Old 12-19-2005, 12:21 PM   #1 (permalink)
My Photos: (15)
RABS - Sinking Brake Pedal - Hyro Boost?
I was just curious if any of those with the sinking brake pedal issues have investigated the RABS valve? After seeing all the posts about the hydro boost conversion I have been thinking about the situation and it seems like anything messing around with the fluid flow to the rear wheels, if malfunctioning could cause all kinds of strange effects on the pedal.
Anyone scrapped the RABS? Since when does a 1 ton truck need the rear anti-lock anyway? Any stories of having your ass saved by RABS? [img]/ubbthreads/images/graemlins/eek.gif[/img]
Mike
89' F350 Crew Cab 4x4 E40D 4.10:1 Early Banks Turbo No More Trans Command - Transgo "TUGGER" 5" Stacks Bronco 33gal Tank
Runboys Pics
Runboy is offline
Old 12-19-2005, 12:35 PM   #2 (permalink)
Re: RABS - Sinking Brake Pedal - Hyro Boost?
Sure. Some members have bypassed the rabs. But here in So Ca if you did and were envolved in a traffic accident... Well you would be found at falt because you 'modified' your braking system by removing a safety feature. Not good. If your peddle is sinking when you are at a complete stop do this. Set the e-brake while stopped and then push down on the brake peddle. If it is a high peddle and the e-brake sets high the problem is the master or the rabs because fluid is leaking past somewhere. If the peddle is low usually the its the rear brakes adjustment being way out. The automatic rear adjusters really don't work very well. Hopefully all you need to do is adjust the rears manually and that it. The rabs unit is very costly. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
icanfixall is offline
Old 12-19-2005, 01:43 PM   #3 (permalink)
My Photos: (15)
I wonder what the legallities are on an older "custom built" truck that never had RABS and has been converted in some way. What if you had improved the brake system in some way - rear discs etc.?
This world is way to full of legal B.S. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Mike
Runboys Pics
Runboy is offline
Old 12-19-2005, 06:31 PM   #4 (permalink)
RABS ain't legal BS, it's a rational safety feature - especially with disc front & drum rears (the 2 types have different operating characteristics.
I had an old truck that on wet pavement would lock the rear and spin around to back-first (if I kept the brakes locked)....totally uncontrollable....
1993 F350 XLT Crew Cab 4x4 factory turbo diesel, 5-spd, 4.10s w/towing package, bench seats (fits family), white paint, sprayed bedliner, "Rackit" lumber rack.
This was exactly the truck I was looking for...
now 282,000 miles & 6 yrs (factory reman engine @ 119K miles)
14.5 mpg @ 65 mph cruise control & AC
Casually looking for a good used overdrive....
Real trucks don't have spark plugs!
-Guy-
Escondido, CA
GuyW is offline
