Hello all! My pressure line from the powersteering pump to the steering gear is leaking at the inlet on the steering gear. I have a new steering gear, could the problem be with the line? I think its a flared fitting, so no o-ring.
__________________ '88 F250 Lariat extended cab ?10,XXXmi, C6 Auto, 3.55 rear, 16" Aluminum Summit Racing Rims, LT235/85R16 Bridgestone Duelers, Sony Xplod CD Reciever, Mostly OEM replacment parts, for now...Lovingly named "Brownie" simply because its brown and a sweet ride .
Could be a crack in the flared end of the Hpressure line....... 25 ftlbs torque
Check for a missing oring we discussed that at the shop today........fords had an oring.
Interesting new twist! After much debate with every partsstore in McDonough, I've found out by the P/N on the line that it was originally on a 460... I'm guessing I also have a 460 pump, because the line that was supposed to fit didn't come close. Are these pumps/lines interchangable between the big gassers and my old oilburner?
