Old 03-06-2007, 06:16 PM   #1 (permalink)
Power steering and fuel lines
I should have made better note when I ripped everything apart, this is what happens when you have too many people helping you. On the steering box, which line is pressurized and which one is the return? Also the same for the fuel splitter valve on the frame, which one is suction and which is return? Thanks
1994 F-250 XLT Off Road 7.3L IDI Factory Turbo 5 spd Man. 410 gearing. Pump turned all the way up, 14 PSI Boost, 1250 degrees MAX. ATS Outlet/Downpipe upgrade with 4" system. 86,xxx miles.
Is Now CUMMINS Powered. '01 24v with HT Turbo, Injectors, TST Competition and Edge EZ, with FASS.
TurboIHPower is offline
Old 03-06-2007, 06:29 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: Power steering and fuel lines
The outlet port (return) is closest the steering column/input shaft. The inlet (pressure) is closest the four bolts where the valve housing joins the box.
Pm me an email addy and I will send you a pic of the FSvalve.....
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 03-06-2007, 09:32 PM   #3 (permalink)
The high pressure side of the steering pump will be hard line and the fitting will be flaired or o-ringed. The return lines are just hose clamps so its easy to tell which is which. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
icanfixall is offline
Old 03-06-2007, 11:11 PM   #4 (permalink)
Thanks. If I had the ford lines still on there it would be easy to hook back up. Im fabbing in a Cummins so I dont have anything to go by.
Old 03-06-2007, 11:44 PM   #5 (permalink)
Everyone above is correct, but if you ever have a doubt, put some fluid in the reservoir and turn the pump by hand in the direction of engine rotation.
Phillipmc1268 is offline
