Just did my second oil change (first was a day after purchase). Had 4000 miles on it mostly commuting to work. Using the "big" 2 qt filter, I got 10 quarts (measured" back out of the engine, when I had put 11 in. Is this about normal for a BOOB truck?
94 F250HD Ext Cab XLT 4x4
Ford Factory IDI Turbo diesel
ATS Outlet/Downpipe upgrade with 4" exhaust system
ATS step 1 upgraded E4OD
Sterling (Ford)10.25 4.10 R-diff,
Dana 50 4.10 F-diff
ISSPRO EV Pyro, Boost & Tranny temp gauges
Pillar Mount
One qt of oil in 4000 miles....that's down right terrible!!! You should sell that truck to me real cheap [img]/ubbthreads/images/graemlins/biggrin.gif[/img]. Put a by-pass oil filter on that engine now, and it'll stay tight. Baja
nope motor is trashed sel it ill buy it for parts to take to the scrap metal place. now where is that big evil grin smiley thingy. ahhh yes there it is! [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
-Jeremy Roooster!
American by birth, Southern by the grace of God!
1991 F250 7.3l 200XXX extended cab long bed. 3.55's REDNECKED OUT!! 295/75/16 Bfg All Terrains 16 in billet rims. New front brake pads and rotors, rear shoes, glow plug controller, glow plugs, return line kit duralast batteries, mitubishi off set gear redution starter, altenator, valve cover seals, holley red pump,new injector pump, soon to be new injectors, new vacum pump. Removed soup bowl and drilled holes in air intake.
Keep in mind that you have probably burned more than 1 quart, because part of what you drained is diluted with water, fuel, etc.... That is why new cars don't "use" oil. Any engine will burn some oil.
1 or 2 quarts between oil changes sounds fine to me.
[/ QUOTE ]Not much more. According to my last oil analysis, fuel dilution was <1%, water was 0%, and soot was .5%. That's less than .15 quart. Oil consumption was less than a quart/3456 miles according to the dipstick.
And how much oil is retained by the filter media? sojerguy's 7.3 motor sounds as trashed (healthy) [img]/ubbthreads/images/graemlins/cool.gif[/img] as mine with 243K miles on it. [img]/ubbthreads/images/graemlins/smile.gif[/img]
