seatbelt warning "chime" won't shut off... - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 01-19-2011, 02:04 AM Thread Starter
lexxxel's Avatar
my seatbelt warning "bell", that comes on when you start the truck, is not turning off today. Well, it did turn off after about 10 minutes, but then it came back on about 5 minutes later. It's mostly been on all day while driving the truck. Rarely off. It's making me crazy
Driving for 45 minutes with that noise is... well... crazy making
any suggestions as to what's wrong, or what might fix?
'91 F-250 7.3idi XLT Lariat Supercab
Non-Turbo, Bone Stock
E4OD 4x2 4.10 non-posi
6 digit odometer
122,000 miles (197,000km)
still Minty Fresh
Sold my old 90 reg cab @340,000 miles (550,000km)
Still running I'm sure...
lexxxel is offline
post #2 of 17 (permalink) Old 01-19-2011, 05:18 AM
cdnsarguy's Avatar
My Photos: (109)
Do you have anything heavy on the pax seat .....try connecting the seat belt. Many vehicles have pressure sensitive switches.
There are wires to the locking device side which shut off the module when connected....... wires could be broken. It is a continuous loop system.
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #3 of 17 (permalink) Old 01-19-2011, 07:36 AM
drinkypoo's Avatar
My Photos: (25)
seatbelt switch, door switch
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #4 of 17 (permalink) Old 01-19-2011, 07:53 AM
My Photos: (27)
'91's don't have a seat belt chime.
LMJD is offline
post #5 of 17 (permalink) Old 01-19-2011, 11:29 AM
drinkypoo's Avatar
My Photos: (25)
door switch then. my D/S switch was disco'd by PO, I kind of like it. pass side switch failed to shut off one time recently but I wiggled it and it's OK, guess I should address that soon.
post #6 of 17 (permalink) Old 01-19-2011, 11:57 AM
My Photos: (27)
Lexxxel, the chime is triggered by a headlight warning that they're still on after engine shutdown. IIRC the only other thing that triggers it is the warning that the key is still in the ignition when you exit the vehicle and have the door open. I disconnected that feature years ago. Your problem might be related to either of those circuits.
LMJD is offline
post #7 of 17 (permalink) Old 01-19-2011, 11:54 PM Thread Starter
lexxxel's Avatar
there's a seatbelt chime on the '91... at least on the canadian model (just like there's a 6 digit odo on the canadian trucks and only 5 on the US models)
and same chime for lights left on, same for door open key in ignition.
The reason I think it's the driver's belt chime, is it usually goes off when you put on the seatbelt. And, if you don't put the belt on (like when the truck is covered in snow and you know you're getting back out after starting it), the chime goes out after about 10 seconds.
When this started, i was in the truck, started it, seatbelt chime started up, I put on the belt, and it did a weird faster chime for a split second, then just kept beeping like normal, and would not stop.
So I'm thiinking belt issue... I will check for loose wires in the clasp, but I did wiggle the thing around while I was driving with no affect...
would it just be in the clasp that the problem is? Or where else does that wire run?
6 digit odometer
still Minty Fresh
lexxxel is offline
post #8 of 17 (permalink) Old 01-20-2011, 07:36 AM
My Photos: (27)
Never thought of the Canadian factor. We're not required to have the DTR lites either. Guys on the Tundra forum were quick to point out (new Tundra's have the seat belt warning) that driving down the road with their dog in the passenger seat would trigger the warning off and on if it was over a certain weight. Any chance that's your problem?
LMJD is offline
post #9 of 17 (permalink) Old 01-21-2011, 12:10 AM Thread Starter
lexxxel's Avatar
lol, no there doesn't ever seem to be a warning about the passenger side seatbelt... I think that was a more recent invention. The dog setting it off would be annoying.
I hate random stupid electrical issues. I'm not good at any of that
6 digit odometer
still Minty Fresh
lexxxel is offline
post #10 of 17 (permalink) Old 01-21-2011, 02:54 AM
cdnsarguy's Avatar
My Photos: (109)
You could just unplug the module...........
post #11 of 17 (permalink) Old 01-21-2011, 04:09 PM
standbypowerguy's Avatar
My Photos: (28)
I left my key off, but in the ignition and the DS door open for several hours this past summer. The chime wore itself out, almost. It still works, but it's no longer loud and annoying, rather it's very soft and difficult to hear. I'd unplug it if I could find it, but the "ding" it makes is so maddeningly omnidirectional. Anyone know what it looks like and where under the dash it resides?
'89 F250 2WD XLT Lariat Supercab,
7.3 IDI, C6, 10.25" 3:55, dump bed.
Mods: Gear Vendors overdrive, ATS 085/088
"Frankenturbo", boost and EGT gauges in pod,
K&N air filter, cold air intake, filter minder, rear
work lights, 'monback beeper, pintle+ball hitch,
brake controller, CB.
Wish list: 130 amp G3 alternator, front hitch,
new hood, fresh paint.
standbypowerguy is offline
post #12 of 17 (permalink) Old 01-21-2011, 04:53 PM
My Photos: (27)
I don't think you want to unplug the chime itself because I think it's the warning for when you leave the headlites on too. I snipped the wire coming off the ignition switch about the first week I owned the truck, think it was white with a purple tracer.
LMJD is offline
post #13 of 17 (permalink) Old 01-22-2011, 01:01 AM Thread Starter
lexxxel's Avatar
yeah, the chime for the headlights is good. Where's the module for the seatbelt chime, or is it the same module for all 3 warnings? Or should I just look for the seatbelt wire, in the clasp? Still haven't taken a look yet, it's too darn cold!
6 digit odometer
still Minty Fresh
lexxxel is offline
post #14 of 17 (permalink) Old 01-22-2011, 03:06 AM
drinkypoo's Avatar
My Photos: (25)
There is only one chime module.
post #15 of 17 (permalink) Old 01-23-2011, 05:36 AM
rotaryboots's Avatar
Send a message via MSN to rotaryboots
mine doesn't have it at all. I have wires going to my seat belt and what-not, but never has the truck ever chimed at me. Was kinda wondering where the module would be located too, I would like the "lights are on" chime and was kinda thinking of putting a newer chime in my 90 like from a 01-06. For some reason I like that chime and feature like the one in my newer truck.
'90 7.3 IDI F350 4x4 Custom, ext cab, E4OD w/ tow package, 4.10 Dana LSD rear, 94' ATS turbo kit w/ 99' PSD wastegated charger set at ~20psi max, copper firering head, studs, turbo IDI block, mild head work, Delta Cam, Moose pump, turbo injectors, 6.0 PSD intercooler, propane injection, 3in exhaust. Almost 300 and 500. (added 2 more flats than previously) 296hp, 487tq (6/4/11)
'03 7.3ltr Powerstroke F350 4x4 4dr. SCT Livewire, ATS exhaust, rebuilt HD trans, 6.0 trans cooler, fuel mods, AFE intake, Garrett gtp38r ball bearing turbo; glad its not a troublesome 6.0
rotaryboots is offline
