Old 05-02-2005, 03:00 PM   #1 (permalink)
My Photos: (9)
Radius arm bushings
Has anybody here down these on your own? How difficult are they to do? So far ive heard only negative things about them. Also the center pivot bushing(or whatever) needs to be replaced.
--Jon
2007 Dodge 2500 Quad Cab 4x4 SWB 5.9 Cummins 6 Speed SLT- Muffler delete pipe, removed emblems, 315/70 17 BFGs
**Sold**2000 F-250 CC 4x4 PSD Lariat 210K UT Orange W/Black- 3 1/2" straight pipe exhaust to a giant 6'' diam. 3ft chrome echo pipe, Zoo-Dad Mod, AFE Stage 1 Intake, Edge Evo., turbo timer, Powder coated black wheels wrapped with 305/70 E Nittos, 05 Conversion w/silverstars, 05-07 emblems, Color matched handles, Ranch Hand Rear Bumper, foil wrap delete/polished up-pipe, Kenwood 7100 Nav/DVD, Pioneer amp, 2 MTX 10s.
**Sold** 92 F-250 SC 7.3IDI N/A 2WD ZF5 160K "The IDI Stroker" 7.3 IDI bored .40 over w/ported heads and lots of other stuff.
http://photos.thedieselstop.com/show...0/ppuser/46803
www.mobilewheelrepair.com
jonmercer05 is offline
Old 05-02-2005, 03:24 PM   #2 (permalink)
Re: Radius arm bushings
I'm doing mine as we speak but not because I wanted to. I was trying to replace the king pins and couldn't get the pin our no matter how hard I tried. It did budge a little but not enough to come out. Sooooo, I unbolted the radius arm bushings, axle pivot bushing and the lower spring mount and brought the whole mess to a machine shop. I will go back together with all new rubber parts so it should be good as new.
To just do the radius arm bushings I don't know if the axel shaft needs to be lowered to get the distance to load all the bushings on the arm end. I wouldn't want to seperate the radius arm from the knuckle end. I seems easier to lower the whole mess like I had to do. Just a thought. Let me know how it works out.
Good luck,
Doug
'86 F-250 4x4
'89 E-250 ATS
Doug Bensen is offline
Old 05-02-2005, 10:32 PM   #3 (permalink)
Supporting Member
when we did the ones on gruss's truck, we ground off the rivits on the brackets, and replaced them with bolts, easier than trying to undo the axle end,
Nick
Dads ride 2002 Dodge 24v, dual exhaust, edge comp hot box. tst 40 hp injectors,Piers B-1 turbo dipricol white face a pillar gauges, Suncoast triple disc and valve body occasionally he lets me drive it. 393 rwhp, 807 ftlbs
1996 F-350 CC swr, long bed , 4x4 PSD zf-5, 250k.Swamped, 5" black stacks, dipricol gauges, 30+PSI boost, DP tuner chip, 330rwhp.
95 PSD project
Need IDI parts I got more than most junk yards.
finallygotanIDI is offline
Old 05-02-2005, 10:44 PM   #4 (permalink)
I second Doubles reply. We use a torch to cut the radius arm bracket rivets. Be careful to not cut the bracket or the frame. A good chisel on an air hammer will work also. I have seen Poly bushings at the local NAPA store. They are a little more money but should last longer than the rubber ones. Just my .02
Jason
92' F-250 4x4, 7.3IDI-NA/Jasper E40D., 4.10's
K&N air filter(no soup bowl), 3 1/2" single exhaust, DPS tuned pump, new injectors, 305/70/16's on 16x10 chrome mods w/no lift.
Stickhauler is offline
