I dont think you have to worry about it unless one actually breaks. If one does break you can bring that piston up to TDC ( sight? feeler stick?) so its easier to fetch.
1993 Ford IDI 7.3L
F-250
ZF-5 speed 4 wheel drive
Class 5 hitch
D load tires <img src="/ubbthreads/images/graemlins/frown.gif" alt="" />
super cab
18x,xxx miles.
Purchased 9-22-06
i would just try removing them first, you will know if you have a problem
when your unscrewing them if they don't slide right out they might be a little carboned up, usually soaking them down with some carb clean does the trick
2001 F-350 7.3L 4X4(ESOF) CC LWB 4R100 4X4, WIX 46637 open element air filter, Wicked Wheel, walker BTM, 203* Tstat, IC tube foil removed, coolant filter, AIH removed, 08 aluminum finned rear end cover, DP tuner 80econ 140smoke high idle,Phantom gauges, ATS transmission,ATS deep trans pan, 5 star torque converter, V10 trans cooler, 4" MRBP SS downpipe, twin 4" stacks
Work like there is a tomorrow and play like there isn't.
87 F250 Lariat SC LB 4X4 with an NA 6.9, C6 and 4.10's. Dana 50 IFS up front. 244K mi. 3" exhaust, WVO, Ram air. Thinking about propane or methanol/ water...
First diesel and a lot to learn....
96 F350 CC LB 4X4 AT 231K
Second diesel and still a lot to learn...
Just try to remove them first. If you find one or more are stuck, then I'd worry about getting the pistons up there to protect against broken tips.
After reading all the horror stories, I was more than a little hesitant as well. Fortunately, the old plugs came right out without a hitch.
1994 F250 4x4 Off Road---7.3 IDI. Bone Stock. Rumored to be the last non-PS to roll off the line.
YOU MUST have the piston at TDC before the tip breaks off (if it is going too). Unless the tip is stuck in the hole it will most certainly drop into the cylinder and the heads must come off. No it won't pass out the exhaust..........
so i must admit i did not do much ( if any) research before removing my glow plugs. if a tip broke off, my plan was to remove the injector, bring the piston to TDC and suck with a vacuum. Not a good plan i suppose? I assumed the tip would fall in the injector no matter what.
i guess its a good plan to listen to the pros!
1993 Ford IDI 7.3L
F-250
Class 5 hitch
super cab
18x,xxx miles.
Purchased 9-22-06
As long as the broken tip stays in the prechamber, you're plan works perfectly. If it falls out of the prechamber into the cylinder, you're most likely out of luck. The hole in the prechamber is actually surprisingly small (That's the prechamber removed from the head in the upper left corner of the pic). I doubt the tip would ever come back out that hole. Not to mention, I think I read the gap between piston and prechamber is only 30 thousandths. The tip would likely be pinched if you raised the piston to TDC after the tip fell into the cylinder.
Is going thru all that overkill? Maybe, but I'd rather take 2 minutes (literally) to disconnect the FSS and put a ratchet on the front and turn the cylinder to TDC.
Best of luck,
Devo
I've seen that mention of disconnecting the FSS before turning the engine over by hand/with ratchet several times since joining this site. Has an engine actually started running like that?
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
I can't even conceive a way that the engine would start while turning over by hand. We're constantly preached to about good batteries and starters because these engines need speed to start. However, I've read that reference numerous times and wouldn't want to be responsible for someone getting a hand laid open or pounded by a suddenly flying fan blade.
I still don't see how it could start though.... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Devo
