Old 04-10-2005, 02:36 PM   #1 (permalink)
Willie's Avatar
Propane Installed at last , three more questions......
Firstly, thanks to all who have shared ideas and advice with me as I made up my own propane injection system. The job is now done and seems to work well. I put the system in to help pull my 6,000 lbs 5th wheel TT. Currently I have no mountains nearby to test the system in real life application so I have set the secondary regulator at about 2 lbs.for now. It only will activate at WOT unless I press my manual activation switch. I am wondering what do you have your regulator set at [img]/ubbthreads/images/graemlins/shrug.gif[/img], and what happens if you increase it and is that a static pressure reading or under flow conditions ???
PS : My Pyro gauge is on order [img]/ubbthreads/images/graemlins/smile.gif[/img]
Thanks again
Bob
My Pictures
1984 Bronco II 4x4 day to day driver : Winter
2005 Explorer Sportrac 4x4 day to day driver : Summer
1991 F350 / Crew cab , Engine 7.3,E4OD tranny. No Turbo but has propane and pyro gauge. The truck is American, complete with a Miles per Hour speedo. Digital trans. temp gauge and voltmeter. Front Captain seats. Control switches for DRL's , Fog lites, High speed idle, Engine kill and scene lites. On board " York " compressed air, Air horns and built in hose reel behind the rear seat. Power bar distribution box from a 1999 Ford Explorer . Checker plate running boards and Frieghtliner mud flaps. LED turn signals in the factory mirrors. DC to AC inverter to run the coffee maker <img src="/ubbthreads/images/graemlins/smile.gif" alt="" /> Soon to be updated with more toys as time & $$$ permit. <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Willie is offline
Old 04-11-2005, 10:59 AM   #2 (permalink)
Re: Propane Installed at last , three more questions......
I think most guys have there pane come on before WOT, but if thats how you want to do it, you might be able to turn it up a little more, you'll have to play with it, i believe at a certainly level you'll get kind of a pre-detonation sound and you don't want to go much farther, would you be able to go through your install on here with what parts you used and where you got them.
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
aaklingler is offline
Old 04-11-2005, 11:04 AM   #3 (permalink)
My Photos: (23)
Congrats! Did you retard your IP any, and if so to what?
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 04-11-2005, 12:31 PM   #4 (permalink)
Willie's Avatar
OK, make that 4 questions [img]/ubbthreads/images/graemlins/shrug.gif[/img] Should I be considering an IP adjustment ?? I have put up a few pictures in my gallery, most parts used were Canadian born items that I salvaged / bought from a local fellow who does propane fuel conversions on Taxis cabs etc..
Bob
My Pictures
Willie is offline
Old 04-11-2005, 05:01 PM   #5 (permalink)
My Photos: (24)
i got mine done too, but the regulator even they are 2 they are not that ease to regulate the flow. wath is the range on the ones you have? i wa thinking on geting one for 0-5 psi but places where is for sale they only sale to companies [img]/ubbthreads/images/graemlins/mad.gif[/img].
anybody know where to get a real accurate regulator?
and, is there any digital regulator that you can regulate from inside the vehicle?
thank you, exekiel
- 12/92 f350 jasper 7.3L 17k Torito
- Home made exekiel propane system, sweet
- Home made ram-air system
- 4.10 open, DRW
- zf5 trans (dextron and militec); 12" luk solid fly wheel and clutch set.
- exekiel coolant filter system (Fleet-guard filter and dca)
- ip runing with stanadyne every tank and Mels timed.
- Agnem manual tranns starting system :-)
- Hypermax turbocharger system YES Finally. Turned up a la Travis.
crew cab/ wood interiors/ 800w cd player. Sweet ;-)
2 new diamond headlights
4 100w flash lights and 2 withe fog lights
more pics
BOOB Man
soon..
- paint job.
exekiel69 is offline
Old 04-11-2005, 08:12 PM   #6 (permalink)
"and, is there any digital regulator that you can regulate from inside the vehicle?
thank you, exekiel
problem with an in cab regulator is that for the regulator to be inside you would have to run a high pressure(input) propane hose inside...unless you had an electronically controlled one connected by wire!?!?! i dont know if that exists! [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1989 F-250: supercab, long bed, 4x4, 5 speed,3.55's up front and rear, turned up pump,Pyro ofcourse!, custom stack, homemade lpg fumigation, more too come...At CSU, the black beauty is for sale...
nickbf2504x4 is offline
Old 04-11-2005, 08:46 PM   #7 (permalink)
My Photos: (24)
yes that is wath i meant, regulator under the hood and controller inside the cab.
anyway, do you guys know about a 0-5 psi regulator?
i founded some on this site but they only sale to lp companies [img]/ubbthreads/images/graemlins/bleh.gif[/img]
exekiel
- 4.10 open, DRW
more pics
BOOB Man
soon..
- paint job.
Old 04-11-2005, 08:56 PM   #8 (permalink)
Geezzzz.... I don't think I'd want THAT in MY cab!! No way!
- SOLD: 1991 F-350 XLT crewcab, dually. BTS E4OD. My favorite truck.
- NEW DAILY DRIVER: 2006 Ram 3500 SLT quad cab. 5.9L Cummins, 6-speed manual transmission, nav system, Jake brake. No mods, now or ever. 100% satisfied.
Mike Lewis is offline
Old 04-11-2005, 09:31 PM   #9 (permalink)
My Photos: (21)
I agree, especally if you are a Somker,... [img]/ubbthreads/images/graemlins/smokin.gif[/img]
I have mine set to activate at 3/4 throttle, maybee a little before. The first reg at the tank is set at 12 PSI, the second is set at 5PSI. I have a turbo so it will handle a little more LPG.
There are a lot of variables, like what size line, inpt nozzle, where it is inserted etc. You just need to experiment to see what works for you truck.
"Big Ed" Cummins Powered 1989 F-350 XLT Lariat, King Ranch, Crew Cab, 12V Cummins, PSD Intercooler, 4x4, C6, Gear Vendors, 4:10ls, Propane Injection, Hood Scoop, Air Compressor/Horns/Bags/Tank/Conditioning, 17x10" wheels, 35" BFG's, Dual 5" Sidepipes, Edlbrock Shocks, Dual Steering Stabilizers, Add a Leafs, Full Guages, Custom Counsol, CD, Amp, Sub, Rear Power Slider, Brushguard, Headache Rack, Spray in Bedliner, Diamond Plate, TCI Deep Trans Pan, Super Duty Cooler, and Aux Filter, Amsoil Dual Oil FIlters and Synthetics, Lots more,... check out the video,..
Click Here for Big Ed's "Extreme Truck Makeover" Video
DarrinTosh@gmail.com
Darrin Tosh is offline
Old 04-12-2005, 07:40 PM   #10 (permalink)
Willie's Avatar
RE :There are a lot of variables, like what size line, inpt nozzle, where it is inserted etc. You just need to experiment to see what works for you truck and how about an internal control regulator.
I guess a guy could put a longggggggggggggg piece of threaded rod into the final regulator top, mount the regulator sideways and put the rod through the firewall with some type of T handle. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
In my system I have used a slightly modified regulator from a travel trailer as my first regulator which brings tank pressure down to 10 psi after turning up the factory setting and plugging the relief vent [img]/ubbthreads/images/graemlins/biggrin.gif[/img] and then I am using a 400 lb input acetlyne ( spelling ?? ) regulator under the hood set at about 2 PSI static. but I have changed the internal spring to something a bit lighter which seems to make the adjusting easier. For a nozzle I am using a propane torch tip which I took off of an old " home handyman " plumbing torch.
Bob
My Pictures
Willie is offline
