Old 04-10-2005, 06:06 PM   #1 (permalink)
My Photos: (5)
Should I, or shouldn't I ?????
So I'm ready to put the lifter in a see how it does. I'm asking one more time. [img]/ubbthreads/images/graemlins/vulnerable.gif[/img]
If I do not change the head gaskets and bolts at 140,000 am I asking for trouble? [img]/ubbthreads/images/graemlins/confused.gif[/img] Money is a serious issue. [img]/ubbthreads/images/graemlins/mad.gif[/img] I need to put an exhaust on it too.
I'm thinking og getting the 02+ PS tailpipe and running 4"straight to a full flow muffler and 4" from the Y to the muffler. I should be able to do that for <$200.
[img]/ubbthreads/images/graemlins/cool.gif[/img]
[b]Gunther X [img]/ubbthreads/images/graemlins/cool.gif[/img] 1988 F350, CC, DW, 7.3 IDI, non--turbo (for now),C-6, 4:10 rears, 141,000, new IP & injectors, 4" exhaust. US Gear Dual Range Aux Trans Overdrive, Headlight Mod, Coolant Filter Mod, Transferflow 45 Gal. Aft axle Tank (Have to wait a lot longer now for those UMM Necessity stops, Ouch!). Phantom Pyro.
Recently repainted (all Ford paint fals off). Pull 37' Phillips steel horse trailer GVCW 17K-21K. MPG 7-8 w/trailer, 10-12 no-trailer (sucks)
guntherx2000 is offline
Old 04-10-2005, 06:39 PM   #2 (permalink)
Re: Should I, or shouldn't I ?????
If you did not remove any of the head bolts and you see no reason to change the head gaskets, then don't change them. It is your call. You will not be very happy if you don't change them, after you drive 1200 miles and blow a gasket. I would change them if it was my truck. Skip the exhaust for now. That is my take on the situation.
Dave
2004 F-350. Standard Cab, 4X4, 6.0 with Torqshift, 3.73 w/LS. <font color="red">(((XM))) Satellite Radio.</font> Lo Jack, 6608 lbs wet. Born on 8/4/2003. Engine 07/23/2003. 3" Lift. Grover Air Horns!!!
http://community.webshots.com/album/85108545NlXNsD
1993 F-350 4X4 7.3 IDI with 5 spd. Gone now.
1976 Kenworth C-500 with Detroit Diesel 8V92TA with 3 spd Jake, SQHD's and RTO 12513 10 Wheel Dump Truck. Sold.
dbennett48 is offline
Old 04-10-2005, 07:20 PM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (66)
My take would be: due to the fact you are not sure what may happen after the lifter replacement and running why do heads now. If you have a problem again with the lifter and have to redo the engine then you will be required to do head gaskets again.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 04-10-2005, 08:52 PM   #4 (permalink)
My Photos: (23)
Greg, I agree with Pete. If you were to have to do headgaskets at some future point, at least you won't have to touch the lifters. [img]/ubbthreads/images/graemlins/smirk.gif[/img] Unless you have a leak, may as well get all the life out of them you have coming to them.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 04-10-2005, 08:58 PM   #5 (permalink)
Posts: n/a
Post deleted by JLester
Old 04-10-2005, 09:01 PM   #6 (permalink)
I'd leave them be since the 7.3 didn't have nearly the head gasket problems of the 6.9. Doesn't mean you won't blow one at some point, but I wouldn't expect it to be right away. Unless, that is you see them weeping already at the edges, then go ahead and change 'em.
J.D.'s Fords: 1986 F-250 6.9 diesel Solid State Glow Plug System 3.55 gears C-6 2WD 178,960 miles.... it still runs pretty good!
Wishlist H-max turbo, T19 tranny,
1989 Ford Ranger ga$$er, non runner, soon to be donated or scrapped!
jdkline is offline
