Old 06-16-2006, 01:23 AM   #1 (permalink)
okiegringo idler pulley
hey thats a great idea. i think i will do that to mine. where do i find a pulley like that?
1989 F350 4x4 crew cab
7.3 , ats turbo w/gauges
running homemade biodiesel since july '07
IM OHV POSITIVE...ARE YOU?
duneburner is offline
Old 06-16-2006, 04:37 AM   #2 (permalink)
Re: okiegringo idler pulley
what is the great idea with the pulley????
David and his Ford truck with a little motor and a big idea......
Ford F-350 Dually Crew Cab 5-Sp 7.3 IDI Centurion Conversion. No mods, rebilt IP and replaced injectors. Used as personal driver and pulling my RV camper.
Planned upgrades are a new and better turbo and larger exhaust pipes than the 21/2s that are already under the rig/ would like a 6 spd tranny but dont know if that is a feasable or smart investment yet.
1993 Dodge 3/4 ton Van Conversion 318CI
1978 Dodge Magnum XE T-top Classic 4BBl 400CI (Honeymoon Car)
1965 Dodge Polara 4 DR 383CI
AmaMoparmanbutlikeForrrrrdtrucks
truckdrivindave is offline
Old 06-16-2006, 08:56 AM   #3 (permalink)
It's to stop the alternator belt on the v-belt setups from flopping around so much. One of thesem days, I'll get around to doing something with mine... http://photos.thedieselstop.com/show...amp;thecat=500
86 F250 4wd, 6.9, T-19 trans, 4.10 axles, opened up the intake, fabbed 3.25 exhaust to self made muffler, 3.5 out to 4" tip. GM prefilter/water separator, Holley Red fuel pump.
92 F350 2wd crew cab, 5.9 Cummins with A518 auto, 4.10 axle, gear vendors overdrive.
fellro86 is offline
Old 06-16-2006, 10:14 AM   #4 (permalink)
I asked at Autozone yesterday about ordering an Idler pully, about $32. I'm going to check with Napa and see what they have, since Napa is closer to my house.
My alt belt flaps all over the place no matter how tight I set it. I need this mod (thanks Gringo).
--Hugh [img]/ubbthreads/images/graemlins/smokin.gif[/img]
1991 F250 XLT, 2WD, 7.3L IDI, 5 speed, 168K.
waterdude is offline
Old 06-16-2006, 02:35 PM   #5 (permalink)
Just go into Autozone and order the pulley? Just any 4" diameter pulley? Is there a part number associated with the pulley? To fit the V belt properly and size of bolt hole need more specifics. Great idea.
Just installed new belt yesterday.
'90 F250 4x4 std cab 5 sp. 7.3 IDI
Velvet spring shackles, K&N Air, Warn Hubs
Baldwin 5200 coolant filter, 175K & counting
Captj is offline
Old 06-16-2006, 07:05 PM   #6 (permalink)
Still working on the specifics...new Idler Pully must fit a V-belt and have sealed bearings inside of pully.
I haven't pulled my bolt yet, but I will this weekend.
--Hugh
Old 06-16-2006, 10:22 PM   #7 (permalink)
My Photos: (25)
Look at my photo album and the part number is on one of my pics i took when i put the pully on mine several months ago. It is working great. And so easy to do.
Dwight in Mississippi
dlblack is offline
Old 06-16-2006, 10:51 PM   #8 (permalink)
My Photos: (17)
The bolt hole in the pulley is larger than the bolt in the water pump and too short once the pulley is there. So, I went to Ace Hardware and bought a 1/2" longer bolt and one heli-coil that fits the bolt. Cut the tang off the heli-coil and screw it onto the bolt and it will center in the pulley hole. OkieG
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 06-16-2006, 11:10 PM   #9 (permalink)
My Photos: (25)
Good idea with the helicoil and will keep that in mine.
My bolt/pully has never moved sence i installed the okiegringo pulley.
It works great and a lot less noise and vibs. Just wish i had done it years ago.
