Is it possible to buy an injection pump rebuild kit? - Diesel Forum - TheDieselStop.com
post #1 of 28 (permalink) Old 12-13-2008, 05:05 PM Thread Starter
I know everyone recommends against doing it yourself, but I have done successfully many such tasks when equipped with good directions and/or info. I have over 400k miles and feel that my engine will run away if I don't do something, so if I rebuilt a pump and it didn't work out, the result is the same. I can't afford a rebuilt pump or a rebuilt engine, but a friend donated a 460 gas engine for if neither works out. The only concern about the 460 is, does the ZF 5-speed bolt up. I need this truck and it seems to like me. -Jeffy.
'92 F-250, 7.3idi, 5-spd, over 400k miles on never repaired engine. Yancey, Tx. Long live Ford!
Jeffy 92 is offline
post #2 of 28 (permalink) Old 12-13-2008, 06:29 PM
chuckster57's Avatar
Hate to tell you but even with great directions and all the info in the world you won't have the equipment needed to do this job. Tolerances in this pump I am told are way to close for the DIY'er. Also you need special fixtures to flow test and adjust these things. If your truck is running good now, just set a little bit of $ aside each payday and save up for the rebuilt pump.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 28 (permalink) Old 12-13-2008, 11:33 PM Thread Starter
It's for a '92 F-250 idi 7.3. If you have an extra I could use it if your price is merciful! -Jeffy.
Jeffy 92 is offline
post #4 of 28 (permalink) Old 12-14-2008, 12:06 AM
Jeffy, you need a special machine to calibrate the IP, way to many places you can screw up at without said machine. Also, the big-block trans will not bolt up to the diesel, and the other way around.
M.L.S.C. is offline
post #5 of 28 (permalink) Old 12-14-2008, 09:22 AM
mankypro's Avatar
You can get a Bosch rebuilt DB2 IP from Pensacola for $295.00 shipped. Mine has worked flawlessly thus far.
1984 F-250 6.9l IDI
2001 Excursion 7.3l PSD
mankypro is offline
post #6 of 28 (permalink) Old 12-14-2008, 01:06 PM
Is this truck's pump a Bosch? I thought it was a Stanadyne.
Pele is offline
post #7 of 28 (permalink) Old 12-14-2008, 01:49 PM
mankypro's Avatar
Stanadyne pump, rebuilt by a Bosch shop, according to Pensacola Diesel.
1984 F-250 6.9l IDI
mankypro is offline
post #8 of 28 (permalink) Old 12-14-2008, 03:06 PM
My Photos: (27)
Chuckster's right. I have a Stanadyne pump overhaul and repair manual and without dragging it out, I can recall off the top of my head at least 12 adjustments and calibrations that have to be made on a test stand.
Your best bet for a quality job and fair price is phone a local large truck shop and ask them who they locally send their pumps out to for an overhaul. We dealt with a local pump and turbo shop for about 15 years and I can't recall a comeback from the guy.
LMJD is offline
post #9 of 28 (permalink) Old 12-14-2008, 05:28 PM Thread Starter
Mankypro, can you give me contact info to this Bosch overhauling shop? $300 is the best price I've ever heard on the injection pump. Like I have indicated, my engine has over 400k miles on it, so there's no point in putting an expensive pump on an engine that's going to spit a rod at any time. I've got that 460 gasser... And I'm not afraid to use it! Don't make me do it! It's a 460 and it runs on gas, so watch out! Anyway, I appreciate the info you folks are giving me- facts remain whether I like them or not. -Jeffy.
Jeffy 92 is offline
post #10 of 28 (permalink) Old 12-18-2008, 05:31 PM
ScottFraser2's Avatar
I was able to obtain the actual International 7.3l shop manual. In the last section of the book, it gives complete disassembly, inspection, and assembly instructions of the Stanadyne DB2. I decided to rebuild my original pump after my remanufactured injection pump gave me hard hot start problems. My original problem was a miss at over 1800 RPM. Turns out it was the advance piston that was scored up and worn into the aluminium housing after disassembly and inspection. So I tore my pump right down, cleaning each part one by one and putting the parts into a clean tub of fuel additive until ready to be put back together. I took my questionable parts to the local injection shop and they were able to fix me up. I bought a new oversize advance piston $30, had them hone my housing to accept the new piston ($10 labor) bought a complete seal kit $54, installed a new delivery valve $5, a new metering valve $25, a new cam for the external advance mechanism $35, I was going to buy a new governor flyweight thrust washer, but they told me just to flip it around to give a new surface for the flyweights to run on. Oh and for the $10 they charged me to hone the housing, they also installed my seals on the pump drive shaft because you need a special tool to do so. Once I had everything back together i took the pump assembly to the injection shop for calibration. They charged me .5 hr labour ($40) to calibrate. When i went to pick it up they asked if i wanted a job. The pump has been going strong for 10,000 kms now ! Best of all, it's the original pump to the truck! One heck of a learning experience.
1986 F-250 Supercab 2wd 6.9l T-19B 4 speed 200,000 kms (125000 miles) College teacher dropped it off at my house to have for FREE !
1990 F-350 XLT Lariat CC 4x4 SRW 7.3l, E4OD (Now ZF5 with Luk SMF), 3.55, 281000 kms (175000 miles) Paid $1300 01/05
1995 F-250 XL Supercab 4x4 7.3PSD ZF5 (Luk clutch/SMF) 3.55 265000 kms (164000 miles) Paid $6200 10/08
2005 E-150 XL 4.6l V8 60000 kms (37000 miles) Paid $15000 09/07
ScottFraser2 is offline
post #11 of 28 (permalink) Old 12-18-2008, 05:50 PM
My Photos: (27)
Hey good for you! That's what I'd call a cheap but GOOD pump overhaul. Most local inj shops I've been around were nice guys and easy to work with. Sounds like we have the same series manual.
LMJD is offline
post #12 of 28 (permalink) Old 12-18-2008, 08:14 PM
Yeah the manual I have is Part# CTS-4245G volume 2 Navistar truck service. But I want to make people aware that all injection shops might not give you the time of day to give advice/tips/hints....also I did this over a couple weeks as i was running the reman'd pump in my truck. I did take the pump back and they gave me another one on warranty...no refund...LOL its still in the box on the shelf in the garage, never been opened.
post #13 of 28 (permalink) Old 12-18-2008, 09:27 PM
The pump rebuild shop is on Ebay under Pensacola Fuel Injection Inc. 805-470-9408 Phillip Waters is who you will talk with. No core needed either and the shipping is free too. So for about @950.00 or less because they may have another special you can get a great pump. I have one now and its fine. Nothing more I can say.
icanfixall is offline
post #14 of 28 (permalink) Old 12-19-2008, 01:17 AM
Gary, uhm, what? 950.00? Pensacola Diesel pumps were like $290 online last time I checked...
M.L.S.C. is offline
post #15 of 28 (permalink) Old 12-19-2008, 01:26 AM
mm
pump info
this link explains DB2 pumps: Oliver Diesel - Engines & Outdoors here is an old 6.9 injection pump link: info for repairing injection pumps
1992 F250, 5 speed, extended cab, replaced 7.3 with 6.9 2-5-08 ...will be replaced with 94 7.3
DewEze round bale carrier
mm is offline
