Re: Putting A factory turbo on a 88 7.3 OIL LINE QUESTION
yep itl supply plenty of oil . that is one of the differences in the turbo block they have a 1/4 npt thread in the block and and natural asp has 1/8 . every aftermarket turbo is set up to use the i/8 . i personaly replaced mine with a stainless braided teflon line . got it from a place that makes hydraulic hoses .
94 f450 superduty, 7.3 idi, factory turbo, e4od trans, 5.13 gears, 14000lbs + across the scales every day of the week, 11'redding utility body, 3 cyl kubota diesel(tied in to truck cooling system)for air compressor , front bumper is 8"x8" square (air tank), 4 group 31s batteries mounted to frame under cab,2 straight stainless pipes pokin up in the air and no muffler(sounds great) now runnin on 100% wvo
2ND IDI
93 F250 XLT 2WD 7.3 IDI E4OD ALL STOCK MORRISON UTILITY BODY 10 horse yanmar diesel on the compressor, batteries relocated to under the the cab on the frame
