I heard from a friend that the trucks that have power locks are also ready for the remote locks. Since I leave my cap and sliding windows unlocked to allow easy access for the numerous times I lock my keys in my truck; is there any truth to the rumor that you can just plug in a module somewhere. I looked at the systems for sale on Ebay and it looks like a nightmare to install.
Thanks again
Roy
1994 F350 XLT Crew Cab DRW
Factory Turbo 7.3 IDI
220,000 Miles
Door locks are not a big deal it's when you want remote start etc etc...
There is a new deal out for our trucks which is a number system keypad stuck on the door, which works I hear.......
yah, there's no reason you couldn't install a simple weatherproof pushbutton switch somewhere around or under the truck, to unlock the doors if you're locked out. It shouldn't cost more than 5-10 bucks, nor involve more than a couple wires.
I haven't scrounged wiring diagrams for this 91 yet, but the lock system on the 86 xlt was dirt-simple.
My other diesel is a...
Hydra 35-ton Excavator, 6V71T; Isuzu C201 genset;
'71 VanPelt Pumper, Cummins 855 Turbo
There used to be a link here, to some useful IDI-diesel tech info; but it was chopped out by others, in a vain attempt to repress the very essence of the internet: linking!
sigh...
Hi. I too would like to have remote locks on my 94. Could any of the members tell me where the stock module is located on the 92-97 trucks is located? I have several good auto parts recyclers close and would like to pick one up. Brad
1994 F250 SC, long box 4WD, 7.3 factory turbo,E4OD, 3.55 Axle,185,000Mi, hope to do some mods soon, just bought Feb 05. 1987 F350 Crew Cab, 2wd, SRW, L box, 7.3, 5spd (some PO put them in), 3.55 Axle, 184,000Mi or more, not a pretty truck, usually pulls 5th wheel flatbed, air cleaner mod. 1987 GMC Suburban, 2wd, 6.2, 700R4, 188,00Mi, getting rusty, run around truck. 5020 John Deere 531 cu in, The Big Toy, soon to have a heavy duty loader mounted. Plus to many more Fords, JD's and other toys. REAL TRUCKS DON'T HAVE SPARK PLUGS !!!
On 1994 the "remote keyless entry programming connector #C243" and "remote keyless entry module #C240,C241,C242" are under the dash beside the steering column
1992 F-350 , CC , 4x4 , 7.3 IDI , E4OD , 3.55 Gears , 130000 KM , 4" Lift Kit , Altezza Tail Lights , Euro Clear Headlights ,1990 F150 Chrome Front Bumper, Xenon Extreme White 80/100 Bulbs , E4OD Transmission Cooler , Sony AM/FM /CD /MP3 /XM Ready , Insten FM Digital Transmitter , Apple Ipod video (60g) , Rancho RS5000 Shocks , 10X16 Americal Racing Wheels , 315 LT /75R 16 Durango XTR Radials..
Thanks a lot for the info Punisher. As soon as it dries up I'll be hitting the salvage yards looking for a module and some other parts. Brad
If your Ford vehicle has a factory remote door lock, you can add the keypad w/o much trouble. It sends a signal just like your key fob transmitter and just sticks to the outside of your door. It does need to be programmed. Some can be programmed using ignition key cycles, others have to be programmed using Ford
diagnostic equipment. It depends on the year and model of vehicle.
not all of the 94's have that module, or the wiring for it. Do a search, especially on the PS forum. DreammachineF250 has done a lot of research on this. PM him. Mine did not have these items, and I do not believe many of the 94's had it.
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
My pictures show the C240-241-242 remote keyless entry module would be located to the right of the steering column on the dash. Looks like the RKEM is second wire leadout off the main bundle to the right of the SC. The programming connector is on the steering column up by the wire bundle.
