Return line check valve? - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 06-22-2010, 02:38 PM Thread Starter
ben_fluke96's Avatar
ok so ive got a 7.3 idi in a 73 f250 and upon first start up it runs sort of rough (like air in the system) but if you shut it off and start it right back up in runs smooth ( like its primed back up). i can hear fuel running back in the tank when i shut it off so do i need a check valve to keep the return side primed? if so should i put it close to the tank or the engine?
thanks
Ben
PROJECT: 1973 F250 with 1989 7.3 idi transplant
SOLD:
1996 psd reg cab f-350 xlt 4X4 automatic, hillboro aluminum flat bed, w/4:10LS, converted to dually, 3-4"downpipe and 5" exahust, never even saw the cat, dieselsite.com 6pos. chip with high idle, home made tymar air filter system, gauge pod with autometer ultra lite gauges (trans,pyro,boost), shimmed fpr, tru-cool 4590 tranny cooler
NOW: 2005 GMC duramax
Pictures
"If guns kill people I can blame misspelled words on my pencil."
ben_fluke96 is offline
post #2 of 13 (permalink) Old 06-22-2010, 07:16 PM
You do not need to add a check valve to the return lines. It is normal for excess fuel used to cool the IP, etc to run back into the tank and drain from the return lines.
As you said, it sounds like you have air intrusion. A hard start/rough idle when started is typical of air intrusion. Hard start can also be caused by bad glow plug(s), starter, batteries, etc. You might want to see if you can purge some air from the schrader valve. Add a clear line at the hose indicated in the picture:
to see if you get air bubbles. Check for leaks around your lift pump, fuel filter housing and injectors.
1994 F250 7.3L IDI E4OD 4.10 non-posi
K&N Airfilter
97k miles as of April 25, 2010
daimoku is offline
post #3 of 13 (permalink) Old 06-22-2010, 08:26 PM
chuckster57's Avatar
IIRC the line that comes from the top of the IP has a check valve in it. Could be stuck, allowing fuel drain back.
PETE: help me out here. Or is the check valve in the brass fitting in the filter header, where the return line attaches.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #4 of 13 (permalink) Old 06-22-2010, 09:49 PM
cdnsarguy's Avatar
My Photos: (109)
The check valve is in the line from the filter header to #1 injector return line.... that is to allow any air in the filter to be vented to the return line instead of the IP.
Read up on air intrusion....... Ford diesel 6.9 7.3 IDI
Also see the filter leak points....same page. The filter heater "black connector on the top" if wet could mean a leak. Orings can be replaced in it.
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #5 of 13 (permalink) Old 06-23-2010, 08:09 AM Thread Starter
ive already replaced the fuel heater and o-rings and don't see any leaks anywhere else and it only idles rough on the first start up and is smoother after each start up afterwards until it sits for a while
SOLD:
Pictures
post #6 of 13 (permalink) Old 06-23-2010, 06:12 PM Thread Starter
any other ideas
SOLD:
Pictures
post #7 of 13 (permalink) Old 06-23-2010, 07:29 PM
Maybe the seals on the ends of the supply line from the filter header to the back of the IP. Should be snug enough to hold a seal. Mine leaked out when the truck sat for a while. Replaced and good to go!!
Train Horns:
post #8 of 13 (permalink) Old 11-08-2013, 06:18 PM
Fuel Leak Help
I have a fuel leak that looks like it is coming from underneath the piece of plastic located where the arrow in the photo is pointing. The hose where the arrow is actually plugs into this piece. I do not know what part this is or what it does to order a replacement. Any ideas?
Originally Posted by daimoku View Post
gebbeth is offline
post #9 of 13 (permalink) Old 11-08-2013, 07:35 PM
Welcome to the Diesel Stop.
That part is called an injector return cap. Excess fuel not injected into the cylinder, is routed back into the fuel supply. There is 2 O rings on each injector and that cap is pushed on over them. Leaks occur when either the O rings fail or the cap fails.
You could buy just the one cap from your local dealer, but odds are the rest of them are going to follow suit. Better to replace the whole thing.
What you need is called an injector installation kit. It will have all new caps O rings line and clamps. Different price and quality depending on where you purchase.
Sent from AutoGuide.com App
Train Horns:
post #10 of 13 (permalink) Old 11-09-2013, 06:23 AM
NH2112's Avatar
Send a message via MSN to NH2112 Send a message via Yahoo to NH2112
Yep, especially since removing the hoses from the #1 cap will cause the #3 to wiggle and probably break its seal. I avoid touching any part of the fuel return system whenever possible, it's the weakest point in the design of this engine. An all-metal rail using copper washers to seal and being held on with nuts, like on Cummins & Perkins engines, would have been a better idea IMO.
Phil
Check my lists of common part numbers in my photos! Updated often!
1991 F350 Lariat XLT, 7.3l, 5-speed, crew cab, SRW, 3.55, 2WD.
1990 Jeep Wrangler Sahara, in the process of a major overhaul/upgrade. OM617 on the horizon! Front & rear Dana 44s from a Wagoneer till I get some 1-ton axles built & narrowed, and eventually a front shackle reversal. Diesel YJ, bay-BEE, and not a cookie-cutter 4BT conversion!
NH2112 is offline
post #11 of 13 (permalink) Old 11-09-2013, 08:47 AM
drinkypoo's Avatar
My Photos: (25)
Even just metal rails using the same O-Rings to seal would be a major improvement. I have every intention of building one soonish. I think I will tackle the rebuilding the truck camper project first, though. That should be fun compared to the travel trailer project
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #12 of 13 (permalink) Old 10-11-2015, 12:13 AM
My 2004 F-250 is very hard to start after sitting for over 24 hours. I have to crank continually for about 60 secs 2 or 3 times until the oil pressure is up. it feels as if the fuel pressure is way down or fuel drained back. is there a check valve in the system to prevent back flow?
please help
Ralph
turhambey is offline
post #13 of 13 (permalink) Old 10-11-2015, 07:04 AM
return line check valve?
Your truck has a completely different engine and fuel delivery system. I would post your question in the 6.0 forum, but it sounds like HPOP issue.
Train Horns:
