Old 05-01-2005, 10:20 PM   #1 (permalink)
Gibson's Avatar
radiator resovoir location
while figurin out out a way to put in a ram air system...
I would have to move my battery back, towards the rear, a few inches. i would have to move the radiator and windshield washer resovoirs back too but then i would have to move... on and on and on. so, i am just goin to get rid of my windshield washer resovoir for now.
where would be a good place to relocate my radiator resovoir? i can fit the windshiled washer resovoir (would be used as my radatior resovoir) under the original place of the battery tray. would that be a suitable place? would it be enough capacity? sorry for such a long post......... Gibson
D.T.Gibson
1.830.203.1460
new newer rig: '05 greyish/balckish Ford F-350 XLT Lariat, Crew Cab, 6.0L PowerStroke, Fx4, Leather and all the electric goodies besides a moon roof, auto trans, 3:73's, leveling kit. SCT Looney Tune stacked with Edge Juice with Attitude, and 4" turbo back exhaust. 91K.... blew HPOP and headgaskets. In shop for now. maybe by the 8th ill have her back with new long block! sweet!
newer rig: late '99 Red Ford F-350 PowerStroke, 4x4, CC, 4r100 Auto Trans, 3:73's, Stage Coach Conversion, 4" DP to 5" up to 6" stack, aFe Stage II intake, DP Tuner 4pos chip, dFUSER oil crossover line, 10K mod, AIC controller, '06 18" King Ranch Wheels. 225K.
new rig: CUMMINS POWERED '95 F-350 XLT, crew cab, Blue & white, ZF5-speed, 4x4 with auto locking hubs, 4:10 gears, 283K miles, 3" DP to 5" exhaust, Auto Meter A-pillar 3-gauge pod with EGT, Water temp and oil pressure.
Gibson is offline
Old 05-01-2005, 10:41 PM   #2 (permalink)
Re: radiator resovoir location
If you put the windshield Reservoir under the battery tray, how do you fill it? You might as well throw it out as you can't refill it. Sorry but I don't have a better answer.
Dave
2004 F-350. Standard Cab, 4X4, 6.0 with Torqshift, 3.73 w/LS. <font color="red">(((XM))) Satellite Radio.</font> Lo Jack, 6608 lbs wet. Born on 8/4/2003. Engine 07/23/2003. 3" Lift. Grover Air Horns!!!
http://community.webshots.com/album/85108545NlXNsD
1993 F-350 4X4 7.3 IDI with 5 spd. Gone now.
1976 Kenworth C-500 with Detroit Diesel 8V92TA with 3 spd Jake, SQHD's and RTO 12513 10 Wheel Dump Truck. Sold.
dbennett48 is offline
Old 05-01-2005, 11:00 PM   #3 (permalink)
Willie's Avatar
Gibson
I installed a 4 inch intake on the passenger side of mine, you can try and find the picture I posted by looking for my glow plug battery picture. I turned the air breather towards the A/C / heater and piped the intake just behind the fuel filter, down and under the battery and the air intake ends up in front of the wheel after cutting a few pieces of metal that were in the way. I added a small grill to keep out the grasshoppers [img]/ubbthreads/images/graemlins/smile.gif[/img] PM me with your E mail &amp; I can send you the picture if you can't find it within the gallery as I don't think I posted it correctly at the time.
Bob
My Pictures
1984 Bronco II 4x4 day to day driver : Winter
2005 Explorer Sportrac 4x4 day to day driver : Summer
1991 F350 / Crew cab , Engine 7.3,E4OD tranny. No Turbo but has propane and pyro gauge. The truck is American, complete with a Miles per Hour speedo. Digital trans. temp gauge and voltmeter. Front Captain seats. Control switches for DRL's , Fog lites, High speed idle, Engine kill and scene lites. On board " York " compressed air, Air horns and built in hose reel behind the rear seat. Power bar distribution box from a 1999 Ford Explorer . Checker plate running boards and Frieghtliner mud flaps. LED turn signals in the factory mirrors. DC to AC inverter to run the coffee maker &lt;img src="/ubbthreads/images/graemlins/smile.gif" alt="" /&gt; Soon to be updated with more toys as time & $$$ permit. &lt;img src="/ubbthreads/images/graemlins/smile.gif" alt="" /&gt;
Willie is offline
Old 05-01-2005, 11:09 PM   #4 (permalink)
Gibson's Avatar
I think i need to make myself a little clearer. i edited my thread...
thanks WillieTwo for the suggestion of optin to go to the passenger side. i will see which will work betetr tommarow afternoon. i have all my parts ready to install. i just need a place to install them.........Gibson
D.T.Gibson
1.830.203.1460
Gibson is offline
Old 05-02-2005, 08:12 AM   #5 (permalink)
hesutton's Avatar
My Photos: (30)
Well, I don't know how different your set is from Mel's, but here is a picture of where he has relocated the coolant tank and washer fluid...... HERE
Heath
1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
1983 F250 4x4 5.0L with C6. 340,000+ miles.
7.3 Project Pictures
Webshots Project 7.3 Gallery
DYNO YOUR IDI AT THE 2009 RALLY
hesutton is offline
Old 05-02-2005, 09:02 AM   #6 (permalink)
My Photos: (24)
i maded my own ram-air system with out moving anything. only cut the front support for the radiator just a bit with a saw look at my pictures, it works good and don't need to move anything.
my 2c, exekiel
- 12/92 f350 jasper 7.3L 17k Torito
- Home made exekiel propane system, sweet
- Home made ram-air system
- 4.10 open, DRW
- zf5 trans (dextron and militec); 12" luk solid fly wheel and clutch set.
- exekiel coolant filter system (Fleet-guard filter and dca)
- ip runing with stanadyne every tank and Mels timed.
- Agnem manual tranns starting system :-)
- Hypermax turbocharger system YES Finally. Turned up a la Travis.
crew cab/ wood interiors/ 800w cd player. Sweet ;-)
2 new diamond headlights
4 100w flash lights and 2 withe fog lights
more pics
BOOB Man
soon..
- paint job.
exekiel69 is offline
Old 05-02-2005, 05:47 PM   #7 (permalink)
Gibson's Avatar
thanks guys for the pics. i noticed that yall dont have the a/c on yall truck or i just didnt see it. i have a stock a/c on mine. and thats the mane reason i need to move my battery back.
whats the smallest size of a container i could use for a radiotor resovoir? ..............Gibson
D.T.Gibson
1.830.203.1460
Gibson is offline
Old 05-02-2005, 09:51 PM   #8 (permalink)
check out my pictures and youll see what i did with mine. [img]/ubbthreads/images/graemlins/grin.gif[/img]
1993 Ford F-350 IDI Diesel Crew Cab LWB Banks Sidewinder, Dual side exit 5" Exhaust, Soft Bed Cover, 2WD, Ranch Hand Front and Rear Bumpers, Boostlevel=14psi, 5speed trans, 2800 watt sound system, RedTop Holley FuelPump, 181,000 miles
250HP and 550 Torque @Wheels (w/o NOS)
http://community.webshots.com/user/coolmann64
2003 Excursion Limited powerstroke, bd-power 80hp chip, single ATS exhaust, air intake and tv/dvd
TrbdF450Beast is offline
