Re: Pillar gauges appearance question??
I use Autometer guages since they work so well in the race car. I have a standard black face gauge and used the green light cover to make it match the OEM gauges. The only thing that is different is the Autometers have red pointers and the OEM is white.
I dont know if that will work, but I think most pyros use the same probe/leadwire setup. Maybe someone else has more info on that.
94 F-350 CREW, FACTORY TURBO IDI, 10PSI BOOST, 3in STRAIGHT PIPE EXHAUST w/ BANKS DOWN PIPE, K/N FILTER, AUTOMETER GAUGES, BUILT E4OD, 4.10 gears, 200,000MI. 6 245-75-R16 TERRA-TRAC M/T's 2-KC DAYLIGHTERS
