Parking Brakes - Diesel Forum - TheDieselStop.com
Old 07-04-2009, 07:28 AM   #1 (permalink)
Parking Brakes
Right rear park brakes will not release. I can roll back but not forward, rolling back releases the park brake somewhat and I can drive but it still makes the brake become hot. I find that I would have to get under that right rear side and pull on the cable to release the park brake. What do you think the problem is? Ive not jacked the truck up and looked at the right rear brakes yet....I am using chocks and putting the rig in 1st or rev gear to park when parking rig....
David and his Ford truck with a little motor and a big idea......
Ford F-350 Dually Crew Cab 5-Sp 7.3 IDI Centurion Conversion. No mods, rebilt IP and replaced injectors. Used as personal driver and pulling my RV camper.
Planned upgrades are a new and better turbo and larger exhaust pipes than the 21/2s that are already under the rig/ would like a 6 spd tranny but dont know if that is a feasable or smart investment yet.
1993 Dodge 3/4 ton Van Conversion 318CI
1978 Dodge Magnum XE T-top Classic 4BBl 400CI (Honeymoon Car)
1965 Dodge Polara 4 DR 383CI
AmaMoparmanbutlikeForrrrrdtrucks
truckdrivindave is offline
Old 07-04-2009, 09:28 AM   #2 (permalink)
FMTRVT's Avatar
My Photos: (16)
Cable.
Jack
Truck Modifications below in Pictorials on Facebook. Search in Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
FMTRVT is offline
Old 07-04-2009, 10:10 AM   #3 (permalink)
88beast's Avatar
cable is sticking or brakes need adjusted you neeed one of those spoon brake tools to adjust them if you try this it may help
hit about 35 in reverse and slam on the brakes works when mine does this but find an open parking lot for it
sometimes these just fall off the adjusterand start to stick ive found that helps reset them idk how or why it just does sometimes
last thing is pull off the drum and adjust from there
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
