Operating temp on 94' E40D transmission... - Diesel Forum - TheDieselStop.com
Old 10-25-2005, 03:26 PM   #1 (permalink)
The truck I bought has a aftermarket transmission temperature gauge in it. Was wondering what a safe running temperature is for this transmission? It usually runs around the 170-180*F....
1994 Ford F250 extended cab long box Factory Turbo Diesel with E4OD.
johnny_munyak is offline
Old 10-25-2005, 04:24 PM   #2 (permalink)
Re: Operating temp on 94' E40D transmission...
That sounds about right. Mine runs around 160°-170°F unloaded at highway speeds. I have a deep aluminum pan and aftermarket trans cooler.
Neal in MN
1997 F350 4x4 Crew Cab, long bed, BTS trans, BTS chip, AeroForce single guage, MBRP 4" exhaust, DIY air filter, SD intercooler awaiting time to install!
1980 Mercedes 300D
Sold - 1990 F350 4x4 crew cab ATS turbo IDI
Sold - 1990 F250 4x4 extra cab NA IDI
Sold - 2005 F350 4x4 crew cab totally stock
V2Neal is offline
Old 10-25-2005, 04:29 PM   #3 (permalink)
What is safe temperature for pulling??
Old 10-25-2005, 05:33 PM   #4 (permalink)
I think they usually say you can run all day long at 200*, you don't want to see much more then that for long, 225* you pull over. Where do you guys have your senders mounted?
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
aaklingler is offline
Old 10-25-2005, 05:36 PM   #5 (permalink)
My Photos: (5)
Where are you taking the temp reading from?
Tranny Pan, Side of tranny or in the hot line coming out of the tranny before any coolers?
If in the Tranny pan or the side of tranny you can run upto 200° on a pull, after than back off her a little to let it cool.
Now if your taking the temp from the hot line before any coolers you can run at 225° all day long and not worry one bit about it. I installed mine in the hot line before the coolers and the only time I had to worry about it was when I was backing up. Now if I can off the highway I would see it spike up once I got into city traffic but I would just take it easy then I would let her cool down to BELOW 200° on my gauge before shutting her off. Typically I let her idle until the temp was around 180°.
Travis
Will Work For Diesel Fuel.
argve is offline
Old 10-25-2005, 05:49 PM   #6 (permalink)
hmmm...I'll have to check under the truck. I'm not sure where the sensor is pulling from? At least this gives me an idea....
