Old 11-09-2007, 02:51 PM   #1 (permalink)
Old style Banks tubo
My old style, non-wastegated, Banks trubo has a hole in the exhaust portion of the turbo (I think it is a corosion hole). I noticed there is black residue on the cover but you can't see or smell the exhaust. The other day it died and I had to crank it alot to start and white smoke came pouring out of the hole. Truck drives fine, Poor milage, starts fast every time, except when I kill the batteries. My buddy thinks I can just weld the exhaust housing. Or should I buy a new Banks turbo kit. What kind of milage and power gains might I get from the new style turbo. I get around 11-12mpg. Just wanted to see if anyone else has gone through this.
1993 Ford F-350, crew cab, 4X4, 300000mi, Banks old style turbo, 4.55 gears, 35 in tires; crudy E4od w/ transmission lock up mod, radioactive dirt.
twowheelv is offline
Old 11-09-2007, 04:56 PM   #2 (permalink)
Re: Old style Banks tubo
Had an email from Banks yesterday saying they were having a huge sale to offload new items that were in opened or damaged boxes. I'm very disappointed with Banks customer service, but it may be less money for you than getting a new kit.
'94 F350 Dually 7.3 <span style="color: blue"> IDI </span>
<span style="color: red">Banks Sidewinder & Trans Command, 3.5" Exhaust </span>
<span style="color: blue">Gear Vendors Over/Under Auxilary Trans </span>
<span style="color: green">Gambler 209 (THE Ultimate Bass Boat)</span>
Lance 880 Camper
cre8ive is offline
Old 11-09-2007, 10:38 PM   #3 (permalink)
Do you have a pyrometer? The hole you describe could be the port in the Y before turbo for the pyro.
I had the old style on my 90 for about 200,000 miles. Got beter mileage than the 91 with the WG setup. Not that much better running in a stick truck.
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 02-28-2008, 12:34 PM   #4 (permalink)
It wasn't a hole. The previous owner only put 3 out of 6 bolts on the turbo to exhaust down pipe flange. What type of gasket material should I use?
Old 02-28-2008, 02:20 PM   #5 (permalink)
High temp silicone may be doable, or, I use high temp furnace & stove gasket adhesive (you should be able to get that stuff at Lowe's or any hardware store)
'94 F250 XLT- IDI Turbo, 5 speed, 4x4, manual hubs. ATS upgrade, 3" downpipe, 4" exhaust. Autometer pyrometer & boost gauges. More coming.
'87 Thunderbird Turbo Coupe
Lots of mods & pretty quick.
ghunt is offline
Old 02-28-2008, 02:45 PM   #6 (permalink)
Bill1013's Avatar
Banks Power Systems - Owners Manuals
Check here this may help.
Bill aka Oldbull
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo Radio SD & Tape 126,700 03/08 Strictly stock. Build date 03/99
Rebuilding engine. 92 F350 7.3 IDI CC LB 2WD Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
Reman IP - New Delphi Injectors -New Beru GP's 07/07 New radiator & hoses New WP
Dual Exhaust 3"X18" resonators frnt. of rear wheels
Soup bowl gone, 4" intake W/AZ filter
Cobra CB W/Weather Interrupt - Dual Trucker Antenna's
Blk. Grill W/Brush Guards - Fog lights - Rally driving Lights. GN 20K & Reese 16K 5er hitch
http://community.webshots.com/user/oldbull8?
Formally OLDBULL
Toys: 1984 Coachmen Leprechaun F350 Chassis 460CID 92K miles.
30 ft. Jayco Jay Designer 5th wheel.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One flash and it's gone.
Bill1013 is offline
