Old 07-26-2008, 06:56 PM   #1 (permalink)
LunaTech's Avatar
Oil pressure problem????
Ok, first my truck is a 1994 F350, 7.3L IDI with the factory turbo. I just changed the oil (Rotella T 15w40) today, started and let the oil circulate and shut it down to check the level, everything is fine. The problem is with the oil "pressure gauge" in the truck. As I was driving and the RPM's went up the oil gauge would drop. At idle it showed at the "r" in normal but at about 3000 it would show at the "N" in normal. There is no unusual noise coming from the engine, but I was wondering if anyone has run across this before. I did do a search but could not find anything on this but did run across this link ( TheDieselStop.Com - www.thedieselstop.com ) in a post which I plan on doing but I want to make sure there is nothing I need to check before I can get this done. I don't want to damage the engine. Any help would be great.
Jeff
1994 F350 IDI with factory Turbo, crew cab long bed with dual tanks
LunaTech is offline
Old 07-26-2008, 07:47 PM   #2 (permalink)
If you are concerned on oil pressure, you can always connect a manual guage and see what the actual presure is to ease your mind. You dn't have to install in perm., but just as a check....
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Kaliburz is offline
Old 07-27-2008, 08:50 AM   #3 (permalink)
LunaTech's Avatar
Any other comments or ideas?
LunaTech is offline
Old 07-27-2008, 09:21 AM   #4 (permalink)
My Photos: (27)
Only comment is I agree with Kaliburz, these electrical oil gauges fluctuate, due to design it's pretty rare for an oil pump or pressure relief valve to fail in a diesel engine.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 07-27-2008, 11:40 AM   #5 (permalink)
Snotzalot's Avatar
The F series usually had a on/off sender only and not a true gauge. Check the connector on the wiring to the sending unit, that could be dirty or bad. Give it a wiggle to see if that helps. The E series had an actual gauge.
Regards,
Paul - Pocono Mtns. USA '90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, 10 oz. Bars Stop Leak and No ELC!
7.3L Alternator Belt Idler Photos
Snotzalot is online now
Old 07-28-2008, 05:28 PM   #6 (permalink)
LunaTech's Avatar
Thanks for the input everyone. The connector on the pressure switch was dirty. Cleaned it and the problem cleared up. Thanks again.
Jeff
LunaTech is offline
