The relay seems to not want to work well today,the one by the pass valve cover by the turbo (94 IDI turbo) I think it is for the glow plugs,it clicks when the light goes off,if it does not click the truck will not start,a slight tap with a screw driver it clicks and fires right up,what is the relay for or called so I can find a replacement.
Thanks,Tim
99 F-250 EXT Cab 4x4 Powerstroke Diablo Delta chip,4" turbo back exhaust, all necessary gauges!
94 f-250 ext cab 4x4 7.3 IDI turbo SOLD!!
94 SVT Cobra #1668
90 f 250 7.3 sold
93 11 sec. mustang 5.0 sold
94 3.8Mustang vert driver sold
80 cj-78 mud toy sold
97 5.0 explorer
When you say the truck will not start unless it clicks, do you mean the starter won't even engage, or the engine will turn over, but just not start?
If the starter doesn't even engage, that's your starter relay. It's basically the same type relay.
When changing out either of these relays be very carefull with the big wires going to it, they are connected directly to the battery and will short out violently on anything and everything.
Sounds like the glow plug relay, if they can't find just the glow plug relay ask for a starter relay, it should do the job.
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
I guess I should have specified,it is NOT the starter relay,that one is on the fender,It looks like the one in the pic with 2 small wires going to it,when it does not work the truck just cranks,no start,as soomn as I get it to click it will fire right up.
94 SVT Cobra #1668
90 f 250 7.3 sold
97 5.0 explorer
There was a post about the GP Relay a while back. The GPrelay is slightly different from the starter relay, wired differently inside, and a starter relay will not work. The GP relay is quite a bit more expensive. If I remember correctly, $55.00 [img]/ubbthreads/images/graemlins/eek.gif[/img]. OkieG
First thing, check that your power and ground connections are all good, clean and tight. You might be jiggling a connection when you tap on the relay.
Other than that, the coil in the relay is probably just getting weak or is sticking.
I would say it just needs replaced,the truck has 209,000 miles on it,all the connections are good.
94 SVT Cobra #1668
90 f 250 7.3 sold
97 5.0 explorer
