When the truck flexes while drining over rough terrain or even making a hard turn on pavement the truck makes a popping noise. It sounds as though it comes from the driver's side front of the vehicle. Any thoughts?
1989 F250 single cab 2WD
7.3 IDI with 150,000 miles
Single Straight Exhaust with 4" Chrome Tip
No Soupbowl
E40D
LT 265/75/16 Yokohama AT's on 16x7's
Factory Hubcaps
Gooseneck hitch
Homade rear pipe bumper with built in utility-lights and D-rings
Diamond Plate Aluminum Toolbox
Tinted Windows
Future mods: Roof Markers and front pipe bumper
1997 F250 Extended cab 4x4
PowerStroke Diesel, E40D, Manual Hubs
All Stock Except Exhaust - No Cat, 18" Glasspack
Our 93' does it too. Very annoying. I remember a thread while back that somebody said it was their cruise control unit, where it was mounted. I know that's not it on mine. Almost sounds like it is coming from the firewall or under the dash. If you figure it out, let ME know. [img]/ubbthreads/images/graemlins/smirk.gif[/img]
These are the bolts that hold the hood hinges on, IIRC. Same problem on my truck. I removed the bolts, greased them, and the problem hasn't returned.
Not the bolts on the firewall... the bolts on the front quarter panel. They're vertically-oriented and just below the hoodline. Water gets into them and rust forms, causing the noise.
Mike
- SOLD: 1991 F-350 XLT crewcab, dually. BTS E4OD. My favorite truck.
- NEW DAILY DRIVER: 2006 Ram 3500 SLT quad cab. 5.9L Cummins, 6-speed manual transmission, nav system, Jake brake. No mods, now or ever. 100% satisfied.
Mine has always done this too. I asked about it once at the dealer when I was in for some warranty work. They said it was from rivets in the frame. Apparently there was a TSB issued on this. The repair called for replacing the rivets with bolts, however the dealer told me that it didn't always cure the problem, and there was a risk of the bolts working loose. I never did have it done, and it still pops occasionally.
I would not call mine a popping, but it does make a sound on the drivers side. I think mine is more in the coil spring pocket area. IIRC, I have a bit of play with the washer that is under the bolt that holds the spring down. I know my washer will spin freely, but the bolt is tight. I always wondered if there was an insulator under the spring? I have not been able to find one listed on the parts catalog at work though.
Joe
Hanover, PA
1993 Ford F350 XLT CC DRW 4X2.
"Factory Tech" modified E40D, 4R100 trans pan
Dual B&M plate style coolers, 4.10 rear,
Factory ATS turbo, Upgraded down pipe,
housing and elbow, DPS Stage 1 Injectors
Banks exhaust, Isspro and Autometer gauges.
That thought has been in the back of my head. Nick recommended popping the rivets on the brackets and pulling the whole shooting match to change 'em, then bolt it back in. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Me thinks going to 4WD would be easier! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Joe
Hanover, PA
The sound comes more from the top area than the bottom, so I could believe it might be the hood hinges, or some other bolt in that area. It's a torsional stress induced noise.
Radius arm bushings just replaced about 8 months ago. I believe that I will check the hood hinge bolts. Sometimes the noise seems to be fainter than at other times so it may very well be them seeing that the passenger side bolts are farther away from me in the ****pit!!!
Read in another post in the psd forum about maybe transmission crossmember or motor mounts?
Any thoughts there?
No Soupbowl
E40D
Factory Hubcaps
Gooseneck hitch
Tinted Windows
I have a popping under similar circumstances also, but mine is a very loud clunk or pop coming from the rear of the truck. Im not sure what it is though. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
The Vehicles:
1991 Ford F-350, crew cab long bed, 4X4 with a factory 3 inch lift. Has the banks sidewinder turbo kit w/ wastegate. E4OD automatic that works now. 35" BFG MT's, Limited slip in the back. Going on 167 K miles. Thinking about whacking the muffler off of it. Custom 1000 watt sound system, and brand new headlight assemblys. On board air system with amtrack airhorns.
1979 Jeep CJ-7, 2.5 inch lift, 33" procomp Xterrains, 6 banger with the T-18 trans. New seats, and such. Its a project in the works.
I have a loud pop sound when I turn either direction. It started after I put on my 4 in lift kit. It doesn't do it all the time though. Could it be the leafs shifting when there is lateral flex? Any ideas? Thanks.
Sold it!!! 1993 F350 rebuilt 7.3IDI Turbo Crewcab running 4.10 and 35x12.50x16. Who needs mufflers... straight pipin' with banks downpipe upgrade and 3 in exhaust all the way back and gettin 18mpg if my foot wan't so dang heavy. Biodiesel home brewer and convertion to WVO almost ready for install. Electric Facet fuel pump conversion.
Just got rid of the popping noise I had.
Shock on one side "egged" out the mounting lower end.
And I replaced upper & lower ball joints on the same side.
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
AK check the frame by the steering box for cracks.
It might be your transmission crossmember. I had mine tac welded into place... popping stopped.
If the previous suggestion I made didn't work... try that.
The truck sounded like it was going to come apart whenever I pulled up to camp at the horse races I do. Got lots of attention as I popped my way into a parking spot (offroad).
I'd suggest you only do this if you don't anticipate having to do any engine/trans work anytime soon--not all shops have the stuff needed to undo the tac weld. Held up my transmission replacement a couple years ago for 4 days while we waited for a welder to come.
Mike
