Pulling heads, do I need a hoist? - Diesel Forum - TheDieselStop.com
Old 11-16-2009, 12:22 PM   #1 (permalink)
A diesel mechanic friend offered to help me look into my truck and see why its getting such low compression. He is a stellar mechanic and will set things right.
I have a question for you guys though, to get at the pistons, I have to remove the heads, are they too heavy to remove by hand? The Haynes manual I have mentioned the use of a hoist. I don't know their exact weight. Should I rent a hoist? Im not the strongest guy in the world, but not the weakest. Is it something 2 people could do?
PS. Does anybody know of any good places to buy re-ring kits?
1993 F350 E40D 7.3 IDI 169k stock stock and more stock.
DieselDually1993 is offline
Old 11-16-2009, 01:13 PM   #2 (permalink)
chuckster57's Avatar
You might get away with removing them using two people, but I wouldn't try installing them without a hoist. Especially if the engine is still in the truck. Probably plenty of places to get re-ring kit. Jegs/ Summit/ dealer
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline
Old 11-16-2009, 06:10 PM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (109)
DD I would advise remove the engine and put it on a stand. Unless you like balancing on the fenders.......
Also remove the bolts in reverse # order by undoing 1/8th of a turn per round.......that is if you do not want the possibility of cracked heads
Proud Canadian BOOB man too!!
cdnsarguy is offline
