Removing the turbo. 1993 F250 Factory IDIT - Diesel Forum - TheDieselStop.com
post #1 of 27 (permalink) Old 06-20-2010, 04:47 PM Thread Starter
junkrider's Avatar
Send a message via Skype™ to junkrider
Hi-
I have read many of the threads regarding removing turbos from the engines but I really don't get it.
I have 1993 factory turbo IDIT. Ext cab 4x4 manual trans F250 with A/C.
I have done the following:
removed the alt, fuel filter, the inj lines, harness/gp solenoid.
I have removed the 2 nuts and 2 bolts holding the pipe that runs from the crossover and right exhaust manifold to the turbo.
I removed the bellhousing bolt that secures the other pipe to the bellhousing, and removed the clamp that holds that pipe to the turbo unit, this "other" pipe is now completely loose and free from the turbo.
I removed the center bolt on the conch-shell shaped thing in the middle of the intake manifold (one bolt center), and removed the two bolts on the bracket immediately behind that conch shaped thing. I removed the oil feed line from the block to the turbo unit.
I can rock the entire thing. I also removed much of the heat shielding, but I cant get the heat shield on the back of the pipe that runs down to the crossover, seems like it may be clamped somewhere.
Everything rocks nicely, so I'm pretty sure stuff is loose. Anyone know something I may have missed?
93 F250 IDI TD 4x4 5 speed ext cab 8' 239K Mods: Facet Duralift fuel pump @ 212K, headlight relay conversion @ 218K, custom fabricated radiator support rebuild @ 218K. rockers/lifters/pushrods @ 214K, new fuel tanks @ 233K, new front axle UJ,BJ,spindle bearings @ 233K, new right front UJ LJ drag link @ 239K, new cab corners (both) and drivers floor drivers cab support @ 239K, new left front right rear spring mount @ 239K.
92 Mazda 626 370K (*** DEAD ***)
13 Focus ST 56K (summer DD)
15 Nissan Frontier 3K
04 Suburban Z71 88K
86 Mustang GT Ragtop 5 speed 250K
73 MG Midget ??K
junkrider is offline
post #2 of 27 (permalink) Old 06-21-2010, 07:59 PM
cdnsarguy's Avatar
My Photos: (109)
I'm not turbo literate, but the down pipe is in 2 pieces.. and must be separated by the firewall if I remember what I have read here.......
Cmon someone fess up and help the guy.........
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #3 of 27 (permalink) Old 06-21-2010, 08:06 PM
chuckster57's Avatar
Let me see if I can remember right. I ditched all the heat shields. Tried to save them but couldn't get them to hold their shape. I haven't replaced them and haven't noticed any problems with heat.
IIRC there are 4 studs on the turbo that have nuts on them holding the turbo assy to the "up pipe".
I had to unbolt the exhaust pipe from the DP and then take the clamp off to get the DP to come out. Look at the "tubo upgrade" pics ( link in sig)and it should give you an idea of what your working with.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #4 of 27 (permalink) Old 06-22-2010, 04:54 AM Thread Starter
junkrider's Avatar
If the downpipe is the one with that round clamp that clips the lips together to the turbo, I don't think I need to remove that. The clamp is off and the pipe is free from the turbo.
So, I cant work the turbo out with the entire up pipe attached? Should I absolutely have to unbolt the turbo from the housing at the up pipe and just keep rocking that housing until it comes out of a slip joint?
04 Suburban Z71 88K
73 MG Midget ??K
post #5 of 27 (permalink) Old 06-22-2010, 05:25 AM
My Photos: (27)
Unless the factory Ford ATS version has the exhaust pipes to turbo housing attachment different than the regular ATS, which I doubt, it's self explanatory, IIRC both pipes are a slip fit and after unbolting any support brackets they slip out of the casting. If somebody assembled either pipe without lots of Never Sieze then they'll be REAL difficult to remove from the turbo casting.
On second thought after reading your latest post and checking my ATS installation papers, you may have to unbolt the exhaust inlet cast pipe from the turbo inlet. That would be the four 3/8"? bolts. It's been too long since I've had mine off, but I bet you can't snake that inlet pipe out between the head and firewall if it's attached to the turbo. The outlet slips out of the housing but the inlet has to be unbolted. Be sure to slather any bolt threads, etc. with Never Sieze when you reassemble it.
