rough idle and bluish white smoke HELP - Diesel Forum - TheDieselStop.com
Old 10-24-2009, 06:18 PM   #1 (permalink)
73dieselcowboy's Avatar
Location: british columbia canada/ farmington california
My Photos: (24)
Well another problem with the old 7.3 engine is a used engine put in a year ago, ran fine but a while ago it started ticking, about a week ago it started idling really rough and blowing bluish white smoke from the exhaust, not using any oil, replaced the injector pump and injector return lines yesterday and still the same injectors are about a year old and before I put the used engine in installed new gaskets through out including heads etc, it is blowing smoke at high rpm but even more at idle engine has about 100,000 miles on it, what else could it be? broken valve spring? worn valve seals? any one with some helpfull advise would be great thanks.
91 F250 heavy gvw 4x4 e/cab long box, xlt lariet,dark green and cream with tan captains chairs,7.3, auto, 4.10 limited slip, auto hubs,b&w gooseneck hitch, ats converter, 3 inch custom exhaust from y pipe back flowmaster muffler 4 inch tip, (yes its loud) home made ram air,97 ford alcoa rims,265/75/16 dunlop radial rovers. custom made front light bar, (made by me)with 4 kc daylighters,electric lift pump. procomp shocks, rough country steering stabilizer,rough country front and rear overload springs,sony explod cd,Autometer z series boost, trans temp, and exhaust temp, in pillar pod, original paint, 425,000 klms on truck, 120,000 klms on motor. pulls a 28 ft aluminum exxsis 3 horse angle haul goose. (and a few chevys and dodges out of the mud HA HA) 1966 falcon 351 cleveland, 4 speed toploader, 450 HP, (sunday toy)
73dieselcowboy is offline
Old 10-24-2009, 06:21 PM   #2 (permalink)
chuckster57's Avatar
bluish smoke is associated with burning oil. I wonder if the valve guide seals are bad? How is the CDR? is it maybe plugged and the crankcase pressure is forcing oil passed things? Are you still in Cali?
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline
Old 10-24-2009, 08:35 PM   #3 (permalink)
My Photos: (24)
No had to come back to bc it started doin g this on the way back, just before seattle, what is the cdr I have your number with me I will try and call you, I am going to do a compression test before I go any further, thanks chuck will try to phone you in a few, Gary
Old 10-25-2009, 10:29 PM   #4 (permalink)
Had the same problem this spring and found two problems. First was exhaust valve seats worn out in cylinders one and two. Next was a timing problem I don't know how it changed but by changeing the timing it cleared up 99 % of the smoke.
crihfieldjack is offline
Old 12-13-2009, 12:46 AM   #5 (permalink)
My Photos: (24)
Well hvnt been on for a while, I was thinking valves or seals thecompression in number 7 is at 250 while the othersare all at 450, im thinking I may have broken a valve spring and it took out the seal, could that be possible? I am flying back to cali for christmas and leaving the truck at a buddys, going to attack it in the new year, I have a buddy that knows of an 89 for nothing the body is rotted out I thought the 89 model had a 6.9 not a 7.3 am I right? and if so will the heads off a 6.9 fit a 7.3? thanks in advance Gary Merry Christmas to all.
Old 12-13-2009, 01:07 AM   #6 (permalink)
Plywood's Avatar
My Photos: (13)
As far as I know blue smoke is usually oil, but burning diesel can be blue if the right temp and what not, but bluish white is probably diesel what does the smoke smell like?
The 89 should be a 7.3L. Look at the number on the block just next to and under the IP driver side, should say 7.3D
Don't know all the ins and outs, but I've read about guys using a 6.9 bottom end with 7.3 heads and calling it a 7.1.
You might have the injectors pop tested, heard about new ones being bad before.
CDR is crankcase decompression regulator, or something very similiar.
It is right to the rear of and under your air cleaner, it lets the block blow by go into the intake, but prevents the engine intake from sucking on the crankcase. In theory of you block the lower end of it and suck in it, it should close, and then when released the spring should push the valve back open. However, it is open at low rpms, so basically a bad CDR behaves the same as a good CDR at low rpms, so not your problem.
85 F250 XLT Lariat 4x4 7.3L N/A, C6, 315/75/16 Siped Wild Country Muds, Manual ZD9s, K&N, Soup Bowl Out, Dura-Lift Pump, Dynomax 3" Y-pipe-4" AFE Muffler-5" Turndown.
http://www.youtube.com/user/Theonlyplywood#p/u
Turn it up!
Plywood is offline
