Old 11-17-2007, 01:27 PM   #1 (permalink)
question about crossmember difference
I was wondering if the crossmember for a 1994 f-350 with a 460 and a 5 speed behind it, will work for an 1994 IDI motor. what iam doing is with our dump truck iam ripping out the 460 and putting an idi in it.
thanks for your 2 cents
92 F-250 with luk clutch, got 304,000 miles out of old motor, now have IDI out of a 94 With factory turbo. Bought and installed ATS Exhuast housing, wastegate, downpipe. Turned up pump electric fuel pump. Runs like a bat out of hell.
andre7910 is offline
Old 11-17-2007, 02:12 PM   #2 (permalink)
88beast's Avatar
Re: question about crossmember difference
tranny may fit if you have a 5spd tranny but the engine on the idi is larger you could do a custom oilpan but may endup with coooling issues
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is offline
Old 11-17-2007, 03:20 PM   #3 (permalink)
The crossmember is the same. You have to change the motor mount towers. Many people have put an IDI in to gas trucks with no oilpan issues.
Keith
2000 F350 Cab/Chassis CrewCab 4x4 DRW 7.3/auto "Hamilton Custom Cruiser Conversion" WesternHauler Bed 50gal TFI transfer tank 4" turbo back Exh. DIY intake w/Napa 6637
'88 F350 CrewCab SRW 4x4 7.3/C6/4.10LS Banks non-wastegated turbo NAPA 6637 airfilter 4" lift Airlift rear airbags 107k miles
'86 F250 ext cab. 4x4 6.9/C6/3.55 arrowcraft dually conversion 45gal aft tank ?53k miles
'85 F350 Cab/Chassis DRW 55" Schwalbe Sleeper 7.3/T-19, 4.10, Banks Sidewinder wastegated Turbo Holley red tweaked inj.pump 6.2 governor and STACKS! The old 6.9 gave up after 445k miles.Stacked before stacks were cool since 5/85 **SOLD**
My Pics
'86 F350 Crewcab Dually 6.9/C-6/4.10 LS Racor seperator. 233k miles **SOLD**
'89 F350 Crewcab SRW 4x4 7.3/zf5/4.10LS 193k miles**SOLD**
85Hauler is offline
Old 11-18-2007, 12:30 AM   #4 (permalink)
thanks
Old 11-18-2007, 11:39 AM   #5 (permalink)
If your talking about the cross member under the transmission there are several different ones. I changed from a C6 to a ZF5 and had to modify a different cross member. Check with your friendly local salvage yards.
1988 F250 7.3 diesel 4x4 auto C6 now ZF5
1990 F250 7.3 diesel 4x4 auto E4OD. now ZF5
1992 F250 7.3 diesel 4x4 ZF5
Greg77 is offline
Old 11-18-2007, 12:12 PM   #6 (permalink)
We are talking 5 speed to 5 speed here. The crossmember should be the same, after all it is the "same" transmission.
Now that is assuming that you have a ZF-5 with the IDI engine. The 460 transmission has a different bolt pattern and will not directly bolt up to the IDI. I believe some folks have re-drilled the 460 bellhousing to work with an IDI.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
