i am installing an on board air system on my truck using hesuttons design.i have the comp. mounted.my ? is does anyone know where to get the double pully for the power steering pump to run the york comp?thanks robert
1989 ford f-250 4x4, new DAS remanufactured 7.3, zf 5 speed- 410 gears, 600.000 + miles,hypermax turbo+exhaust system, air lift air bags all the way around,luk single mass flywheel,york on board air compressor and tank,recaro leather bucket seats,spray on bed liner, holly red pump,coolent filter,gear vender,filtration solutions oil bypass filter,ford motorcraft glow plugs,mechanical gauges in the stock cluster, mean green starter,hypermax cowl air induction system,vormax fuel filter, grover air horns,evans coolant,baja block drains.
Pictures: http://photos.thedieselstop.com/show...1&si=robertleo
My E-350 4x4 is a Beach Vehicle. I would be interested in an onboard-air scheme. More info please?
AMMO
AMMODYTE(@>
'94 E-350 7.3L IDI/E40D 4wd conversion by QUIGLEY. "Star of Life" Ambulance (conversion by AEV). GVW 8400 # (without driver) Currently used as a beach vehicle and (Class B RV) camper. Those BILSTEIN RV shocks sure made a big difference!
285-75-R16 BFG T/A KO's on OEM factory (8 bolt) 7" rims. Dana 60 axles front & rear with 4:10 gears. Completely rebuilt JASPER engine installed, Winter 2005. Steel security screens under windows and American padlocks w/round hasps allow on-street parking. Towing mirrors. Independent cabin power (deep discharge) battery.
My serpentine belt should be 115" long, best replacement I can find is 114.5, which might work.
Is onboard air impossible with a serpentine belt? What about if I remove the A/C compressor?
AMMO
AMMODYTE(@>
what about if you take a single sheave pump pulley--and weld it to the front of your serp pulley--skip weld it at even spots so it doesnt go out of balance----- [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] some may tell you this wont hold---right--your welding on the od of the pulley--also--so you can get this off later on--take a hole saw-- 2 1/2 inch--and bore a hole in the exact center--again so it doesnt go off balance--this will be enough to get the puller thru to get a hold of the recess area---
contact kilby at onboardair.com he sells a serp/v-belt combo pully as well as many adapter brackets to adapt different pump to engines.. The pully is reasonably priced.. Ive got on on my jeep to run a 2nd alternator.
1989 S1600 ToyToter3000 - Uhaul Special, 7.3 IDI 5-Speed Spicer, Rear Air Ride, 4wheel disks
thanks all,my truck does have v-belts.the mustang pully may work i asked the guy at auto zone and he said the pumps are pretty much the same although he didnt have a mustang pump in stock to compare.i did send hesutton a personal message no reponse as of yet.there arent many junk yards where i live.the serpantain belt could probably be made to work just would take some trail and error.i would not forfit your a/c there is some room there in that spot to work with.i will try to bring back the orginal post for the ones who havent read it.the measurements seem to be spot on and is drawn up very well........robert
Got the PM. The pully was actually on the truck when I bought it. I pretty sure the PS pump is used on lots of applications. Might be able to grap one off some other Ford. Like stated above, check local boneyards, autoparts, or even Ford.
As far as serp belts. It would work. I have a few part numbers for serp pulleys for the York compressors. I've seen the combo v-belt/serp. pulleys. Probally work just as well and you won't need such a long serp. belt. to turn the York.
Photo's in my gallery of the York. I plan on doing an article one of these days when I have more time off of work.
Heath
__________________ 1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
I have the combo serp/vbelt pully from Kilby at onboardair.com.
It replaces your ALTERNATOR pulley and your compressor mounts next to the alternator.
If you're going to drive the compressor off of the power steering pump, the kilby/onboardair.com pully will NOT work for you as it's not made to work on the PS pump (too small a serp diameter).
For alternator drive: Do not order the Kilby overdrive pully as its' serp diameter is much too small. I ordered the O/D one first and had to send it back. Just order the standard pully and it will still overdrive your alternator (and give you more juice at idle) as it is a slightly smaller then stock diameter.
