Old 04-17-2007, 02:17 AM   #1 (permalink)
Ram Air... NO TURBOS
Has anyone fabricated a ram air system through their hood?? I wanna pull more power outta my idi by stuffing some more air into it but don't wanna pay out almost the same price that i paid for the truck to turbo charge it... Any ideas or "already done it pics"??
7.3 IDI F-350 4x4 1990
-Custom: '92 interior; Banks Y Pipe, Flowmaster muffler and Dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
-Soon to come-
Mid 80's front clip
Matching fender flares
Black paint job with chrome trim (fender flares, grill, bed runners, wheels, exhaust stacks, windshield trim, bumper)
2.5" leveling kit
4.6l Mustang GT 1997
-Custom side exhaust (no mufflers, Ford Racing Exhaust tips
-Aftermarket stereo (Alpine headunit; JL Component Speakers; JL 300x2 Amp; JL 10" W7 Sub; JL 500x1 Amp)
GOTTA LOVE FORD MUSCLE
Cjhstang is online now
Old 04-17-2007, 09:06 AM   #2 (permalink)
Re: Ram Air... NO TURBOS
No, not yet....but in the near future. There was a post some time ago and one of the members had pictures of a ram air modification that came in behind the grille on the passenger side, but would be next to impossible with the ac compressor and condenser coil intact-he had removed his. For those of us that are aesthetically challenged (my wife's description of me) it would make sense to have some kind of hood scoop to bring in cool air and take advantage of ram-air effects. The ram effect follows the laws of physics; 4000 feet per minute equate to 1" water column pressure-or 45mph. This is a squared relationship, so 70mph = 2.3". This is at least enough to overcome the filter loss and should do a lot of good. I had a '67 GTO in the 70s and had a working hood scoop-used a motorcycle inner tube to seal the od of the air filter to the bottom of the hood and drilled some 1/2" holes in the bottom of the air filter housing to drain water-never had a problem. Something similar would work for this application. Even something as simple as a 6" elbow stuck up through the hood would work. What does everyone else think??
93 F-250 mostly stock 270,000 miles original engine 2nd rebuild on E4OD...92 F-700 Bus/Motor Home 160,000 miles 6.6 Brazilian Ford td engine
wtom24 is offline
Old 04-17-2007, 01:50 PM   #3 (permalink)
I've never seen a ram air set up with the air filters that sit ontop of the engine like this. Do you need a special filter if your going to ram the air directly down into it from the hood directly above it instead of it coming into the side of the bowl like factory?... any idea of what sort of power gains you'd be looking at?? I've been seaching for a somewhat large ram air piece thats already manufactured that I can put on it... but pep boys isn't impressing me-they all look too small.
Thanks for the tech info!
-3" Body Lift
-8ft snow plow
-Soon to come-
Mid 80's front clip
2.5" leveling kit
Old 04-17-2007, 05:39 PM   #4 (permalink)
My Photos: (16)
http://photos.thedieselstop.com/data/500/56843t1.jpg
'93 F250 SCab XLT, 4X2- 7.3/ZF5/4.10 Banks Wastegated Turbo, Enviro-assult tube
'85 F250 Reg Cab XL, 4X2-6.9/C6/3.54 Racor, Holley Red, Auto Jet 3" out, Air Ride Rear
'93 F150 Reg Cab XLT, 4X4-5.0/AOD/3.55 Pacesetter dual out, Timbren Rear
Some pix/ The fleet
Zrob is offline
Old 04-18-2007, 12:39 AM   #5 (permalink)
Bill1013's Avatar
Hey I just changed over my air intake. Used a filter from Autozone. They claim it's just as good as K&N. A 4" dryer ell ( can adjust it for any angle ) and a 8 ft. section of dryer 4" duct. Don't stretch it out and it's real solid. Had to cut off about 14". Removed the baffle in the original filter unit. Had to flatten the two top lumps on the original filter box, once it's on there it's hell to get off, no need for a clamp there. Drilled one hole thru radiator mount for wire tie. Looks like there is plenty access to cold air where it's placed. Made one heck of a difference no smoke when idleing now. Check pics out. Don't know if it will increase mileage yet, but it sure act like the engine gets more air.
