Old 08-01-2005, 06:03 PM   #1 (permalink)
rawpower's Avatar
Saginaw PS pump on a 93 7.3?
Im just now (finally) completing my hydro-assist steering. For it to work efficiently I will need a Saginaw pump. I already have one waiting, but no means to mount it. I would like to know how can I mount it. If I recall correctly, dont the diesel vans use a saginaw pump? I just need something that will mount to my D side cylinder head and keep the pulley inline with the rest as well as have a mount for the AC and vacuum pump.
What can I do?
Thanks RA
1993 Ford F350 7.3L Turbo Diesel ZF S5-42, Divorced TS NP205, OEM locker/welded 2.5 ton Rockwells, 46" Michelin XML's, and some stuff too.
http://www.supermotors.org/users/RAW_POWER
rawpower is offline
Old 08-01-2005, 08:10 PM   #2 (permalink)
Re: Saginaw PS pump on a 93 7.3?
sounds like you already answered your own ques--why wont the stock pump work--what did ford use on the later sd's???? remember that someone drilled out the hole in the pressure line output fitting--for the hydro assist sd's--said made world of diff---
94_turbo is offline
Old 08-01-2005, 09:52 PM   #3 (permalink)
rawpower's Avatar
Mine currently uses a C-II pump. Its gpm is too low for hydro assist.
The Saginaw is more reliable and has a higher gpm.
On the drilling out thing, are you takling about this:
http://westtexasoffroad.homestead.co...rsteering.html
rawpower is offline
Old 08-02-2005, 01:57 AM   #4 (permalink)
towcat's Avatar
Got hydrostop on my truck. got the plastic res. for the 88-94 f450. It has two return nipples one for the hydro and the other for the gear. never has a low boost issue on any of my F450's for running any Ford pump that came off a salvage Ford pickup. One more thing to consider, if you do use a saginaw pump, you will have to get a high pressure hose made to convert your ford fitting to GM fitting.
86 f250 6.9IDI, 4spd 4X4 "the runt"
89 f450 rollback carrier 7.3IDI, ZF5, 4X2(in memory of...)
90 f450 conventional towtruck 60"CA 7.3IDI, E4OD, 4X2
92 f350 CC 7.3IDI, ATSturbo*intercooled*, ZF5, hydrostop, 4X2 "the nebuchadnezzar"
...Quack Quack................*P.A.K.*...
red pill or the blue pill? make your choice and pm me.
7/03 mini meet pics
towcat is offline
Old 08-02-2005, 11:53 AM   #5 (permalink)
rawpower's Avatar
My current hose already threads into it... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Whats hydrostop?
rawpower is offline
Old 08-02-2005, 12:55 PM   #6 (permalink)
the guy that drilled out the outlet piece did this on a ford stock pump---and as he said--no pressure problems---
94_turbo is offline
Old 08-02-2005, 01:34 PM   #7 (permalink)
towcat's Avatar
Whats hydrostop?
hydrostop=hydroboost...
Doesn't Ford use a O-ring style fitting and GM use a double flare type fitting? But then again, if it doesn't leak...go for it.
7/03 mini meet pics
towcat is offline
Old 08-02-2005, 04:47 PM   #8 (permalink)
rawpower's Avatar
Oh I thought you were saying that it doesnt even thread in and I would therefore need to get a new hose. It threads in but may leak as you said... Ill see.
Still working on the bracket to mount it with...
Anyone know if a bracket off of a 6.9 or 7.3L van will work on my truck and keep the pulley in line with the rest? Do they have provisions for mounting an AC and a vacuum pump?
What GPM is a Saginaw pump?
What GPM is a CII pump?
rawpower is offline
