Shift lever, can't get out of park - Diesel Forum - TheDieselStop.com
Old 07-07-2008, 02:38 PM   #1 (permalink)
Merisangel's Avatar
Wink Shift lever, can't get out of park
Hi guys, I have a problem with getting my truck out of park. It's a 94 F250 4x4 auto trans. As usual I push down brake pedal after starting and it won't shift out of park until repeated push downs and releases of the brake pedal. Would this be the safety switch gone bad? I've been told there are two, one around the brake pedal and one on the tranny somewhere. Could any of you fellows help me?
Thanks so much...Meri
94 F250 Turbo SC 4x4, Centurion Package, K&N filter, straight pipe, E4OD, 4:10
99 Mallard 27' TT
Merisangel is offline   Reply With Quote Quick reply to this message
Old 07-07-2008, 03:11 PM   #2 (permalink)
My son is having the same problem. we have his dash tore apart. then Last night I read it might be a brake light fuse. Putting dash back together to see if this works. Anybody eles have any Ideas?
diesel dad 96 is offline   Reply With Quote Quick reply to this message
Old 07-07-2008, 04:41 PM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Is the truck weight resting on the park pawl ie on a hill. I can find no reference re a requirement to press the brake to allow the trans to be shifted in the 94 truck info on Ford CD.
Proud Canadian BOOB man too!!
cdnsarguy is offline   Reply With Quote Quick reply to this message
Old 07-07-2008, 10:59 PM   #4 (permalink)
Merisangel's Avatar
No, it' not parked on a hill, in the garage. I have always had to depress the pedal to shift out of park. Another post under the PSD had a similar problem and was stated to be the brake switch. I haven't checked my brake lights as I am not at home until tomorrow, but I will check that out and see if my lights are working. I don't think it's a fuse since it will shift after repeated pumps on the pedal....MS
99 Mallard 27' TT
Old 07-08-2008, 06:10 AM   #5 (permalink)
cdnsarguy's Avatar
My Photos: (109)
OK just checked 96 info....... there are 2 fuses #18 and #13...... BOO switch signals the Shift lock actuator. BOO.......Brake on off switch found on the brake pedal arm.
Old 07-12-2008, 07:17 PM   #6 (permalink)
Merisangel's Avatar
Problem solved...$14 brake switch save the day. Easy to install...even I can do it...saved tons of bucks
This forum is the best place to come for help and I sure appreciate all the expertise available through this site.
You guys are top notch!
99 Mallard 27' TT
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
