Old 10-07-2005, 11:56 PM   #1 (permalink)
price of new motor
I have a 93 turbo idi with 230k and would like to know how much a new or rebuilt motor will cost me?
93' factory turbo zf5 extra cab 230k 4x4 straight 3" pipe slight tweaking on pump c5 axle code k-n air filter pillar mounted pyro
eken4570 is offline
Old 10-08-2005, 12:13 AM   #2 (permalink)
My Photos: (5)
Re: price of new motor
You can get a price on-line here
1991 Ford PL Custom Ambulance Type III 7.3L Diesel. Photo Here Pioneer AM/FM/XM/CD Stereo. Code 3 lightbar, Whelen Strobes and flasher lights. Whelen flood lights on front, rear and sides. There bright enough to turn darkness into daylight. Siren with several tones plus electronic airhorn and PA. Custom 3" exhaust from manifolds back with a Gibson Superflow Muffler [img]/ubbthreads/images/graemlins/grin.gif[/img]. Dual alternators and dual sets of batteries. If I need a jumpstart all I do is push a button. On spot tire chains that install and de-install themselves at the flip of a switch. Also has air compressor on board along with suction unit and O2 system.
1972 Cadillac Hightop Ambulance by Superior Lucky if I get 10MPG
CompuDoc is offline
Old 10-08-2005, 12:34 AM   #3 (permalink)
Whoa!I would stay clear of Jasper.Several have had bad experiances with their IDI rebuilds.EZ will chime in on his.Plus,if you have a problem they like to twiddle their thumbs till the warrantee is up then your stuck with the thing.DAS get constant thumbs up.They are expensive but they don't skimp. DAS
IDI Till I Die!!!
NCC-1701UAV U.S.S. Enterprise -1991 F350 CC dually.Lighted heated west coast mirrors,Nathan Airchime K3HA air horns,attitude from hell itself!
1994 F350 Crew Cab Dually,7.3 IDI turbo-Currently in the Roundhouse awaiting 10 year overhaul. White Lightning
1971 M35A2 deuce and a half.6wheel drive,Power Nothing!125 Horses in a 13,000lb truck.Real get up and go power! Martyr Machine
Cousteau 2006 Ranger STX-3.0 V6,5spd handshaker,standard cab
m35a2 is offline
Old 10-08-2005, 04:58 AM   #4 (permalink)
http://www.shopdiesel.com/reman_engs.html http://shop.ivalueinternet.com/DropI...ory_id/164.htm for this one click on Gold Silver or Bronze >>> http://dieselautoservices.com/ford.html http://www.diesel-engine-parts.com/sitemap.html
HERE is a good site with info http://www.intellidog.com/dieselmann/idi.htm
specs for IDI http://www.thedieselstop.com/faq/949...q/engcomp.php3
92 F 250 Ext Cab Long Bed 2WD 5-Sd , All stock "for now" 60 Gal tank in bed for burning used cooking oil , If you smell frys you might be behind me.
93whitetiger is offline
Old 10-08-2005, 10:15 AM   #5 (permalink)
I am one who will pipe up. Call DAS! I love mine. I spent about $6000 for a complete drop in unit. They are in Canada so the exchange rate changes the prices. And that was a few years, and many many miles ago with no issues. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
1990 F-350 Dually 4X4 CC Rebuilt Turbo and NEW 7.3L DAS engine, rebuilt rear diff, Reman E4OD Stage 1 injectors Stage 1 pump Baumann recal kit and TDC for E4OD dead trans again...
2004 F-350 4X4 CC 6.0 PSD
2004 Wilderness 320dbhs TT
DSBlack is offline
Old 10-08-2005, 09:57 PM   #6 (permalink)
You could Go To Cummins Then go to FordCummins .
CJ
The wife's truck: 1994 F350 Super Cab XLT 7.3 Diesel, was E4OD auto now ZF5 manual (See conversion notes)
See also(ZF5 Wiring)
My truck: 1990 Dodge D250 5.9 Cummins, Getrag 360 manual, Tweeked pump, straight pipes
Ceejmo is offline
Old 10-08-2005, 10:52 PM   #7 (permalink)
My Photos: (24)
Wherever you get try it not to be a Jasper. I spended more money and time than I expected with this engine and it is not even my daily driver. [img]/ubbthreads/images/graemlins/mad.gif[/img]
- 12/92 f350 jasper 7.3L 17k Torito
- Home made exekiel propane system, sweet
- Home made ram-air system
- 4.10 open, DRW
- zf5 trans (dextron and militec); 12" luk solid fly wheel and clutch set.
