Old 01-25-2008, 01:22 PM   #1 (permalink)
Oil pan removal to check for bad con rod or wrist pin?
Well I'm still trying to track down my terrible knocking noise so I was thinking of removing the oil pan to see if any of the conecting rod bearings are somehow loose or a wrist pin has some play. First is it possible to tell either of these things from pulling the oil pan?
What is involved in removing the oil pan? Does the cross member have to come off? New gasket?
Thanks,
-Rob
'94 F250 XLT 7.3L. Turbo Diesel 4X4 "OFF ROAD" package, X-Cab, 4.10 grears, Now a 5 speed, original IP, just did injectors,"Wallace mod" 3.5" turbo outlet housing and 3.5" DP and straight piped exhaust, 113K on the clock. Repainted it black. Ispro pyro and boost gauges, turned up pump.
ClassicFordGuy is offline
Old 01-25-2008, 03:25 PM   #2 (permalink)
i learned the hard way... if it runs leave it, your talking a large job. i was unable to remove the oilpan on my 1990 without removing the engine. and i wish i would have left my engine in till it blew, you can find replacement engines pretty cheap.
It is hard to tell where the knock is coming from without dissasembling the motor. Did you lookinto the cylinder heads to see if it is a loose valve guide??
Good Luck!!!
Matt
ASE Certified: Medium and Heavy Truck Diesel
Federally certified air brake technician
1990 F-250 7.3 IDI N/A 4x4 ZF5 Dana 60 front, LUK Clutch SMF, 215k
1991 Ford B700 6.6l School bus, Straight pipe
1987 Ford F350 Dump 4x4 c6, 38k miles, 8 foot meyers plow
2002 VW Golf TDI
1989 Festiva (my favorite)
1989 Saab 9000 Turbo
2002 Saturn SL1 (Daily Driver)
1950 Dodge Coronet
1996 F150 2wd 4.9 5 spd, 136k
Http://www.ammomotorsports.com
90734x4 is offline
Old 01-26-2008, 07:48 AM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (66)
I vote remove the engine........ really there is no room to do much underneath.......
If you want R&R info for engine and (the pan only) PM me an email addy........mention Pan and engine removal.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 01-26-2008, 11:10 AM   #4 (permalink)
My Photos: (27)
Wrist pin bushing or wallowed out wrist pin bore----no way. Same goes for a cracked piston skirt. Either could cause the noise you're hearing.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Similar Threads
3208 CAT Con-Rod Length, etc. wireflight General Diesel 3 11-27-2006 08:11 PM
Pump rod fell into oil pan hoytbowman Power Strokes 1994-1997 General 5 10-20-2006 07:52 AM
oil pan removal grumpyrider 7.3L Power Stroke Engine and Drivetrain 9 09-11-2006 10:40 AM
Rattlin' wrist pin secordj7 6.9L Diesels 5 11-17-2005 07:37 PM
Knocking in #8 caused by wrist pin... chumstone 6.9L Diesels 8 05-04-2005 10:23 AM
