Old 06-01-2005, 02:55 PM   #1 (permalink)
My Photos: (14)
Ok - now I'm Skeered!!!!!!!!!
In talking with a fellow Dieselstopper, we've come to the conclusion that my pyro may be faulty. I've got good boost but low EGT's. Not good cuz I've been hammering this beast. I sure hope if it is off that I haven't exceeded the 1100* mark!!!! I haven't towed with it but......... still frowning.
Old 71 '93,F350 Crewcab, 7.3IDI with Hypermax non-Wastegated Turbo, 5 Speed, 4" Fabtech Lift, Filter Engineering Coolant Filter, 4" Straight pipe.
TurboYT is offline
Old 06-01-2005, 03:31 PM   #2 (permalink)
My Photos: (13)
Re: Ok - now I'm Skeered!!!!!!!!!
Turbo, I bet your pyro is fine. With an unloaded truck, H-max turbo, I bet you would have trouble going to much over 1100. With a load, it may be easier, but if you are under 15psi on boost, I bet your readings are right on. By the way, what kind of boost can you get from your new IP. How do you like it so far? Scotty
Semper Fi
Scott Beretz
2006 Dodge Megacab 4x4, Cummins, 6 Speed, Airbags, Quadzilla Commander, XZillaraider 2, 285/75R17 Toyo OC AT's
Pulls a: 3814SS Keystone Raptor Toyhauler w/Quads
beretzs is offline
Old 06-01-2005, 03:35 PM   #3 (permalink)
My Photos: (14)
Love it, so far. I'm only able to get 10-11+ hammered unloaded. Accelerates much better. I think it will really come alive when I get it timed, build an intake, and install the holly red pump.
I really want to ride in another IDI so I can compare. The car I borrower while the truck is being worked on is an acura RSX so I get spoiled in the accelartion department.
Any more info on the possible SoCal IDI rally?
TurboYT is offline
Old 06-01-2005, 03:44 PM   #4 (permalink)
SoCal IDI Rally??? Who? What? Where? When?? These are things inquiring minds want to know. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
jerry
'91 F350 CC,7.3NA w/K&N,E40D(rebuilt--way too many times), 2WD,3.55 rear end,new IP,new u-joints & carrier bearing, new rotors, new calipers, new drums & hdware, added Auburn limited slip unit (2/8/05)w/valvoline synth 80-90w, new batt.cables,new window motors,new radiator & hoses, 500K, (new injectors)+ mi (now 678K miles)& still Truck'n. If I can fix it, it ain't broke, I'd rather do it myself.(yes, I add,stanadyne, lucas or power sytems fuel additive in every tank, w/maybe 1-2x year full big bottle dose split between both tanks). New tires & pretty wheels, front end rebuild 3/17/05. Bilsteins added 6/12/05. New motor mounts & valve cover gaskets (9/06.)Future hopes finally fixing my electric door locks & adding remote entry/alarm system.
http://community.webshots.com/user/jl_mendoza
jlmendoza is offline
Old 06-01-2005, 03:54 PM   #5 (permalink)
My Photos: (14)
Here's the link. It's posted in the events section:
http://forums.thedieselstop.com/ubbt...31&fpart=1
TurboYT is offline
Old 06-01-2005, 08:23 PM   #6 (permalink)
one question.Where is your Probe?If it is post turbo and hitting 1100Degrees.....EWWWWWW.Not good!You might have been hitting some high temps at the head....Like in the 12-1400Degree range.If at the head then that seems about normal.If you really want,find someone with a pyro they are fixing to install and do a quicky install(duct tape and allegator clips) to double check yours.
IDI Till I Die!!!
NCC-1701UAV U.S.S. Enterprise -1991 F350 CC dually.Lighted heated west coast mirrors,Nathan Airchime K3HA air horns,attitude from hell itself!
1994 F350 Crew Cab Dually,7.3 IDI turbo-Currently in the Roundhouse awaiting 10 year overhaul. White Lightning
1971 M35A2 deuce and a half.6wheel drive,Power Nothing!125 Horses in a 13,000lb truck.Real get up and go power! Martyr Machine
Cousteau 2006 Ranger STX-3.0 V6,5spd handshaker,standard cab
m35a2 is offline
Old 06-02-2005, 01:19 PM   #7 (permalink)
My Photos: (14)
The probe is in the "standard" hypermax position, pre-turbo, passanger side exhaust.
TurboYT is offline
Old 06-02-2005, 02:57 PM   #8 (permalink)
My Photos: (23)
That's a good location. Pyro wiring can affect the accuracy. Always get the wiring kit, and never cut or adjust the lenght of the wire.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 06-02-2005, 07:04 PM   #9 (permalink)
My Photos: (14)
Mel,
what kind of numbers are you running?
TurboYT is offline
Old 06-03-2005, 10:01 AM   #10 (permalink)
My Photos: (23)
About 280 to 300 at idle, and anywhere from 600 to 900 cruising depending on speed. On hills I drive by the pryo and take my foot out of it when I have to.
- Mel
agnem is offline
Old 06-03-2005, 12:51 PM   #11 (permalink)
My Photos: (14)
yeah, either my pump isn't turned up all the way or my pyro is off
idle doesn't even touch 250, cruising 450 or so. hills 650 maybe 700.
Unloaded of course.
TurboYT is offline
Old 06-03-2005, 12:57 PM   #12 (permalink)
My Photos: (13)
I would bet your IP is not turned up all the way. When I got mine, the internal was maxed, but the external was not. So I just let the external loose, just holding on by a few threads and THEN I got the results I was looking for. Scotty
Semper Fi
Scott Beretz
beretzs is offline
Old 06-03-2005, 01:31 PM   #13 (permalink)
My Photos: (14)
Your correct the external is not all the way out. I figured that because it's marked with the "red stuff" that it is that way for a reason? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
TurboYT is offline
Old 06-05-2005, 02:36 PM   #14 (permalink)
Unloaded of course
About the same #'s I'm seeing and I have mine in the Hypermax piping too. Cruising at 75 I will run about 550.
Mine was "painted" with grey stuff...LOL My understanding is that it is marked so the pump builder will know if it's been played with, therefore voiding their warranty.
My pics...
Sorry to all the loyal 7.3 guys, but I traded my '91 7.3 in on a 2002 F250 Ex cab V10 4x4. SCT Xcalibrator2 with tunes by Powerplay Performance. 285/75/16 Toyo M/T's. Took a long time to get used to the ping-pop of a cooling catalytic converter...LOL.
'85 Bronco swapped up to a 302 4bbl from the 300 I6, NP435 4spd, NP208, 32x11.50x15 Radial RVT's, Soon to be 6.9 turbo powered.
86 F350 Cab&Chassis with a dump bed. 2wd 6.9 and 4 spd tranny. No mods to engine.
2000 Volvo 660 N14 Cummins, 500hp 1650 ft lbs, Autoshift tranny 10spd.
What part of "SHALL NOT INFRINGE" do you NOT understand?
aceohearts is offline
