Old 03-20-2008, 06:26 AM   #1 (permalink)
ltaylor's Avatar
question for anyone with turbo knowledge
i rebuilt my own to4E, first time ever playing with a turbo. After I run the truck a while i get oil running out of my exhaust. no smoke, just oil, is there a seal i forgot to put in? or should i look further into the motor.( I think it would smoke like a freight train if the oil was coming out of the motor). thanks for any thoughts.
2001 Excursion Limited, 4x4, toreador red, 4" turbo back exhaust, DYI Tymar intake
92 F350 CC SRW,7.3 E4OD 4x4
4" lift 35" tires, 4.10, 4" exhaust straight pipe,
ATS nwg turbo, rebuilt and balanced, holley red, new IP & injectors, rebuilt heads by me
A pillar triple pod, auto meter phantom gauges,
pyrometer, boost, trans temp, oil pressure & water temp
future upgrades
formerly known as; pullmyfinger
http://community.webshots.com/user/pullmyfinger76
ltaylor is offline
Old 03-20-2008, 12:08 PM   #2 (permalink)
Did you mark the position of your compressor wheel relative to the shaft before you disassembled the turbo?
If not, then it's now out of balance and that's why it's leaking. I know this because I made the same mistake on a 57 trim T04E that I was putting some new bearings in (got a bit hasty with the disassembly).
You'll want to have it professionally rebalanced, costs about $100. I had mine done by a place called gpop's turbo shop, they have a pretty quick turnaround. Look them up on google.
I do find it odd, though, that you have oil running into your exhaust and it isn't burning off...
'94 F250 XLT- IDI Turbo, 5 speed, 4x4, manual hubs. ATS upgrade, 3" downpipe, 4" exhaust. Autometer pyrometer & boost gauges. More coming.
'87 Thunderbird Turbo Coupe
Lots of mods & pretty quick.
ghunt is offline
Old 03-20-2008, 01:35 PM   #3 (permalink)
and if you have THAT much oil coming out--u best fix it N O W cause the next thing your going to have is a runaway engine--surprised it didnt happen already---ive been there--not funny!!!!!!!!!!
94_turbo is offline
Old 03-20-2008, 04:31 PM   #4 (permalink)
ltaylor's Avatar
I had the assembly balanced, put all back together with all lines marked inline. There is no oil in the intake side, nor does the engine smoke. Thanks for the help.
future upgrades
ltaylor is offline
Old 03-22-2008, 08:30 AM   #5 (permalink)
I had the same symptoms when I installed my turbo. It turned out to be my CDR was not venting and causing pressure in the turbo pedestal and the back pressure caused oil to flow over the exhaust impeller into tailpipe. No oil on compressor side. Mine was so bad it was dripping but only smoked if you revved it up.
Hope this helps.
Try this chart
Turbocharger Failure Analysis Chart
gnathv is offline
Old 03-22-2008, 09:02 AM   #6 (permalink)
ltaylor's Avatar
thanks for the info. i will check into this.
future upgrades
ltaylor is offline
Old 03-22-2008, 04:48 PM   #7 (permalink)
You replaced the oil seal, yes?
Any idea what direction the gap in the seal is oriented?
ghunt is offline
Old 03-24-2008, 05:33 PM   #8 (permalink)
brahamfireman's Avatar
Hope this helps.
Try this chart
ditto to the CDR, had a vent pipe on a PSD plug once and did the same thing, except he had stacks and the whole box sides wer covered in oil.
Diesel Rod
Formerly Diesel Rod.
A '97 F250 with 295K miles, 90 LED's and 5" stacks, among other things....
A '96 F250 Reg cab with 210K miles, Needs to go away. PM me.
'86 359 Peterbilt SHORT HOOD. The ongoing "project" it aint pretty but its got a 425 air to air Cat motor .....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