- exekiel coolant filter system (Fleet-guard filter and dca)
- ip runing with stanadyne every tank and Mels timed.
- Agnem manual tranns starting system :-)
- Hypermax turbocharger system YES Finally. Turned up a la Travis.
crew cab/ wood interiors/ 800w cd player. Sweet ;-)
2 new diamond headlights
4 100w flash lights and 2 withe fog lights
more pics
BOOB Man
soon..
- paint job.
exekiel69 is offline
Old 10-09-2005, 07:57 PM   #8 (permalink)
Then come to my site for tips on installing and using your Cummins. I think you'll find lots of helpful info there if you decide to go that route.
Linky: http://www.cummins-conversion.com
Mike
- SOLD: 1991 F-350 XLT crewcab, dually. BTS E4OD. My favorite truck.
- NEW DAILY DRIVER: 2006 Ram 3500 SLT quad cab. 5.9L Cummins, 6-speed manual transmission, nav system, Jake brake. No mods, now or ever. 100% satisfied.
Mike Lewis is offline
Old 10-09-2005, 09:37 PM   #9 (permalink)
why get rid of it just because it has 230k? i have a 93' non turbo with 207k and i expect to get a half million miles or even more before i rebuild but i am seriously considering swapping it for a powerstroke engine
01 Dodge Ram 3500 4x4 DRW SLT 24V Turbo Cummins.
Digital Gauges.Boost & Pyro.
-Aurora Twins,Exhaust Brakes,Performance Head,
Step 8 BullyBooster Injectors,Edge Comp Plug-In Module.
Odometer:401K
'02 Dodge Quad Cab.24V Turbo Cummins.6 Speed.
Stock.
Odometer:100k
'93 F350 4X4 XLT CREW 7.3 N/A.3.55 Gears.
-Odometer:341K
'99 Peterbilt 379 Ex.Hood.Flat Top.550 CAT 18 Speed,8" Straights
odometer:521k
tall_green is offline
Old 10-10-2005, 12:26 AM   #10 (permalink)
230k?!?! That thing's just gettin' broke in! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
'92 F-250 XLT Super Cab, 7.3 IDI non-turbo, E4OD Tranny, 4.10 gears, Mocha, 200,000+
'99 Crown Vic P-71 Interceptor
Hangfire is offline
Old 10-11-2005, 10:40 AM   #11 (permalink)
230K? I have 260K on two different 7.3's in E350 vans. No problems with either one.
Remember, these are Medium Duty International truck engines, not the car engines that Ford used as truck gassers (302, 351, 460). Now the 300 I6, that was a purpose built truck motor.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 10-11-2005, 12:45 PM   #12 (permalink)
actually,the 300 I6 was a tractor engine put in a truck.....made to run LONG hours tugging and pulling.
IDI Till I Die!!!
m35a2 is offline
Old 10-11-2005, 03:21 PM   #13 (permalink)
if you are going to install a crate motor, i would really recomend a Reviva mmotor. they were building them for International for years and were marked as Dealers Deisel. i have been installing them for years without one issue. well maybe one, still have no idea why i have low oil pressure on my 7.3l with 130k miles. they are a good motor with an excellent warranty.
huskyhauler is offline
Old 10-11-2005, 10:37 PM   #14 (permalink)
Yeah... my cousin has a '94 F-150 with a 300 I-6 that would walk away from my '91 with a 302 pulling a slightly lighter load.
I wouldn't mind having one of those good old I-6s... nothing but good things to say about them.
Old 10-12-2005, 01:26 PM   #15 (permalink)
day late and a dollar short mike.
I just sold mine for $1,200.
only had 156,000miles on it, alotta new stuff. was an '88 F150 with a c6.
Great truck. I never touched the engine... never even took the valve covers off it (talk about low mantainance)
'89 F250 7.3 IDI, c6, 3.55rear, 2wd, 152k miles
DeepRoots is offline
