Has anyone found an extra-capacity rear tank that fits? I am looking for one that will work with B100 biodiesel, so the regular, "aluminized" steel tanks won't work. Would really like to find a 35 gal (or so), plastic one. I have "googled" my fingers off to no avail. Anyone have a source?
1992 2WD F-250 SuperCab 7.3L 5-spd 4.10 rear. Changed to 5w-40 Rotella Synthetic oil in the crankcase & Deep Purple Synthetic ATF in the Trans. 38K on new Jasper longblock, Bought truck from local University (MSU - 09/20/06). Replaced O-rings on return line caps with Viton. Now on to tackling Biodiesel!!
Yeah, some folks use the Bronco tank. You'll obviously need the straps for it as well, as tis much deeper than the stock one.
__________________ The more I drink, the more I drink, the more I drink...
'90 F350 XLT Lariat, reg cab, dually, 4.10s, factory tow package, Chevy hydroboost conversion, P3 brake controller - the Hay Express
get a plastic bronco tank and straps the mounting is the same
but dont get the sending unit tis different
try a gooogle search on plastic fuel tanks
i think flowmaster has a good line
I also know theres a 45 gal out there and a 55 gal front
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
how big is that 55-gal front tank? Stock is 20 and tis freakin huge, there's hardly any space left for anything larger, and that 55 has to be a monster in size.
well its more preciselly modeld and its way deeper and has an oil pan shape to its bottom
its definatly not a 4x4 thing
when i did this on a gasser years ago--they just sent long bolts--and pipe spacers, and reused the regular straps---tho i had to redo the send unit---
it will promote corrosion faster and it will also be a matter of is it done or is it done correct
the stock straps are made to hold the large tank your bolts and spacers are not
also the bolt and spacer idea has also in cases loosened a bit allowing the tank to move but i never heard of it falling out
Is there a chance or is there a "Parts Link" section? That would be nice to go to one area and find links to all the parts needed and a "Fix It" area too.
I will probably go with the plastic Bronco 33 gal rear tank with the new straps. There ARE larger "extra-capacity" rear (and front) tanks out there, but they are NOT made to be used with Biodiesel. They are made of "aluminized" steel (whatever that is), and they called me and said that they do NOT recommend or warranty them for use with anything over B10 (10% Biodiesel blend).
The rear tank is way easier, to me, to remove. The only thing holding mine up was the skid plate. It was about 8 or so bolts and odown it came. I wasnt sure if that was normal......
1994 F350 XL Crewcab 4x4 SRW 7.3 NA
Dana 60 Sterling 10.25 3.55 285/75 16 Dayton Timberlines
TC lockup Mod
Pyro Installed!!!
TO DO: Boost guage, Tekonsha Voyager Brake controller and Turbo when I acquire one!!!
