Old 07-24-2007, 12:55 PM   #1 (permalink)
OK, how do you tell if what type of "gears" your truck has?
How do I tell if my truck has 4.10 gears or 3.54 gears ? [img]/ubbthreads/images/graemlins/confused.gif[/img]
If it has the 3.54 gears, how hard is it to convert/change/upgrade it to the 4.10 gears?
1993 Ford F350, automatic, 7.3 L Diesel with after market Turbo!! BUT I REALLY WANT an F450 to better pull my six-horse trailer!!
IF I KNEW THEN, WHAT I KNOW NOW, WHICH IS: NEVER LEND YOUR TRUCK TO ANYBODY!!!
DiannaBlasingim is offline
Old 07-24-2007, 03:01 PM   #2 (permalink)
My Photos: (23)
Re: OK, how do you tell if what type of "gears" your truck has?
Have an assistant handy. Take a long piece of string, and tape it to the driveshaft, on the bottom. Now put a chalk mark on your tire. Have the assistant hold the string, as you drive the truck forward one revolution of the tire. Now look at the string and see how many times it wound around the driveshaft. about 3 and a half times you have 3.54, and over 4 times, then you have the 4.10's. Easy is a matter of money. LOL!
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 07-24-2007, 08:06 PM   #3 (permalink)
never heard of doing it that way. Wouldn't tire size affect that outcome??
1993 F250 4x4 7.3 IDI turbo. 6" lift.
Jeremyy is offline
Old 07-24-2007, 09:19 PM   #4 (permalink)
My Photos: (14)
look at the tag on the rearend or front dif or use the onwers manual and look at your code on the door build plate to tell what it has .
350 Long Rod
89 F350 4x4 CC ,97 5.9 Cummins, Fuel plate ground to a 100 profile,boost set to 30 lbs 5spd 31/2 exh no mufler. boost&pyro gauge.2500 lb frame mount overloads.power stroke intercooler,Valaire clutch.pulling 33ft 5th whl, 2000 Tahoe transporter.Hauling Banshees one with a long rod motor and my own porting,T-3s single carb the other stock port with pipes.
350 long rod is offline
Old 07-24-2007, 10:55 PM   #5 (permalink)
http://www.drivetrain.com/Fordtrkratio_posidata.html
check your door codes with this site
ASE Certified Master Mechanic
1994 F250 ZF5 turbo(factory) a work in progress 208000 miles and counting..
Retired in 2005 more time to work on the truck!
34 years as a ford prototype mechanic.. Now running a big truck shop... series 60 detroits mostly...
roamer37 is offline
Old 07-25-2007, 02:02 AM   #6 (permalink)
asauer's Avatar
Send a message via MSN to asauer Send a message via Skype™ to asauer
Yes, Tire size would affect it. You can do it by yourself. Just jack the truck up and pick a tire to spin. Note where the yoke on the rearend is, then spin the whole works and start counting. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
1997 Dodge 3500: 2WD Cab & Chassis, 12V Cummins, 47RE Automatic, Dana 80, 194,000mi. Parting out.
1989 12V VE Cummins out of Chevy C60? at the machine shop...going into the Ford.
Member of Indiana Air National Guard 122FW MXS
asauer is offline
Old 07-25-2007, 09:07 AM   #7 (permalink)
[/ QUOTE ]No, tire size won't affect the outcome. One rotation of a large tire or one rotation of a small tire is still one rotation of the ring gear. The distance the truck moves on one rotation of the tire changes, but not the relationship between axle and driveshaft rotations.
Casey_1 is offline
Old 07-25-2007, 09:43 AM   #8 (permalink)
My Photos: (23)
Correct. And jacking the truck up and spinning one wheel is not accurate. If the wheel on the other side doesn't turn the same amount, then the spider gears are going to multiply the shaft rotation some amount. Now if you have a locking diff, that would be fine, but I'm going to guess that's a big unknown right now.
- Mel
agnem is offline
Old 07-25-2007, 01:55 PM   #9 (permalink)
cdnsarguy's Avatar
My Photos: (66)
I would be surprised if the rear axle was not a 410 on a F350 dually.
Decoder Chart
Code Ratio Capacity Maker Type Yr
12 2.73 3800 FORD REG 1991
17 3.25 3300 FORD REG 1971
17 3.31 3800 FORD REG 1995
18 3.08 3800 FORD REG 1991
19 3.55 3800 FORD REG 1991
25 4.10. 5300 FORD REG 1991
29 3.55 5300 FORD REG 1991
35 4.10. 6250 FORD REG 1991
36 3.73 7400 DANA REG 1980
39 3.55 6250 FORD REG 1991
45 4.10. 7400 FORD REG 1991
49 3.55 7400 FORD REG 1991
65 4.10. 8250 FORD REG 1991
69 3.55 8250 FORD REG 1991
72 4.63 11000 DANA REG 1991
73 5.13 11000 DANA REG 1991
H5 4.10. 3800 FORD LIMITED SLIP 1991
H7 3.31 3800 FORD LIMITED SLIP 1995
H8 3.08 3800 FORD LIMITED SLIP 1991
H9 3.55 3800 FORD LIMITED SLIP 1991
B5 4.10. 5300 FORD LIMITED SLIP 1991
B9 3.55 5300 FORD LIMITED SLIP 1991
C5 4.10. 6250 FORD LIMITED SLIP 1991
C9 3.55 6250 FORD LIMITED SLIP 1987
D5 4.10. 7400 FORD LIMITED SLIP 1991
F5 4.10. 8250 FORD LIMITED SLIP 1991
W5 4.10 8250 FORD LIMITED SLIP 1995
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 08-26-2007, 10:26 PM   #10 (permalink)
Thanks for your help .... sorry it's taken so long to respond
Things have been very "hectic" the past few months ... Yep, it is the 410
I don't know why I am stressing over this ... my friend's all say ... stop worrying that truck is more than sufficient to pull my 6-horse with 3 horses on it ... but, the tag on the truck's door says 10000 gvw and I am certain that with horses on board that I'm looking at closer to 12,000 maybe 14,000#'s .... The trailer does have electric brakes on all four wheels ... I just am so afraid of damaging my truck ... I really can't afford to buy something else ... and this is the only trailer I have that will fit my big WB's ...
