Running out of gas... - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 11-22-2007, 05:07 PM Thread Starter
If you run out of gas, what is the best thing to do to get the air out of the system? Just turn it over until it starts? Happy T-day!
91 E-350 Pathfinder 4x4, 7.3 IDI, E4OD, Dana 60 front and back, BW1356 w/PTO, 20KW Harrison Hydragen onboard hydraulic driven generator, AirRide Technologies on rear axle, 35" Goodyear MT's.
RlxdN10sity is offline
post #2 of 18 (permalink) Old 11-22-2007, 05:26 PM
dakotajeep's Avatar
Re: Running out of gas...
pour fuel in the filter......I've heard ATF fluid too...
2003 F350 6.0 Lariat Crewcab 4x4 SRW 285/75 16's Treadwright Retread MTG's
Sold:
1994 F350 XL Crewcab 4x4 SRW 7.3 Banks Turbo
Dana 60 Sterling 10.25 3.55, ISSPRO EV Guage and Pyro
PICS of my rigs and random stuff:
dakotajeep is offline
post #3 of 18 (permalink) Old 11-22-2007, 06:47 PM
Cjhstang's Avatar
crank it and push that schrader valve on the fuel filter bracket in. once fuel shoots out, then u should be good.
F-350 4x4 1990
-'94 overhauled 5.9 Cummins
P7100 Injection Pump w/ 4kgsk, 60lb valve springs, Hamilton performance cam, HX40 turbo, ARP head studs, New marine pistons and injectors, FASS system lift pump
-Homemade oem & engine harness with Dual electric fans
-'92 interior; '86 front clip; '04 Hydroboosted front and rear disc brake system; Slew of autometer gauges; dual 4.25" Stacks
-Rebuilt and upgraded my E4OD - billet input shaft and T.C. Remote mount Derale dual layer trans cooler; Baumann Trans Controller and Harness
-3" Body Lift, Cut-Out Bushwacker Fender Flares with 16x10 Eagle Alloy 186 on 33's
All done in the driveway and basement...
Cjhstang is offline
post #4 of 18 (permalink) Old 11-22-2007, 06:50 PM
You're not supposed to have gas in it anyway. If you run out of fuel, remove the filter, fill with clean fuel, reinstall, crank for a moment, bleed air from fitting on filter housing, crank again, should start. Kevin
Kevooo is offline
post #5 of 18 (permalink) Old 11-22-2007, 08:09 PM
cdnsarguy's Avatar
My Photos: (109)
Cjhstang has the best answer... leave filter as is and use the Schrader valve to purge air until fuel is present, allow starter to cool 2 minutes. Now continued cranking for 15-20 seconds with foot to floor may be required after filter is full.
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #6 of 18 (permalink) Old 11-22-2007, 08:40 PM
jabink89's Avatar
i agree with cjhstang and cdnsarguy i have been unlucky 2 and ran it out of fuel. again just use the schrader vavle till fuel shoots out. then follow cdnsarguy with the rest of what he says to do.
Exactly what i did both times(no need to mess with fuel filter.
jabink89
1988 F250 ext. cab dually 2WD 4.56 rear
7.3 W/ ATS Turbo kit, HEAD STUDS, ZF5 single mass flywheel, 12.5 clarck clutch, 6" stacks, mickey thompson supersingles for the summer time.
American flag paint
boost/pyro/oil temp/oil press
1986 f250 Lariat 4x4 6.9L c6 auto/285-75-16's/ brand new viper red paint with my own custom interior viper red and black to match body/front flare out fenders to match newer body style bed from a 95 (custom)
jabink89 is offline
post #7 of 18 (permalink) Old 11-22-2007, 11:40 PM
dakotajeep's Avatar
Apparently, I get a C- on my post......tell me it doesnt work though?
Sold:
post #8 of 18 (permalink) Old 11-22-2007, 11:46 PM
jabink89's Avatar
no you post works just as good haha
its just alot easier using a screwdriver or a pen and bleed fuel to the schrader valve(once you put fuel in the tank of course)
jabink89
American flag paint
jabink89 is offline
post #9 of 18 (permalink) Old 11-23-2007, 08:59 AM
cdnsarguy's Avatar
My Photos: (109)
dakotajeep........ No C- but first choice is the KISS principal, especially when you stuck on the side of the main route through town at rush hour getting a hand full of fingers. Not many of us are equipped to R&R a filter on the road side.
post #10 of 18 (permalink) Old 11-23-2007, 09:02 AM
dakotajeep's Avatar
Yeah, I was being sarcastic....my filter is like an oil filter and comes off by hand....the diesel mechanic put it on....Although, I do have the original setup/parts....
Sold:
post #11 of 18 (permalink) Old 11-23-2007, 04:49 PM
If your driving a diesel, you should have a spare filter and the means to change it.
Kevooo is offline
post #12 of 18 (permalink) Old 11-23-2007, 05:16 PM
Snotzalot's Avatar
My Photos: (5)
Why?
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger Cream Puff, 92,000 Miles, 5.4L Gasser
'90 E350 7.3L Ex-Ambulance High Top 420K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak. 10 wonderful cool years using Freeze12 without any AC system modifications. Retired with blown trans.
Snotzalot is online now
post #13 of 18 (permalink) Old 11-23-2007, 06:55 PM
So when you get a bad tank of diesel and it clogs up your filter you have a means to change it and be on your way... This is a BIG thing if you decide to put biodiesel in, that first tank will clean up EVERYTHING and clog that filter up very fast..
1990 F250 4x4 7.3l IDI 3.55 E4OD 250?k
1997 2500 Ram 2wd Cummins 5spd 3.54 286k
RunRed is offline
post #14 of 18 (permalink) Old 11-23-2007, 07:33 PM
If the fuel can't get thru the filter, your walking! Kevin
Kevooo is offline
post #15 of 18 (permalink) Old 11-23-2007, 07:39 PM
I should add, I tell my customers to carry a spare fuel filter, serpentine belt, and on some vehicles, a CMP and a belt tensioner. The parts are usually the old ones we have replaced before they failed. I tell them, even if you don't have the tools to replace these parts on the road, a tow truck driver or another motorist will. I know I'd rather have these common parts under the seat if something goes wrong. Kevin
Kevooo is offline