PARTS
Autozone Filter $32.00
Lowe's 4" x 8' Flex Alum. Duct $11.37
Lowe's 4" 90Deg. Alum. Elbow $3.33
Lowe's 2-4" Worm gear clamp. $2.74
CHECK PICS
OLDBULL [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo Radio SD & Tape 126,700 03/08 Strictly stock. Build date 03/99
Rebuilding engine. 92 F350 7.3 IDI CC LB 2WD Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
Reman IP - New Delphi Injectors -New Beru GP's 07/07 New radiator & hoses New WP
Dual Exhaust 3"X18" resonators frnt. of rear wheels
Soup bowl gone, 4" intake W/AZ filter
Cobra CB W/Weather Interrupt - Dual Trucker Antenna's
Blk. Grill W/Brush Guards - Fog lights - Rally driving Lights. GN 20K & Reese 16K 5er hitch
http://community.webshots.com/user/oldbull8?
Formally OLDBULL
Toys: 1984 Coachmen Leprechaun F350 Chassis 460CID 92K miles.
30 ft. Jayco Jay Designer 5th wheel.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One flash and it's gone.
Bill1013 is offline
Old 04-18-2007, 07:28 PM   #6 (permalink)
Thanks for the info OLDBULL. I like the idea... Might i ask... why didnt you completely remove the filter housing and connect your new intake directly to the engine intake? I'd be afraid of it creating a bunch of turbulance in the big open airfilter housing.
Do you ever have problems with water or mud gettin on your filter?
-3" Body Lift
-8ft snow plow
-Soon to come-
Mid 80's front clip
2.5" leveling kit
Old 04-18-2007, 08:51 PM   #7 (permalink)
Bill1013's Avatar
Never had it on the road til today. Idled just fine with no smoke like i used to have idling. I don't think you would get any mud or water cause it's behind the radiator mount bracket, but there is a couple of openings that would let cold air to filter. Thought of a ram air on the hood but could'nt figure how to do it and all the water to contend with in rain also opening the hood then making good connection back again. Thought I had everything good to go until I road tested today. Read my post today 7.3L Oil at #8 cyl.
Formally OLDBULL
Bill1013 is offline
Old 04-18-2007, 11:17 PM   #8 (permalink)
wow, sounds like a mess! I can't imagine that would have to do with a modification to your air intake... just a stupid question...you didn't drop anything into your engine did ya?
-3" Body Lift
-8ft snow plow
-Soon to come-
Mid 80's front clip
2.5" leveling kit
Old 04-19-2007, 12:28 AM   #9 (permalink)
Bill1013's Avatar
I'm quite sure it's not because of the air intake change. I did have the air intake covered before removing the head. Any thing inadvertantly drop in the air intake would have to go thru the intake valve, and #8 was at the top when I replaced the head. Well I'll know when I pull the head again. Just alot of hard work again. LOL [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Formally OLDBULL
Bill1013 is offline
Old 04-19-2007, 12:52 AM   #10 (permalink)
are u runing two air filters or just that one
93 IDI 360,000 miles still runs good 2wd auto trans all stock
kkkdusty is offline
Old 04-19-2007, 07:38 PM   #11 (permalink)
Willie's Avatar
I 've turned my breather to point just behind the fuel filter, added 4 inch flex aluminum dryer pipe and feed it along side and down then under the pass. battery tray. Ends up in the wheel well. I cut a grill into the bumper to put more air into the general area but it is not a direct connection. Been that way for 3 years now, no bugs but can't really remember how much it helps. [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Bob
My Pictures
1984 Bronco II 4x4 day to day driver : Winter
2005 Explorer Sportrac 4x4 day to day driver : Summer
1991 F350 / Crew cab , Engine 7.3,E4OD tranny. No Turbo but has propane and pyro gauge. The truck is American, complete with a Miles per Hour speedo. Digital trans. temp gauge and voltmeter. Front Captain seats. Control switches for DRL's , Fog lites, High speed idle, Engine kill and scene lites. On board " York " compressed air, Air horns and built in hose reel behind the rear seat. Power bar distribution box from a 1999 Ford Explorer . Checker plate running boards and Frieghtliner mud flaps. LED turn signals in the factory mirrors. DC to AC inverter to run the coffee maker <img src="/ubbthreads/images/graemlins/smile.gif" alt="" /> Soon to be updated with more toys as time & $$$ permit. <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Willie is offline
