Old 10-31-2006, 03:48 PM   #1 (permalink)
My Photos: (13)
Rear main seal....
Looks as though the rear main is going out.....there is oil all over the bell housing, exhaust and so on. What's an estimated repair cost on this one?
1989 F250 single cab 2WD
7.3 IDI with 150,000 miles
Single Straight Exhaust with 4" Chrome Tip
No Soupbowl
E40D
LT 265/75/16 Yokohama AT's on 16x7's
Factory Hubcaps
Gooseneck hitch
Homade rear pipe bumper with built in utility-lights and D-rings
Diamond Plate Aluminum Toolbox
Tinted Windows
Future mods: Roof Markers and front pipe bumper
1997 F250 Extended cab 4x4
PowerStroke Diesel, E40D, Manual Hubs
All Stock Except Exhaust - No Cat, 18" Glasspack
welder79 is offline
Old 10-31-2006, 07:05 PM   #2 (permalink)
ltaylor's Avatar
Re: Rear main seal....
if you can do the labor yourself its a cheap fix. i had my tranny in and out in about 3hrs (to replace the torque converter)and its a 4x4. i think the seal is between 20 and 30 bucks. if you have a small slide hammer it will make the job easier when removing the old seal.
2001 Excursion Limited, 4x4, toreador red, 4" turbo back exhaust, DYI Tymar intake
92 F350 CC SRW,7.3 E4OD 4x4
4" lift 35" tires, 4.10, 4" exhaust straight pipe,
ATS nwg turbo, rebuilt and balanced, holley red, new IP & injectors, rebuilt heads by me
A pillar triple pod, auto meter phantom gauges,
pyrometer, boost, trans temp, oil pressure & water temp
future upgrades
formerly known as; pullmyfinger
http://community.webshots.com/user/pullmyfinger76
ltaylor is offline
Old 10-31-2006, 09:27 PM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Ensure the rear seal "is" the culprit and not the oil sender or valve covers which could be the case........ Oil from above will find its way into the bell housing since it is not sealed at the adapter plate.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 11-01-2006, 12:26 AM   #4 (permalink)
The pan on mine had a hundred holes, and the sending unit leaked and it all looked like the rear main! I drained the motor oil; wire wheeled the pan, cleaned it off real good with lacquer thinner and then coated it with epoxy. The sending unit and pedestal were removed cleaned and wrapped with plumbers tape before reinstalling. Note that the plumber’s tape may cause a bad ground causing the oil pressure idiot needle to do weird things. Number one you need to get a mechanical oil pressure gage. If you don’t like to have a dead gage on the dash you can wrap a wire tightly around the base of the sending unit and attach the other end to a good ground source. Another place is up where the IP meats the gear tower, is the seals fail or the sealant fails oil runs down on the valley cover and to the back of the engine and down the bell housing and onto the muffler! There are a few other things like back pressure in the crankcase cause by a failed CDR valve / turbo causing too much blow by…
93
93 E-350 160,000+
http://webpages.charter.net/idi_diesel
GaryBecker is offline
Old 11-01-2006, 08:48 AM   #5 (permalink)
cdnsarguy's Avatar
My Photos: (66)
If you use the liquid Teflon tape sealant, you will have a good seal and a good ground.
Old 11-02-2006, 10:56 AM   #6 (permalink)
My Photos: (13)
What do you mean by oil sender? Do you mean oil pressure sender?
Thanks for the replies.
No Soupbowl
E40D
Factory Hubcaps
Gooseneck hitch
Tinted Windows
welder79 is offline
Old 11-02-2006, 02:28 PM   #7 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Yes ...sorry I mean Oil Pressure sender.
Old 11-02-2006, 10:07 PM   #8 (permalink)
Small slide hammer? I just unbolted the plate from against the back of the engine that holds the oil seal. Hammered out the old seal and pressed in a new seal on my workbench, and bolted the entire plate back in place.
_______________________________________________
Aaron
1987 F250, 6.9, C6 - keeps me busy!
1988 F250, 7.3, ZF5, supercab - newly acquired project
adelyser is offline
