Old 03-14-2006, 11:43 PM   #1 (permalink)
radiator core support
okay guys and gals, i have been trying to restore this 94 IDI turbo and i have ran in to a problem and i was wondering if anyone had the same problem or might know why? i have ordered 4 supports for this diesel and none of them are the same as mine or even close? did ford make some speical trucks for companies?? i have now decided to take it to a machine shop and have a support made, i know my radiator is massive it has to slots on the side the sit on pins or dowels stiking out of the side of the support and the radiator is about 5 inches thick, the support from the frame mounts sticks down about a foot or more down through the center of the frame,
1994 f250 super duty ext. cab 7.3l IDI turbo. 4x4 manual tranny. I am new to the diesel trucks, i bought this truck to pull my tractor and equipment for my landscaping business
ncfirefighter46 is offline
Old 03-15-2006, 02:11 AM   #2 (permalink)
My Photos: (17)
Re: radiator core support
I think we're gonna need photos of the support that you have. I don't know of any that the rad protrudes below the frame. [img]/ubbthreads/images/graemlins/shrug.gif[/img]OkieG
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 03-15-2006, 05:56 AM   #3 (permalink)
Unless you have something totaly out of this world the radiator support from a 87 diesel pickup will fit, it did in mine........ Jim
<font color="blue">[b]93-F250 (Super Duty), Extended cab, Long Bed, XLT, Gray & Black, 7.3L, New Injector Pump, New Injectors 4X4, ZF5 5 speed trany, 4.10 gears Limted Slip.</font>
<font color="red"> Click here to check out My $800 Texas Truck</font>
<font color="green"> My 30 ft Wilderness 5th wheeler after new paint job and striping.</font>
<font color="purple"> The 2004 IDI rally in July</font>
<font color="red">Life, Liberty and the Pursuit of All Who Threaten It </font>
ltl_jrw is offline
Old 03-15-2006, 08:19 AM   #4 (permalink)
hesutton's Avatar
My Photos: (30)
I put a front clip from a '95 FSuperduty PSD on my project truck and the IDI radiator just dropped into the PSD rad. support without a single modification. It was like that PSD rad. support was made for my IDI radiator. It is strange that you are getting all these different rad. supports. Might be easier to just hunt one down at a local boneyard. I have some photos of the clip in my galleries if you think that will help ya.
Heath
1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
1983 F250 4x4 5.0L with C6. 340,000+ miles.
7.3 Project Pictures
Webshots Project 7.3 Gallery
DYNO YOUR IDI AT THE 2009 RALLY
hesutton is offline
Old 03-15-2006, 11:02 AM   #5 (permalink)
My Photos: (17)
I just got a catalog from www.lmctruck.com the other day. They sell a rad support and lotsa other things for these old trucks. Some are ridiculously expensive and others are quite reasonable. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Old 03-15-2006, 12:16 PM   #6 (permalink)
Shouldn't be anything special.
IIRC - There should be 3 flavors for the 92-96. Gas, Diesel W/O AC and Diesel with AC.
1996 F350 CrewCab XLT 4x4 zf5sp with 1996 5.9 Cummins Turbo Diesel
FordCummins1 is offline
Old 03-18-2006, 08:49 PM   #7 (permalink)
Heath
that is what mine looks like but there is none in my local boneyards. and they said there was N/A anymore. but they body shop is fixing mine.
Old 03-18-2006, 10:11 PM   #8 (permalink)
I ran into a similar problem with my 91 f250 4x4 with A/C. Mine dips below frame level too. No one seems to make a rad. support for my model with A/C but they do make one for a truck without A/C. The correct one has been discontinued by Ford. Someone told me they were the same. All I would have to do was transfer the mounting tabs for the A/C condenser from my old one to the new one. So I ordered a new after market one. Well it was definetly not the same. After some head scratching I decided that I could cut the "U" shaped part out of the new one and transfer the old "U" into the new rad. support. It took a lot of work including drilling out 40+ spot welds but it turned out really good. I also welded in several reinforcements in places I have seen them break in the past. The cost of the new "incorrect" support was about $180 w/shipping. I don't know if you can apply this to a 1992+ but hope this helps.
a91f250 is offline
Old 03-18-2006, 10:44 PM   #9 (permalink)
yeah that is what the body shop is doing for mine right now everything from the mounts up was the same but the u was not the same, so they are cutting my old one out and welding to the new one i think, i know i am goign to have to use mounting bushings off a 80 model truck to go on my truck i may need to mod mine alittle but i can not afford the mounts at 80 each i have ran out of cash now for all new body parts and fiber glass and paint and the luk flywheel.
Old 03-18-2006, 10:57 PM   #10 (permalink)
On my 1986 Diesel, there was a "Super engine cooling" option. This used the radiator support that dropped down.
jamesl is offline
Old 03-18-2006, 11:01 PM   #11 (permalink)
well i think this one had this option i am not for sure this truck was company truck and i think they have a heavy duty rear end in it and it has a ball in the bed of the truck and has a crap load of springs on the rear, so i dont know?
