Power source for fuel pump - Diesel Forum - TheDieselStop.com
Old 11-20-2009, 03:18 PM   #1 (permalink)
Looking thru my OEM manuals for a place to connect a 3-5 amp draw for a fuel pump, but getting frustrated....
1. where is a quick and easy to get at / down-n-dirty, ignition key-activated power source (so I can get running)?
2. what is the BEST way to get a power source (long-term solution)
For #1, I'm looking at the glow-plug controller (with an inline fuse)...
Thanx
1993 F350 XLT Crew Cab 4x4 factory turbo diesel, 5-spd, 4.10s w/towing package, bench seats (fits family), white paint, sprayed bedliner, "Rackit" lumber rack.
This was exactly the truck I was looking for...
now 327,000 miles & 8 yrs (bought with factory remanufactured engine @ 119K miles)
14.5 mpg @ 65 mph cruise control & AC
Casually looking for a good used (secondary) overdrive....
Real trucks don't have spark plugs!
-Guy-
Escondido, CA
GuyW is offline
Old 11-20-2009, 05:05 PM   #2 (permalink)
RWF350's Avatar
Get the main power from the solenoid on the passenger fender (with a fuse). I would use a bosch style relay ($6) and tap an accessory fuse in the fusebox for switch power. That will keep majority of the load off of the ignition switch. A little more work but worth it.
2007 Chevy 2500HD 4WD Ext Cab (late model) 6.0L (gas) 6speed auto
Deceased--1990 F350 2wd DRW Super Cab E4OD 7.3l IDI
Gooseneck hitch, Flowmaster (single inlet/dual out), 60 gal tank/toolbox/bedrails/headache rack (custom built, welded together as 1 unit), 3 gauge pillar pod w/glowshift gauges, oil, water temp, trans temp
Never ask "What else can go wrong?" cause something will.
RWF350 is offline
Old 11-21-2009, 02:24 AM   #3 (permalink)
rsr911's Avatar
Do like RWF350 suggested with the relay but rather than tap an accessory tap the wire to the IP fuel solenoid. This way the pump will run even while cranking. This is how I plan to set up mine in the future but I've heard it suggested here before. Right now I have my pump on it's own switch coming from the drivers side positive battery again so the pump runs while cranking. This insures the IP never has to pull a vacuum. Once I have mine on a relay I'm going to move the existing switch under the dash as an override in case of relay failure.
1986 F350 Crew Cab 2wd SRW. 1991 7.3 IDI, T-19 4spd Sterling 10.25 3.55, 12" HD clutch. A Banks waste gated turbo. 5" cut down Peterbilt stack. Midwest rebuilt IP turned up. AC Delco 6.5 GM 12V GP's, working great. Running W85 high performance zero-gel diesel! D60 front conversion, 4wd conversion, dually conversion, and steel flatbed conversion now underway. Man those frame rivets are a pain!
1966 Porsche 911. 1983 911 SC engine with modified Zenith carbs, headers, 911S brakes, custom fuel rails, MSD 6al box with timing computer, 1974 IROC body kit. 1850lbs, 200rwhp, total blast to drive.
rsr911 is offline
