power steering shaft seal leaking... now what? - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 12-16-2010, 10:38 PM Thread Starter
lexxxel's Avatar
I've got a power steering fluid leak at the bottom of the steering shaft where it goes into the steering box... at the seal. What can I do to fix this? Does the steering box need to come off and be rebuilt? Or can just the seal be replaced while it's still on the truck. The steering box is mechanically good, seems a lot of work to remove/rebuild it just to fix a leaking seal...
Advice appreciated. thanks
'91 F-250 7.3idi XLT Lariat Supercab
Non-Turbo, Bone Stock
E4OD 4x2 4.10 non-posi
6 digit odometer
122,000 miles (197,000km)
still Minty Fresh
Sold my old 90 reg cab @340,000 miles (550,000km)
Still running I'm sure...
lexxxel is offline
post #2 of 18 (permalink) Old 12-16-2010, 10:59 PM
86ford69's Avatar
I would also like info on this. Mine started leaking about a month ago. I really done feel like pulling the whole thing to fix it. Also mine is leaking at the bottom where the pitman arm hooks up.
IRAQ WAR VET. 3 YRS SERVICE AND 18 MONTHS IN THE SAND. R.I.P ALL MY ARMY BROTHERS WHO DIDNT MAKE IT BACK. ROCK OF THE MARNE 3ID 3BD HHC 1 15th MECH INF. Old blue. 1986 F250 Xlt larait. Supercab long bed. 4x4 6.9 N/A. 4 speed with granny. No soup bowl. Sunpro 3 gauge pod for water, voltage and oil pressure. Push button glow plug control with Kenworth dash light as glow plug light. AC 60g glow plug conversion. No more burnt up gps. Dana 50 TTB and sterling 10.25 with4.10 gears and limited slip. Custom 5 inch stack from a JohnDeere Tractor and custom push bar/ grill guard. 33 12.50 16.5 Wild Country radail rvts in the rear and brand new BFG All terrains TA KO`s in the front. Shes a beast son. Wish list. New windsheild. New tach and speedo. New paint that matches. Proud BOOB man.
86ford69 is offline
post #3 of 18 (permalink) Old 12-16-2010, 11:13 PM
rsr911's Avatar
The box has to come off and be partially disassembled to replace the bottom shaft seal. Definitely not a fun job, I did it last winter on my van. The van leaked so bad that it would blow through a quart in 5 miles. I seem to recall I got the seal at Azone or Napa.
1986 F350 Crew Cab 4wd DRW conversion. 1993 7.3 IDI, 5spd Sterling 10.25 4.10 rear, kingpin D60 4.10 front, 12" HD clutch. A Banks waste gated turbo. Midwest rebuilt IP turned up. AC Delco 6.5 GM 12V GP's, working great. Running W80-W85 high performance zero-gel black diesel! 4wd and dually conversion is done. Washer mod on the D60 kingpins eliminated the death wobble. Custom 10" C-channel front bumper with military D-rings front and rear. Pintle hitch, receiver hitch, and goose neck hitch. 7800lbs full of fuel....
rsr911 is offline
post #4 of 18 (permalink) Old 12-16-2010, 11:31 PM Thread Starter
lexxxel's Avatar
uggg... exactly what I didn't want to hear
I'm driving the truck 800 miles at xmas... hoping the leak doesn't get really bad bc I can't fix it before I go if it has to come off to be done. Right now it's dripping but just a little stain on the driveway after driving it... altho I guess you never know how long it'll take to get real bad
crap.
6 digit odometer
still Minty Fresh
lexxxel is offline
post #5 of 18 (permalink) Old 12-17-2010, 06:11 AM
My Photos: (27)
The lower (sector shaft) seal can be replaced without removing the steering gear. Upper seal, the gearbox has to be removed.
LMJD is offline
post #6 of 18 (permalink) Old 12-17-2010, 07:29 PM Thread Starter
lexxxel's Avatar
is the lower one the one that the steering wheel shaft goes into? Because that's where it's leaking....
