Oil pressure sending unit - Diesel Forum - TheDieselStop.com
Old 11-10-2012, 10:49 AM   #1 (permalink)
Ok, I have been trying unsuccessfully to take the oil pressure sending unit, which I think is on its way out, off the engine block. I know its located to the left of the glow plug control if your looking at the engine. Anyone have any tricks on how to get it off? I can't seen to get a socket over it and no room with my large hands to get vice grips or pliers on it. Anyone know of a trick. It will save me a lot of cursing at the darn thing.
Shockyjoe is offline   Reply With Quote
Old 11-10-2012, 10:59 AM   #2 (permalink)
Wrencher's Avatar
Can you get to it with a pair of pliers and break the plastic plug off, then use a socket on it?
2002 F-350 CC Shortbed, 7.3 Powerstroke,150K, DIY BHAF, EBV brake mod, fuel shim. Built tranny w/ triple disk Torque convertor and shift Kit, 4" Lift, 35" BFG KM2, TS Performance 6 Position, Banks Big Head Wastegate, 4" Duals, Superlift Air Bags, B&W Hide a ball W/ 5th Wheel Companion, Marinco mod
LOCAL 3 OPERATORS UNION
Wrencher is offline   Reply With Quote
Old 11-10-2012, 11:16 AM   #3 (permalink)
NH2112's Avatar
Send a message via MSN to NH2112 Send a message via Yahoo to NH2112
It may have a hex under the switch body, if you have crowfoot sockets you could use a ratchet & extension to get it off.
Phil
1991 F350 Lariat XLT, 7.3l, 5-speed, crew cab, SRW, 3.55, 2WD. 115K original miles.
1990 Jeep Wrangler Sahara, 4.2l, 5-speed, Dana 30/35 w/3.07s (for now!), 33x10.5x15 BFG Mud-Terrain KM2s on 4" Rough Country springs. Engine being rebuilt after an awesome afternoon in the mud LOL
NH2112 is offline   Reply With Quote
Old 11-10-2012, 11:23 AM   #4 (permalink)
My Photos: (27)
Yea, Phil, I think they're the bell shape design and that's what it takes.
LMJD is offline   Reply With Quote
Old 11-10-2012, 12:12 PM   #5 (permalink)
drinkypoo's Avatar
My Photos: (22)
Might be a can, might be a bell, either way it should have flats under the sender.
If you are replacing it, now is your chance to make your oil pressure idiot needle into an oil pressure gauge. Ford Oil Pressure Gauge Fix
drinkypoo is offline   Reply With Quote
Old 11-10-2012, 12:56 PM   #6 (permalink)
NH2112's Avatar
That article is pretty good. A bit wordy, but good. I'm wondering if a rear window defroster repair kit would be an easier way to bridge the gap after the resistor is removed?
Phil
Old 11-10-2012, 06:51 PM   #7 (permalink)
drinkypoo's Avatar
My Photos: (22)
I have a temperature-controlled soldering iron, so that's what I would use.
If I didn't, I would try a conductive pen, which you should be able to get for about five bucks.
Old 11-10-2012, 08:15 PM   #8 (permalink)
NH2112's Avatar
Just use a pencil, they work great in distributor caps LOL
Phil
Old 11-10-2012, 10:18 PM   #9 (permalink)
drinkypoo's Avatar
My Photos: (22)
The pencil would produce too much resistance
