Old 06-22-2007, 08:14 AM   #1 (permalink)
Oil pan gasket and rear main seal?
Ok, this may be a dumb question. I am getting ready to do my oil pan gasket and rear main seal. Just looking for any tips to make this go as easy as possible. What is the best plan of attack? I've considered just pulling the motor but I'd rather not. It's a stick shift if it makes a difference. I may pull the transmission already since second gear syncro is acting up at times on 3-2 downshifts. Any help would be appreciated.
Eric
92' F350 xlt, 4x4 Quad cab, 8ft box, srw. 7.3idi w/ATS Turbo, 5spd, 3" exhaust, no muffler. 285's. Just to haul my Jeep.
LowBudget is offline
Old 06-22-2007, 08:24 AM   #2 (permalink)
91diesel's Avatar
Send a message via AIM to 91diesel Send a message via MSN to 91diesel
Re: Oil pan gasket and rear main seal?
It isnt that hard to pull the transmission so I would do it. You MUST at least lift the engine to gain access to the oil pan. The rear seal isnt hard but I am pretty sure you have to remove transmission and flywheel/flexplate. Keep all your bolts in separate boxes or little tins and mark them. This is what i do most every time theres an amount of bolts being removed. Lifting the engine and taking transmission out isnt near as hard as it sounds (least it wasnt for me). Good luck!
1997 F-350, XLT, dually, crew cab, 7.3 PSD, E4OD auto, B+W turnover goosneck hitch
http://community.webshots.com/user/91diesel
**91diesel AKA anthony2010**
http://www.youtube.com/watch?v=fe622W_yZcQ
16.66MPG
[IMG src=file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-9.jpg][/IMG]
91diesel is offline
Old 06-22-2007, 02:19 PM   #3 (permalink)
iv egot to do the same thing sence my rear main is leaking after replacing it when i had the c-6 tranny rebuilt in the 1st of may this year. let me know how it goes.
olred is offline
Old 06-22-2007, 06:50 PM   #4 (permalink)
I looked up the rear main seal procedure at work today on Mitchell on Demand and it lists a couple special tools. I'd like to find out if these are necessary or not. I mean they always list special tools for other jobs that are never needed. I'd like to "tackle" this in the next couple weeks. Thanks again
Old 06-22-2007, 07:10 PM   #5 (permalink)
91diesel's Avatar
I think maybe you need a slide hammer. Not expensive and can be used for many things with other attachments. You could probably get away with out one but it would be a little hard. Its a lot easier though, you can get them at sears or some auto parts stores.
16.66MPG
91diesel is offline
Old 06-23-2007, 12:15 AM   #6 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Punch a screw into the metal of the rear seal, screw it in a little, using a claw hammer now pull out the seal..... Check the crank for scoring of the old seal.
Check out if this seal kit will fit your truck..... comes with seal, speedy sleeve and INSTALLATION TOOLS....
Rear seal kit
F2TZ 6701 A
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 06-23-2007, 01:13 AM   #7 (permalink)
Do not use a oil pan gasket... It will leak for sure. All the "real" gasket sets ( Felpro) don't offer a pan gasket and my Navistar service states not to use a pan gasket. A high grade RTV is all you need. I use Permatex Copper Plus. It has never let me down. I've used it for years on valve covers and oil pans without any leaks ever. And any gasser needs it for the intake manifold fronts and back seal areas. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
icanfixall is offline
Old 06-23-2007, 11:43 PM   #8 (permalink)
I think I've heard before about using silicone instead of a gasket, not a job I want to do twice. I'll call Ford Monday on that rear main seal kit and see what they have to say. I can't stand these oil leaks, I've got something up higher leaking as well. Not sure what yet but the pan gasket is the biggest by far. Thanks again
Old 06-24-2007, 12:41 AM   #9 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Be aware if the leak is above it may be seeping into the rear main seal area.....the seal may not be the problem. Solve ALL upper leaks first.
Old 06-24-2007, 05:31 AM   #10 (permalink)
My Photos: (10)
You can get an oil pan gasket on without pulling the engine. I did it recently by cutting the gasket (NAPA has them) in half (near the rear of the gasket/engine), then slipping the gasket back into place. I used some rtv to mate the two halves. The pan will drop enough to slip the gasket in. No leaks on my truck!
92 F350 XLT Crewcab dually, 204K miles ATS turbo, 3 inch exhaust, DPS IP & Stage 1 injectors, Holly Red pump, K&N, E40D, aux cooler, A-pillar guages, 410 limited-slip rear, Rancho 9000s, towing package, full running boards, mud flaps, 94' Ford (Alcoa) aluminum wheels, Predator camper shell, 200 watts of Sony/Boston Acoustics! Complete engine rebuild at 176k miles. Ford reman E4OD at 204k miles.
2001 Komfort 26FS
My Truck
Fozz is offline