6 digit odometer
still Minty Fresh
lexxxel is offline
post #7 of 18 (permalink) Old 12-18-2010, 07:55 AM
no,as lm said--the lower can be replaced,,without,removing the box..remove the steer arm[puller], take out the lower snap ring,start truck..take wheel all the way left or right,then snap hit the steer wheel against the stop--pressure will spike in the system,,and SHOULD blow the seals out--have someone watching,so you shut truck off,as soon as seals pop loose..replace------now the top one,,remove the long shaft from the input of the box--slid the two pieces together to get away from box. pry out the outside dust seal,remove the inner snap ring,and hit the steer wheel against the stops with truck running,, to blow this seal loose also--replace--
94_turbo is offline
post #8 of 18 (permalink) Old 12-18-2010, 10:47 PM Thread Starter
lexxxel's Avatar
so it sounds like you're saying the steering box can stay on the truck?
I'm confused here...
6 digit odometer
still Minty Fresh
lexxxel is offline
post #9 of 18 (permalink) Old 12-18-2010, 11:03 PM
My Photos: (10)
What about throwing some Lucas Power Steering Stop Leak in it? At least that will take care of it until you're ready to really fix it. That stuff works.
92 F350 XLT Crewcab dually, 225K miles ATS turbo, 4 inch exhaust, fresh IP & new matched BB injectors, Holly Red pump, K&N, E40D, 2 aux coolers, A-pillar guages, 410 limited-slip rear, Rancho 9000s, towing package, full running boards, mud flaps, 94' Ford (Alcoa) aluminum wheels, Predator camper shell, 600 watts of Sony/Boston Acoustics! Complete engine rebuild at 176k miles. Ford reman E4OD at 204k miles.
2001 Komfort 26FS
Fozz is offline
post #10 of 18 (permalink) Old 12-19-2010, 01:16 AM
Kevin 007's Avatar
Yeah I second that!
1984 F-250 6.9, T-19, BW1345, BB code injectors, low mileage, manual Beru Glow Plugs, D70 rear end. solid truck.
1985 Toyota Landcruiser BJ60, 5 bearing cam 3B 4cyl diesel, H55F trans. Best rig I have ever owned.
1981 Honda Trail 110.
Kevin 007 is offline
post #11 of 18 (permalink) Old 12-19-2010, 07:56 AM
My Photos: (27)
The bottom seal can be easily changed from underneath the pickup with out removing the gearbox. The top one (upper seal that the steering shaft goes into) is next to impossible to lean over the fender, reach down that far and remove and replace. Best option's remove the gearbox for that one.
LMJD is offline
post #12 of 18 (permalink) Old 12-19-2010, 10:39 PM Thread Starter
lexxxel's Avatar
I think I'll take some stop leak along for the long trip...
Then when I have time to do the fix, I'll probably have the steering box rebuilt at the same time. Why not when it's off the truck anyway... I know a good rebuilder around here... after going thru 3 boxes on my last truck
Thanks guys
6 digit odometer
still Minty Fresh
lexxxel is offline
post #13 of 18 (permalink) Old 12-20-2010, 07:03 AM
drinkypoo's Avatar
My Photos: (25)
I think the long-term answer is to pull one from a yard and rebuild it. Then you get to have the experience of fixing it, and have a spare.
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #14 of 18 (permalink) Old 12-20-2010, 02:31 PM Thread Starter
lexxxel's Avatar
I got one from the wreckers for my last truck and had it rebuilt... put it on the truck and it was tight when you turned the wheel one way. The rebuild sucked. After 6 months it was leaking everywhere.
I finally found a place that did a decent job. I guess if you just clean it up and replace the seals, some places call that a rebuild. Because it's such a pain to get on and off, doing it just once would be nice.
I've decided to pull the box and replace just the two seals for now. Nothing wrong with it otherwise, and I don't have the time right now to be down for a week. Would have been nice to wait till I had time for a full overhaul, because I'd like to replace the steering shaft too, apparently there's a bushing in it that wears out... my steering is a little looser than I'd like, but right now I just don't have the time (or the parts)
6 digit odometer
still Minty Fresh
lexxxel is offline
post #15 of 18 (permalink) Old 12-28-2010, 12:40 AM Thread Starter
lexxxel's Avatar
ok.. any tips on how to remove the seal with the box off the truck? I pried the crap out of the upper seal to get it out... bent it all to crap... is there a better way?
6 digit odometer
still Minty Fresh
lexxxel is offline
