oil pan leaking - Diesel Forum - TheDieselStop.com
Old 10-20-2009, 09:13 PM   #1 (permalink)
oil pan leaking
Hello, bran new to this site and looking for help with replacing my oil pan '94 F-250 4x4 7.3 idi diesel. Can anyone tell me if you can r&r the pan without pulling the engine? also should I buy another oem pan or is there a better aftermarket replacement?
octoberfarm is offline
Old 10-21-2009, 02:52 AM   #2 (permalink)
CGBear's Avatar
I'm pretty sure you can pull the motor mount bolts and jack the engine up and swap out the pan. As for aftermarket or oem oil pan, I've had good and bad luck with aftermarket. Not for a diesel though. I bought an aftermarket chrome deep sump pan for my small block chevy and it was fine. I bought another chrome pan from the same outfit for my 351m in my plow truck and it was garbage. It leaked through the rear main even after swapping out the rear gaskets twice. The rear of the pan was a little out of round. It's a crapshoot and totally up to you.
1993 F250 supercab longbed 4x4 with a quarter of a million miles. Stock 7.3, e40d trans and 3.55 rear gears. I got rid of my silly 6" exhaust stack in the bed and installed a thrush turbo w/side dump exhaust. The thrush gave it a little too much hush. Pro comp 6" suspension lift. Got a Meyer 7.5 foot snow plow, a flipper style gooseneck hitch, a cushion ride tag hitch and a 21,000lb fifth wheel hitch.
CGBear is offline
Old 10-21-2009, 08:39 PM   #3 (permalink)
Thank you for the advice, now to do the dirty work!
