Re: ?'s 93 idi need help
ATS, (factory optioned) Gale banks or Hypermax are your three "off the shelf" choices. Waste gated or non waste gated will be your other option. Figure abot $1700 - $2500 for the kits. Used / EBay ?For Sale section here are other options. I picked up a "take off" factory ATS unit from another board memeber last July. You don't say if you have the E4OD or a hand shacker. If you are auto, you will need a trans computer or upgrade. Id di not change anything prior to installing the turbo. (Hindsight, I should have changed my return lines)
Look up a member named soulpatchfr he is in Norfolk I think.
Joe
Hanover, PA
1993 Ford F350 XLT CC DRW 4X2.
"Factory Tech" modified E40D, 4R100 trans pan
Dual B&M plate style coolers, 4.10 rear,
Factory ATS turbo, Upgraded down pipe,
housing and elbow, DPS Stage 1 Injectors
Banks exhaust, Isspro and Autometer gauges.
My truck
1996 Shasta 265BH
