Push button starter - how big of a fuse? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 05-16-2009, 09:42 AM Thread Starter
dieseldirt's Avatar
I want to run a push button to my fender-mounted starter relay.
I will put one wire on the little ignition switch terminal on the relay and one wire on the starter terminal on the relay and run them both back to a heavy duty 60 amp push button.
Is this right?
I am wondering how big of an inline fuse / fusible link i should use and where i should put it on the circuit.
thanks.
'94 F350 RC/SRW 7.3 IDI Factory Turbo 4x4 ZF5 3.55 Dana 60 (auto hubs) 10.25" Sterling + Detroit TrueTrac. 33x1250x16.5 BFG. Hypermax Cowl Intake. Factory downpipe to 4" exhaust . Visteon radiator, Group 31 batteries, South Bend Clutch/SMF, DMI Hitch, Connex 3300HP, Wilson 1000, Uniden BCT8, gun rack, Western V-Plow. 228K
'97 F350 RC/DRW 7.3 PSD 4x4 E4OD 4.10 Dana 60 (manual hubs) 10.25" Sterling. Dump Body. L-pack toolboxes. 118k
Hot Work Saws- Husqvarna 385xp x2, 372xp, 346xp, Stihl ms660
Member NRA, AHBA
dieseldirt is offline
post #2 of 7 (permalink) Old 05-16-2009, 10:27 AM
EMD_Driver's Avatar
The only thing you will be energizing, is the relay itself. Personally, if I were doing this wiring job, I would use a 10A switch and 10A inline fuse.
2011 F250 3.31's 6.7
99 CC 4x4 auto 3.73s, with training wheels, former dog house, 6637 intake, RDT, 4" exhaust, evo tuner, a few gauges, '06 interior, '04 springs, '02 mirrors and shiny hubcaps
2007 Excel 30RKE fifth wheel
At work: 56 EMD GP9 16-567C 1750hp
EMD_Driver is offline
post #3 of 7 (permalink) Old 05-16-2009, 10:41 AM Thread Starter
dieseldirt's Avatar
Oh OK. That was partly why I was asking... i am just learning.
So I would've needed the big switch and BIG fuse if i was jumping the relay (hot terminal to starter terminal), right?
but since i am just doing the same thing the ignition switch does, and using the relay rather than jumping it, I only need the 10A switch and 10A fuse?
i think i get it now.
Member NRA, AHBA
post #4 of 7 (permalink) Old 05-16-2009, 10:49 AM
EMD_Driver's Avatar
Yeah... It doesn't take much juice, to power a relay..
post #5 of 7 (permalink) Old 05-16-2009, 03:16 PM
88beast's Avatar
u no those ricers you eat for breakfast? well lots of um got what you want it will even light up when you push it and it says "engine start" on it
pretty sweet i think
or id go with an old semi style one
but its got to be labeled if you disconnect the ignition switch part of it remember that (inspection law in some states)
88 f250 96 bed 95 front clip western mirrors and big ole bumper.
7.3 idi t70, 3g, g31,
other mods, oba, warn winch, big steel goodies including a headache rack etc.
check out my site at
88beast is offline
post #6 of 7 (permalink) Old 05-17-2009, 07:05 PM Thread Starter
dieseldirt's Avatar
yeah i am probably just going to put in a push button like on an older semi.
i know what you mean though those toggle switches with the little flip up cover on em....for that race car/fighter jet look.
..what i really want to do is replace my throttle pedal with one of those big ones out of a semi. how much of a pain do you think that will be?
Member NRA, AHBA
post #7 of 7 (permalink) Old 05-17-2009, 07:48 PM
RWF350's Avatar
On any wiring, never put a bigger fuse than the weakest component can handle. example: 60amp switch on 16 gauge wire with a 60 amp fuse, wire will probably melt before it pops a fuse. If in doubt on a fuse, bigger is NOT always better. And always put the fuse as close to source of power as possible. Popping a fuse is way better than burning a vehicle down.
RWF350 is offline