Guys, any suggestions would be appreciated.
Old 08-26-2007, 10:46 PM   #11 (permalink)
88beast's Avatar
Re: Thanks for your help .... sorry it's taken so long to respond
well does it work now?
if its working now then use it till it dies then get a 450 realy brakes on all fours and if ur allready using it i do not see y not?
imo i think a truck like that should have no problem with that trailer especialy with brakes on all wheels use air ride or sway control to help the horses behave is all
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is offline
Old 08-27-2007, 12:21 AM   #12 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: DiannaBlasingim</div><div class="ubbcode-body">Things have been very "hectic" the past few months ... Yep, it is the 410
Guys, any suggestions would be appreciated. </div></div>
GVW = Gross Vehicle Weight, which means what the maximum the truck itself can weigh. I.E. Truck weight plus tongue weight of your tralier (and anything else you are carrying in the truck).
What you are really looking for is GCVW = Gross Combined Vehicle weight, that isn't labeled on the truck data plate. It is the rating that includes total trailer weight plus truck weight. It is higher than 10,000 lbs. However, I don't remember what it is, or where to find it.
To give you an idea, I have 1993 F-350 Crew Cab Dually with a GVW of 9,999lbs. It weighs over 7,000lbs empty, if trailer weight was limited by GVW, then the heaviest trailer I could pull would be less than 3,000lbs; not even enough to pull a two horse trailer with one horse.
I believe you are fine, maybe someone else on the forum can point us where to find the rated GCVW. I've pulled 5 ton of hay on a 3,000lb trailer many times, including over Blue Diamond Pass in NV (very steep), and not had any problems.
1993 Black F-350 Dually Crew Cab
7.3 w/ Banks Sidewinder Turbo
5 speed, 2x4
rollfj is offline
Old 08-27-2007, 01:55 PM   #13 (permalink)
My Photos: (6)
If you have the owner's manuals, the CGVWR is listed in there - it's tabulated by engine/trans/rear diff ratios. I'm not sure if it's in the main book or in the diesel supplement.
My '91 4x4 F250 HD (HD=4.10 rear and F-350 brakes) is somewhere in the neighborhood of 14k lbs CGVWR - so I'm guessing you're OK. The CGWVR rating has nearly everything to do with braking capacity, and little to do with acceleration. If you don't have the books, maybe someone with a set of '93 manuals can look it up for you!
-Nate
CliFord is my truck... &lt;img src="/ubbthreads/images/graemlins/cool.gif" alt="" /&gt;a [color:"red"]RED[/color] '91 F-250XL, Standard Cab, 4x4, 7.3IDI NA w/ DAS Heads, ZF 5spd, 4.10's, Wrangler AT/S 285/75/16's on 16x8 rims, Rancho RS5000 shocks & steering stabilizer, 175k miles & counting
CliFord is offline
Old 08-27-2007, 08:32 PM   #14 (permalink)
No, I don't have the books .. Anybody ?????
Old 08-27-2007, 09:08 PM   #15 (permalink)
Hey lady, don't sweat it. I live in Oregon, we have some mighty big mountains here, I just towed a 2tom chevy truck on a 20' flatbed bumper pull behind my '93 F250 w/3.55 gears. Just go double nickle, it's OK. My understanding is that the tranny is the week link in thease rigs, so get a good cooler installed, seeings how you live in Arizona.....
'93 Ford F250 w/ 7.3 IDI diesel (no turbo) E4od auto. SC/LB 2WD, but hey, got 3 attenas. retired government vehicle.
'26 tall T coupe on '67 scout frame w/400 Ford/C6
'00 Dodge Ram 1500 SC/SB w/318/5spd 4X4 3" SkyJacker lift 33-12.50X15 Perreli Scorpions
'01 Dodge Ram 1500 Quad cab/SB w/360/auto 4X4 NO LIFT!!! Running 33-12.50X15 Hi-Tech-Retreads with Green Diamonds (alternative to studs!) on saw blade chrome wheels.
'62 Caddy 2dr, "slammed" with air bag suspension. I can literaly set it on the ground!!!!
'48 CJ2A w/'61 over head valve engine
'77 Chevy Caprice, rare 2 door! Built 350 4 bolt mains. Weyand high ram intake, Headman Headers, dual glass pack "cop callers", TH350 with high stall converter and B&M "street/strip" kit (churps the tires hitting 3rd @ 90MPH!!!!)
'84 AC 5040 w/ loader
'71 Dodge D200 w/'69 vette 327 & powerglide
'97 Morgan built 20' tilt car hauler
'01 Morgan built 16'cattle trailer
Ford 9N
Ford 8N
JD model 40C crawler
shitface is offline