Thanks again okiegringo
Dwight
dlblack is offline
Old 06-17-2006, 11:19 PM   #10 (permalink)
well i got the number from dlblack
45954 is autozones part # also 845954 bought one today works like a charm cost a whole 18.00 for pulley incl tax 2.00 for fasteners
list is like this
1, 45954 ac pulley
1, 11/2" 3/8 grade 8 bolt
1, split lock washer
4, 3/8" gr8 flat washers
I turned a sleeve out of a drop off a gun barrel ,tight clearances and turned outside .480
thanks okie
god bless
MINE 95 f350,cc,4x4,7.3psd,e40d,3" to 4"down pipe ,5" straight exhaust,afe stg 2 intake,byron eddins elect fuel system,cobalt oil,boost,pyro,trans temp gauges,bpd stg1 injectors, 17deg hpop and 96 resavoir mod, 3.55 gears rear Limited slip , rear air ride suspension ,front add a leafs ,crank case vent mod,hughes cast trans pan,sonnax valve and superior steel accum valves, tony wildman 4 pos. chip, ported turbo and modded pedestal, 6.0 ic with custom 3" intakes and pipe, custom byron eddins 4 line oilsystem with no check valves in hpop ,119,000mi and counting
HERS 95,f350,cc,4x4,7.3 psd,e40d,3" dp,4" exhaust with donaldson muffler,k&n in factory cleaner,tymar hpx,fpr shimmed,fuel heater removed,flapper removed from turbo and modified pedesta, tony wildman 4 pos chip,150000 mi and counting
boys
96 f350 cc/4x4 centurion, 7.3psd, 4" lift , e40d, fuel heater removed,fpr shimmed,ccmod, 150000 and counting
glassbed is offline
Old 06-17-2006, 11:59 PM   #11 (permalink)
My Photos: (17)
You're very welcome, guys. My idler pulley has been on for 2 yrs now and still with the same alt belt. Before the idler, my belt would vibrate soo much that it hit the lower bolt head of the fuel filter bracket. That was the wear point on my engine. [img]/ubbthreads/images/graemlins/smokin.gif[/img]OkieG
Old 01-24-2007, 07:50 PM   #12 (permalink)
I'm planning to do the okiegringo pulley mod. I went to autozone and purchased the 45954 pulley like in the pic but it looks different than the one in the pic. The one in the pic looks like it has a offset hub on it. The one I purchased doesn't have that. I even went to NAPA where that # crossed to a 38003 and got the same result. Is it just the pic that makes it look that way or what? Also the "V" doesn't seem wide enough for the belt. Is that ok because it is just an idler or am I getting the wrong pulley?
a91f250 is offline
Old 01-25-2007, 12:02 AM   #13 (permalink)
I don't get it, i tried this mod with the pulley from autozone and there was like.. 1 micron between the mod pulley and one of the main pulleys on the water pump and with the engine running it would vibrate the pulley just a little bit and it would beat against the other pulley resulting in this clinging sound. So i took it off... What happend to me? Everyone elses seems to work fine.
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 01-25-2007, 12:24 AM   #14 (permalink)
My Photos: (49)
I put one on mine a while back, works great .I was changing belts every six months.I used Dblacks pics.for reference.I cut a piece of 1/2 inch stainless tubing and stuck it in the middle to take up the slack....Robert
1989 ford f-250 4x4, new DAS remanufactured 7.3, zf 5 speed- 410 gears, 600.000 + miles,hypermax turbo+exhaust system, air lift air bags all the way around,luk single mass flywheel,york on board air compressor and tank,recaro leather bucket seats,spray on bed liner, holly red pump,coolent filter,gear vender,filtration solutions oil bypass filter,ford motorcraft glow plugs,mechanical gauges in the stock cluster, mean green starter,hypermax cowl air induction system,vormax fuel filter, grover air horns,evans coolant,baja block drains.
Pictures: http://photos.thedieselstop.com/show...1&si=robertleo
robertleo is offline
Old 01-25-2007, 01:57 AM   #15 (permalink)
My Photos: (17)
Eric, is your water pump pulley bent? Probably got bent the last time the alt belt broke and wrapped around it. I'm still running the same belt. [img]/ubbthreads/images/graemlins/shrug.gif[/img]OkieGringo