LMJD is offline
post #6 of 27 (permalink) Old 06-22-2010, 08:03 AM Thread Starter
junkrider's Avatar
Thanks to everyone for the assistance. I did see some other posts referencing curved box wrenches, to get four bolts off the turbo, and those must be the ones on the turbo casting that you mention. I'll pick up a set of curved wrenches after work tonight, soak those bolts with pb blaster and attempt this some more.
I'm not as mechanically incompetent as my first post implies, but I'm pretty new to diesel IDI, never worked on a turbo at all, and I really don't want to disassemble stuff that doesn't need disassembling, considering disassembling parts that are 18 years old with 200K miles unnecessarily can significantly impact the cost of the job as these parts start breaking.
Thanks for everyones help. I'll post with my results
EDIT: Also, I noticed that online manuals (autozone) and the haynes diesel manual are almost useless. Time to get a fsm.
04 Suburban Z71 88K
73 MG Midget ??K
post #7 of 27 (permalink) Old 06-22-2010, 08:20 AM
You are very welcome. If You have any questions at all, don't hesitate to ask. LOTS of knowledge here and we are all eager to share.
What are you trying to accomplish by removing the turbo?
Train Horns:
post #8 of 27 (permalink) Old 06-22-2010, 08:59 AM Thread Starter
junkrider's Avatar
I likely have a collapsed lifter, based on my diagnosis, on cylinder #6. So, I'm removing the intake and valley, then will swap all 16 lifters and push rods.
04 Suburban Z71 88K
73 MG Midget ??K
post #9 of 27 (permalink) Old 06-22-2010, 09:03 AM
Yuck!! Good luck with it. FYI- if you are re-using the rockers and pushrods, I would take them out and save them as "pairs" and be sure the copper end of the push rod is installed at the right end.
Train Horns:
post #10 of 27 (permalink) Old 06-22-2010, 09:35 AM Thread Starter
junkrider's Avatar
I already have all new pushrods and lifters. The price of the valley gasket was enough that I only want to do this once.
04 Suburban Z71 88K
73 MG Midget ??K
post #11 of 27 (permalink) Old 06-22-2010, 10:24 AM
Train Horns:
post #12 of 27 (permalink) Old 06-22-2010, 12:31 PM Thread Starter
junkrider's Avatar
Chuckster,
How much does the 5th wheel you pull weigh, what sort of fuel mileage do you get while towing?
I was getting about 16.9 to 17.1 not towing, driving mixed highway (at no faster than 65mph) and backroads. 5 speed. I did see that the crappy CAI air-filter (previous owner has credit for that POS) was very dirty and have cleaned it now. Hoping to get 18-20 on highway, I don't know if its possible.
04 Suburban Z71 88K
73 MG Midget ??K
post #13 of 27 (permalink) Old 06-22-2010, 12:58 PM
Chuckster,
It weighs in at just under 9K dry. Of course I only haul enough water to flush "on the way". When I do weekenders, I don't like to keep track, as it is usually an hour to an hour and a half of UP hill pulling. I figure in tanks of fuel
On our 8500 mile road trip we averaged 10.3 MPG. trailer was hooked on abot 90 % of the time. It's NOT my DD so when I do drive it around I have "fun" probably get 12-14 MPG.
Train Horns:
post #14 of 27 (permalink) Old 06-22-2010, 06:47 PM Thread Starter
junkrider's Avatar
Okay I pried up gently on the bracket holding the turbo housing to the back of where the intake hat is, and the intake hat came off nicely. No damage, every thing seems fine, I was hoping that this slip joint on the up-pipe was coming apart. No such luck.
Is the slip joint the same as any exhaust pipe joint? Is there supposed to be a clamp or set-bolt holding it together? About how far down from the turbo housing should the slip joint be?
I started soaking the bolts between the compressor housing and the exhaust housing, but I'm not really sure which bolts are the desired ones to remove?
Do I need to remove the heat shielding from the uppipe?
Thanks again for any help.
04 Suburban Z71 88K
73 MG Midget ??K
post #15 of 27 (permalink) Old 06-22-2010, 08:06 PM Thread Starter
junkrider's Avatar
I finally bent the heat shield on the up-pipe from behind the waste-gate to expose a flange with some nuts that are readily visible (2) and maybe some more, not really sure yet. Soaked it all over with PB blaster and letting it set for the night.
04 Suburban Z71 88K
73 MG Midget ??K
