Is this possible on a E350 2wd without removing the engine? Where is the best place to jack up and support the engine? Does anything need to be removed to do so? I do not have AC on the van. Thanks!
id use an engine hoist realy heavy duty one and lift off the engine lift tabs on intake this is how im going to do my motor mount
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
mine is an f series, so i'm not sure how much room u'd have in a van... but i unbolted my engine mounts, put a 2x4 from a floor jack to the harmonic balance and jacked her up. Just be very careful as u push up the jack... keep an eye on all your hoses and you fan.
You'll have to remove the air filter... that gave me plenty of room to jack it up and drop the oil pan.
7.3 IDI F-350 4x4 1990
-Custom: '92 interior; Banks Y Pipe, Flowmaster muffler and Dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
-Soon to come-
Mid 80's front clip
Matching fender flares
Black paint job with chrome trim (fender flares, grill, bed runners, wheels, exhaust stacks, windshield trim, bumper)
2.5" leveling kit
4.6l Mustang GT 1997
-Custom side exhaust (no mufflers, Ford Racing Exhaust tips
-Aftermarket stereo (Alpine headunit; JL Component Speakers; JL 300x2 Amp; JL 10" W7 Sub; JL 500x1 Amp)
<div class="ubbcode-block"><div class="ubbcode-header">Code:</div><div class="ubbcode-body ubbcode-pre" style="height: 34px;"><pre> put a 2x4 from a floor jack to the harmonic balance and jacked her up. </pre></div></div>
Actually this is a NO NO you can bend the crank or damage the harmonic balancer mounting.
Anyone wishing the proceedure on the correct way can PM me an email addy and I will forward the information.
Yeah, good point... prolly wasn't the most intelligent thing i've done, but i guess i got real lucky n it worked... is there any way to jack it up with a floor jack? or r u prity much limited to a engine lift?
-3" Body Lift
-8ft snow plow
-Soon to come-
Mid 80's front clip
2.5" leveling kit
