Scotty, pushing the top of the pump towards the drivers side advances timing.
HUH???? Are you sure there partner... Think about which way the gears turn... Front standing in front of the grill.
Crank gear turns clockwise
Cam gear turns counter clockwise
then Injection pump gear turns clockwise. So if you tip the pump top towards the driver it's retarded because your following it's rotation but if you rotate the pump top towards the passenger you are advancing the timing...
Travis
Will Work For Diesel Fuel.
gotta agree with travis - towards the passenger side advances, drivers side retards.
Mojave Red: 1986 F-250XLT Lariat, Std. Cab, 4X4, D.A.S. 6.9 Turbo Upgrade(@160,000 miles), Banks Sidewinder, Updated Controller with 12V Constant Duty Glow Plugs, C-6 w/Gear Vendors OD, 4.10s, Holly Red fuel pump, AutoMeter Oil and Water Gauges, 38 gallon fuel tank in place of the spare, 195,500 miles
Gotcha, might goof around with it a little today since it has stopped raining, but it is a pain to get to the bottom nuts on the IP without the special wrench. Anyhow, what do you think about an 1/8 or so towards the pass side should get me where I want to be? I hate not having the correct tools for the job, but, I will just have to suffer until the wife clears me for some tool money. Scotty
Scotty,
With regards to the wrench. I just took and old long shaft boxed end wrench and put some heat to it till I got it where it was useful. It was just an old pos that I had layin 'round the tool box. Made life more simple but looks kinda funny.
Just my 0.02
Ron [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Goldie 1990 F-350 Custom 4x4 C/C DRW conversion. 7.3L Banks non-waste gated turbo, ZF-5 with 4" custom Exhaust complimenting a RDT venturi system, Autometer Pyro and boost 2 gauge pillarpod and your standard compliment of mechanical gauges. Clutch pedal Heim joint mod.
The Beef 1989 F-350 Lariat C/C DRW 7.3L N/A, ZF-5. Clutch pedal heim joint mod. Original price $500.00.
Currently slated for an extreme makeover ground up restoration.
Mater 2007 F-250 Lariat 4x4 6.9L IDI, T-19 trans pushing a 7'6" Western plow. Completely assembled from the tires up!
And if you don't have a torch handy, I took a trusty Craftsman wrench and hit with the grinder..thinned her out...til she fit nicely.
Now she stays in the side panel on the door for those 'speedy' adjustments when needed... [img]/ubbthreads/images/graemlins/eek.gif[/img]
Steve
1986 F350 6.9 IDI (w/Banks old style turbo )crew cab. 4x4, with 211,000 miles, ( may she rest in peace),<font color="blue"> NEW 7.3</font> w/Banks old style turbo, C6 trans. (4th one)<font color="red"> New Hughs convertor</font> ( [img]/ubbthreads/images/graemlins/smile.gif[/img] Lovin' it !)- Largest Perma Cool trans-cooler w/fan, G/V-Overdrive,<font color="red"> manual glow plugs,</font> homemade air intake with 4" alum. pipe w/12" K&N conical air filter, and RDT system routed to a Jaz 1 qt. breather tank. <font color="red"> Holley Red fuel pump,</font> w/fuel filter/water sep.combo and homemade water/treatment filter set-up (where the old fuel filter was), 433 gears with 35" BFG tires, 6" Rancho lift, 4" exhaust no muffler.
I may try that tomorrow, that bottom nut is a pain, I am waiting for the boys to tell me if retarding is towards pass side or drivers side. I am "almost" positive it is towards the pass side, but either way, I will try and figure it out. Scotty
Put a mark on the large brass adjustment fitting and a mark on the housing that is aligned with the one on the brass. Loosen the jamb nut and turn the large brass fitting 1/4" that will raise the cut in pressure about 2 psi. That may also help with the knock situation.
To retard timming, top of pump twoward drivers side, 1/16th of an inch is just under 4°, the thickness of the stamped line is just about 2°.
95" Extd Cab F250HD 4x4 DRW, /86"6.9 T19 GV o/d 3.73 axles, Hypermax Pulse turbo, intercooled / Modified Hypermax ram air induction, PowerShot 2000 LPG system "first design". Ride rites @ all 4 corners, Dana 50 mono Beam up front, Ford 10.5" in rear with 4 wheel disk brakes. Other Truck, 1983 IHC "S" with 14ton NoMar wrecker body, 30,000 GVW, 229"wb with a 340hp Detroit 6V92TA, Eaton 13spd RTO9513, 3.70 ring & pinion and LPG kit. Alcoa 22.5x8.25 with Michelin XVE 255x70x22.5
Huff, did you continue to operate your pump with the cold start solenoid controlling housing pressure for modified timing at the predetermined boost level? You had posted some numbers back a while ago, and I was curious if that had worked out or not?
Lorne
1990 F250 with 325oookm - ATS (non wasteGated kit ) on since 0km's / ZF / Single Cab Conversion to 6 seater keeps the family involved / Getting on, but running strong
For right now, I am going ot leave it where it is at, at least until I can narrow down if it is the HG's or not. If it is not the gaskets, I will retard it a bit more towards the drivers side and turn the propane back up. Right now, I ran the truck home on a large hill that usually required the truck to come out of OD and this time it wizzed up the hill, NO SWEAT, so pray for me fellers.. Scotty
Yep it still works great. I set the timming at 5° btdc @ 1400 rpm with power to the cold start solenoid then at 5psi of boost the hobs switch cuts power to the solenoid and the timming retards by 2° btdc no knock from the lpg, just smooth power.
Perhaps Huff, you should re-describe what you have done there, for the guys running reasonably high boost numbers, and also propane. Heck, I'm inclined to add the system to my engine, even without propane (I do reach 12lbs if pushed, but generally keep to lower levels these days as I forsee keeping her running as is till the game is over! Touch wood and all that.
I think some of us had questions whether the cold dump solenoid would handle being on all the time during low boost, but if it has worked this long (must be at least a year already?) then duty cycle must not be a factor.
Again, I think this simple little mod deserves more scrutiny and credit [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Lorne
The reason I did it was to relive some of the thermal dynamic stress on the engine. It might lose a couple hp (big deal) but the engine sure sounds and runs great. Even at 30° F the truck starts with just a ½ sec on the starter. It does idle a little slower (about 75rpm) for the first few minutes when cold.
