Old 05-25-2007, 11:46 AM   #1 (permalink)
Powershot 2000
I have heard that the powershot 2000 propane system will work on the 7.3 IDI's. Is this true. I see them advertised for the powerstrokes so I was wondering it plugs in electronically to the powerstrokes at all, or if it is all mechanical hook up that can easily be done on an IDI. I have found a used system that is said to work fine, but I don't want to buy it if i am not sure it will work. [img]/ubbthreads/images/graemlins/shrug.gif[/img] I heard that propane makes an incredible difference in performance when used correctly. So does anyone know how much an estimated power increase would be?
1989 F-350 crew cab dually 4x4 7.3 IDI, Banks Sidewinder Wastegated Turbo. Rebuilt E4OD with Transcommand. push button start, 5" straight piped dual bullhorn stacks. New body work and paint. Custom diamond plate interior. Custom built front and rear HEAVY DUTY bumpers, Many Many Mods on the way. Just need more money and time. [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img] fuzzy dice hangin from the mirrior
1990 F-350 Crew Cab SRW 7.3 IDI with ATS turbo. Offroad wheels and tires. E4OD. custom exhaust and turned up pump. New bed and paint.
2001 Custom F-1150 (f-800 w/ f-350) crew cab pickup. "Big Red". 3208 turbo Cat w/ Allison auto. DVD, Navigatin, 6 disc cd changer. back up camera. 22.5 alcoas. dual 150 gallon tanks.
1979 Ford F-250 4x4 Highboy regular cab long bed. 351M 4 speed. Engine, drivetrain, and other upgrageds coming SOON! bought 11-25-07
2008 Mustang warrior edition convertible. FAST!! and 2000 Eddie Bauer Expedition 4x4 5.4 Triton
6 other IDI work trucks and 1 Powerstroke. all with plows and 4x4
ThomasBrooks is offline
Old 05-25-2007, 02:09 PM   #2 (permalink)
Re: Powershot 2000
The powershot will give your IDI motor about 350 more hp... [img]/ubbthreads/images/graemlins/eek.gif[/img] Not really but it sure does wake up these motors. Several members have made their own systems that work very well and are cheaper that the powershot 2000 ayatems. I really think the water-methonel injection system (window washer fluid) is a better system and the "fuel" is cheaper.... [img]/ubbthreads/images/graemlins/grin.gif[/img]
icanfixall is offline
Old 05-25-2007, 02:28 PM   #3 (permalink)
Re: Powershot 2000
I still am a little worried about putting in one of the h2o kits because I am not sure its a good thing to spray water into a hot engine. I don't want to deal with any cracks. Can anyone convince me otherwise?
Jimmy C.
89 F350 7.3 IDI Diesel, 110,000 miles, Black and silver, single cab long. 4x4 XLT Lariat. 5 Speed Manual, very clean truck. Banks sidewinder kit, 4" dual stainless magnaflow exhaust, 4" skyjacker suspension kit with rear add leafs. Chrome Pro Comp wheels, 35" Pro Comp Mud Terrains.
JCDiesel89 is offline
Old 05-26-2007, 09:26 PM   #4 (permalink)
Swervin's Avatar
Re: Powershot 2000
I have had this system for the past 4 years on my truck, and it does just what I had hoped it would. I would say that that there is about a 50 hp gain under load, it really does make for an engine that comes alive.
One of the best features is the proportional to boost pressure system which gives you the most propane when you have the highest need. But the best feature, when I compared this system to the others on the market when I bought, were it's safety features.
My system has been trouble free.....
89 Ford F250 SC 5 sp 429,100kms, rebuilt drop in at 385,600kms, new clutch and flywheel, Powershot2000 propane, rebuilt ATS Turbo, 4" exhaust with Dynaflow muffler, full Amsoil with single Amsoil bypass filtration, Pioneer DEH-P470 deck and 10" sub with 250 watt amp!!!
Truck and Trailer
Swervin is offline
Old 05-28-2007, 08:22 PM   #5 (permalink)
Re: Powershot 2000
My dad is worried that the extra power from a propane kit will burn up the E4OD. I just had it rebuilt about 3,000 miles ago and it is in fact in the shop right now getting a leak fixed and seeing why it doesn't shift properly. So, the transmission will be "like new". It has a shift kit and a Banks transcommand. Is this anything I should be worried about?
Old 05-29-2007, 11:14 AM   #6 (permalink)
Re: Powershot 2000
there is also a bullydog propane kit it says it works for these trucks and it gives 80 hp anyone have this?
1993 F-350 dually 7.3 IDI non turbo
All Stock, if you wanna give me some money to change that its cool
The only guy in high school with a diesel
chrisbigrig350 is offline
Old 05-30-2007, 04:59 PM   #7 (permalink)
My Photos: (23)
Re: Powershot 2000
The E4OD's problems are not mechanical from what I understand, it's all in the electronic valving that is the issue, so extra HP into it doesn't make any difference. Besides, they put those behind the powerstrokes, so they know how to take the extra HP. As for water injection, your not putting enough in to actually cool the metal. It turns to steam and cools the air charge. No risk of cracking if used in proper amounts and is atomized properly, but many avoid it due to the infamous story of Travis and the Enterprise.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 06-02-2007, 01:05 PM   #8 (permalink)
ndh
Re: Powershot 2000
can someone re-post or tell this infamous story?
1994 F-250 XLT 4x4, Xtra-cab, longbed, IDI factory turbo, ZF5, 4.10.....126k miles
turbo temp monitor
ndh is offline
