i went to leave work tonight and the back end of the truck felt like it was bouncing.i jacked the back axle up and put the tranny in neutral.it was hard to turn the back wheels by hand.when i turned one wheel on one side the other wheel would turn in the opposite direction,is this normal.can i drive the truck for about 5 miles to get the truck home or will i cause more damage.the truck also did this when i put the truck in neutral and coasted across the parking lot.what could be the problem and what do you think it would cost
If you mean the truck was pulsating across the parking lot as you drove, most likely the rear brakes were/are applied or the drums are possibly out of round....... Check the cables are slack....
Proud Canadian BOOB man too!!
ok i drove the truck home.it shook bad for 1 block then it ran great the rest of the way home.will be pulling the rear wheels off in the morning.could a rock have got in the wheel to cause the shacking
I don't think a rock could have gotten in there but you never know. My guess is just some sized, rusty or sticky brake components, maybe a broken spring.
If you find yourself in that situation again you could always try to pound the backing plate of the drum with a hammer or rock in attempt to free up something that might be sticking.
And yes, the wheels do turn in the opposite direction when jacked up.
1984 toyota BJ60 Landcruiser, 3B diesel, H55f 5 speed, Best rig Ive ever owned. Never needs anything, 503,000km, Old Man Emu suspension, rusty and running strong Will certainly outlive all my other wheels
1985 Toyota 4wd pickup, single cab, rare 2lt 2.4l turbo diesel, 5 speed, custom flatdeck, timing belt every 100,000k and shes good to go. 393,000km Excellent fuel economy!
Check your universal joints. I had one seize up and it felt like the rear end.
1993 F250 XLT Long Bed, 4.10LS with Aluminum Cover, Rebuilt E4OD, ATS 088 has 085 Air Box with Twin 4" intake tubes, Powerstroke 3.5" exhaust, tandem 28,000lb Transcoolers, Mag Hytec 8qt oversize trans pan.
pulled the wheels off this morning and it turned out to be the brakes where worn down and the brake cylinder right side came out to far making the brake stick
Not pointing fingers, but your findings just exemplify the reason there are MAX/MIN sizes for brake drums and rotors. Ensure after any brake job that your drums/rotors are within specs or the end result when things wear or you fail to adjust them as required will be the above or worse.
Remember backing up, stopping hard and driving ahead, repeat as necessary will adjust the rears if everything is working right. Try it you may like the results... higher pedal with less travel is always my result.
Rememberance Day 2009............. be there!!!!!!!!!
new rear brakes,new brake cylinders ,new brake lines.bled the brakes this morning and while the truck was on stands i told the wife to start the truck and put it in drive and see if the rear brakes come on.the truck STILL HAD A BAD VIBRATION.what a wast of $140 in new brakes.how can i tell if the problem is hanger bearing or u joint or rear end.i will be posting a video on the truck.any + help would be great i need the truck for work but cant aford to throw money away
Paul - Pocono Mtns. USA
02 E350 15 Passenger, 52,000 Miles
'90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak, Retired 11/8/2011 with blown trans.
I looked at the video, could it be the midway carrier between the two drive shafts? There is a bearing, I believe, and a rubber mount for the bearing. See if the rubber mount is there, damaged, missing chunks, or the like. Or, if that bearing is shot.
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer Yaesu FTM-10R & a Comet CSB 790A
figured it out.i took the drive shaft from hanger bearing to the rear end out and the truck still shook.took the drive shaft/hanger bearing out and ran the truck with no vibration.the hanger bearing is fryed.
